Old 10-22-2012, 06:01 PM   #3137
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by jpit View Post
Just curious but why is it that only the second gear gets the rpm raised to 8000? Do all the other gears stay at the stock limit of 7400?
Not positive but I think the other gears get the 7800rpm redline. Probably has to do with the simple fact there was more power to be made past 7800rpm in second gear but not the others.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 10-22-2012, 06:10 PM   #3138
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
it is so you can get over 60MPH in only 1 shift. as was said, its for 0-60
SkAsphalt is offline
Old 10-22-2012, 06:14 PM   #3139
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Interesting, I was under the impression the old (tuned) 7800 limit already allowed for that.
Edit: Or is that why you made sure to say "over 60mph" ?
Laika is offline
Old 10-22-2012, 06:34 PM   #3140
JoeKingNoah
Drives: FRS
So are we clear to flash our cars now or are we still waiting on an all clear? I have been reading over the last 20 or so pages but I do not see a clear yes or no.
Thanks
JoeKingNoah is offline
Old 10-22-2012, 07:28 PM   #3141
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
Thanks to @xjohnx and @Hawaiian for the PM and video help. Once JV gets the kinks in the e85 map tweaked I'll be going to the dyno!
I go to Richmond for work every other month or so - maybe I'll see you on the road xjohnx?
2013 BRZ Limited WRB
ICEBONEZ is offline
Old 10-22-2012, 07:44 PM   #3142
boris
Drives: 2013 white scion frs
is this new tune a public release version or a test version?
boris is offline
Old 10-22-2012, 07:55 PM   #3143
xjohnx
Grip>Slip
xjohnx's Avatar
Definitely! Hit me up!
xjohnx is offline
Old 10-22-2012, 08:13 PM   #3144
lopro25
lopro25's Avatar
Drives: Hot Lava FR-S
Ok can somebody please tell me how to do a data log?
Sent using mobile Tapatalk App
lopro25 is offline
Old 10-22-2012, 08:16 PM   #3145
xjohnx
Grip>Slip
xjohnx's Avatar
Recent Roms -> 1 -> Map Access -> Log to File.
xjohnx is offline
Old 10-22-2012, 08:19 PM   #3146
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Page 1
Bu-Tang is offline
Old 10-22-2012, 08:30 PM   #3147
lopro25
lopro25's Avatar
Much appreciated.
lopro25 is offline
Old 10-22-2012, 11:13 PM   #3148
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
****DATA LOGS*****
In ProECU, click on FILE -> Open Rom File and open your tune (RR-1xxxx)
With the car running and laptop connected to the car click on map access , once the numbers start moving click on log to file.
When done- click log to file, then map access again.
Datalog will be saved in c:\ecutek\map access logs
It can now be viewed, graphed, emailed, etc
2URGSE
JPxM0Dz is offline
The Following 2 Users Say Thank You to JPxM0Dz For This Useful Post:
JoeBoxer (10-22-2012), kwood9000 (10-22-2012)
Old 10-22-2012, 11:57 PM   #3149
gmookher
uncheck parameters you dont want to log
gmookher is offline
Old 10-23-2012, 12:14 AM   #3150
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Good to know, recommendation on which parameters to uncheck and what senarios to run a datalog ? For example, run datalog for how long ? Car stationary, 0 to 60 etc ?
I have no idea as I have never done one and I'm guessing most have no expereince in this area
Thanks!
2URGSE
JPxM0Dz is offline
The Following User Says Thank You to JPxM0Dz For This Useful Post:
lopro25 (10-23-2012)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
