Old 10-21-2012, 09:51 PM   #15
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by wootwoot View Post
Can you describe how you prepared them for the paint? Good work.
Red Scotch pads(get them at any paint store, not sure if Lowes/HD carries it). Using sand paper sucks, these pads work well and help reaching difficult areas.
Basically take your time scuffing them down to where there is absolutely no shine whatsoever anywhere on the face, lip, and lips edge. Ensure you get in between the spokes and any other tough corners to reach... this can be time consuming.
After you believe you're satisfied, shoot air all around the wheels face and check for any spots that look wet(haven't been scuffed sufficiently). Scuff them and make sure everything looks hazy/ashy.
After that... degrease the wheels/wipe em down. I suggest using an alcohol based degreaser as any moisture you don't let dry will not allow your paint or primer to bond to the surface properly. Whether you use primer or not is totally optional. I didn't as I found it unnecessary.
After that, tape the tires up... LAY THE TAPE AS FAR DOWN ON THE TIRE BEAD AS POSSIBLE. Then shoot the wheel with the airhose one more time to be safe to remove any particles and avoid having a grainy finish.
Then for paint/primer... your 1st coat you spray you want to be light. You want to be able to still see the original surface through it but have a definite hue to it. I suggest starting off by shooting the edges/insides of the spokes then working your way to lip and face. From there you want to make your next coats heavier but light enough to avoid any running.(by the time I finished my second coat I was almost at my final color outcome, smooth and evenly distributed).
*note that time between your coats will vary, I used a duplicolor can that was metalized.... it called for 10-15 minutes between coats and I followed that.
Hope that helps a little, sorry I didn't do a step by step as I was already exhausted. Sure there's plenty on Subaru boards though.
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 9 Users Say Thank You to OmarGC For This Useful Post:
avusblue (10-22-2012), BabaYaga (04-12-2015), chaoskaze (05-02-2015), diirk (10-23-2012), gonzo (10-25-2012), HotLeopardMama (04-11-2013), LeeMaster (12-22-2012), Mr. (04-30-2013), sierra (11-18-2013)
Old 10-21-2012, 09:53 PM   #16
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Damn, this thread is seriously making me consider gold wheels
I'll be back!!
F3dzo is offline   Reply With Quote
The Following User Says Thank You to F3dzo For This Useful Post:
Sportsguy83 (10-29-2012)
Old 10-21-2012, 09:57 PM   #17
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Also tape your valve stems lol
Omar GC
Instagram: 2jzus
Old 10-21-2012, 11:37 PM   #18
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
Looks good I know you save yourself a thousand or so from buying new rims by painting them
oso_25 is offline   Reply With Quote
Old 10-21-2012, 11:39 PM   #19
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
I wish that's how I worked... sadly, I'll probably have 3-5 sets of rims by the end of next summer. I have a problem, I admit it...
Omar GC
Instagram: 2jzus
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
adprokid (10-23-2012), JoeHK (08-12-2015)
Old 10-22-2012, 10:36 PM   #20
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
came out really good! it's clean man.
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
OmarGC (10-23-2012)
Old 10-22-2012, 10:47 PM   #21
gusbarragan
Drives: 2013 Scion FRS
Where did you get the BRZ vents?
gusbarragan is offline   Reply With Quote
Old 10-22-2012, 10:55 PM   #22
mashal
DADA
mashal's Avatar
Drives: 2013
Sexy, I'm gonna copy you
I-Tapatalk
mashal is offline   Reply With Quote
The Following 2 Users Say Thank You to mashal For This Useful Post:
OmarGC (10-23-2012), SkAsphalt (10-23-2012)
Old 10-23-2012, 02:13 AM   #23
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Traded someone my fr-s panels for their brz vents. Had to overnight to WA(aprox $32). But you can purchase the brz vents from Subaru unpainted for $86 per side aswell...
Omar GC
Instagram: 2jzus
Old 10-23-2012, 02:16 AM   #24
inimitable
inimitable's Avatar
Drives: SSM 6-MT limited
Looks solid.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
inimitable is offline   Reply With Quote
Old 10-23-2012, 08:48 AM   #25
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
You brought the wheels back to life, i knew that a solid color will look better, and the bronze is amazing on the whiteout
adprokid is offline   Reply With Quote
Old 10-23-2012, 01:00 PM   #26
wparsons
wparsons's Avatar
Looks so much better. What paint did you use? Any idea how it'll hold up to winter use? I'm going to run my stock wheels with snows, but I'm tempted to paint them first.
flickr
Old 10-23-2012, 05:06 PM   #27
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Also the frs will be garaged when salt/snow is on the ground. Which ever comes 1st.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
Old 10-23-2012, 05:22 PM   #28
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I kind of want to paint my stock rims because I want bronze ones anyway...this does make it look pretty great. I would shoot some clear on them tho.
bbs gold, stock, wheels
Wheel Directory: BBS RF 17x7.5 +48 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 112 11-02-2023 06:40 AM
Wheel Directory: BBS RG345 17x7.0 +48 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-16-2018 01:24 PM
Wheel Directory: OEM Scion tC 17x7.0 +45 Propaganda Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 09-09-2017 06:51 PM
Wheel Directory: BBS RK 17x7.0 +48 Laika Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 05-21-2017 06:31 PM
Wheel Directory: Advan RC II 17x7.5 +43 Hippophobia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-13-2017 04:08 PM
