Old 10-17-2012, 01:07 PM   #15
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by drew935 View Post
Yes, they are worth the price.
If the OP wants it then it is not overkill, and I never looked at coilovers as bling.
It's the value of what he is willing to pay to get what he wants.
Bottom line is, we pay for the results that we want.
Wanting something doesnt negate it being an overkill for its purpose. And if you want to pay for results cusco street specs arent very high in the performance world. Coilovers and cheap coilovers are often under utilized.
chulooz is offline   Reply With Quote
Old 10-17-2012, 01:19 PM   #16
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
Originally Posted by chulooz View Post
Street coilovers? Aside from some adjustability and bling they will be an overkill. Nice struts and shocks would do well for you. You can get some higher quality for less coin with that route.
any suggestions?
FRS-HHH is offline   Reply With Quote
Old 10-17-2012, 01:25 PM   #17
chulooz
Registered you sir
chulooz's Avatar
Keeping my eye on the koni inserts.
Old 10-17-2012, 03:41 PM   #18
Racecomp Engineering
With any coilover or replacement damper, make sure you check on warranty and cost/ease of rebuilding in the future.
- Andrew
Old 10-18-2012, 03:32 PM   #19
ModBargains
ModBargains's Avatar
Drives: FRS, M3
If you want a street setup, the Cusco Zero Street A setup will be just fine, but I think it's going to way passed your budget of $1,700.00.
If you want a great setup in that price range, you can always look into CKS Coilovers for your FRS/BRZ which is in the $1700 range.
-Frank
ModBargains is offline   Reply With Quote
Old 10-19-2012, 11:59 PM   #20
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
-Frank
which do you recommend tein flex? or cusco zero street A?? or a good spring set up like RCE yellow springs?
Old 10-20-2012, 12:54 AM   #21
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I think Frank (ModBargains) is confused on the Cusco's, he quoted me $2500, should be more like $1600 from what i've seen for the one's being discussed here.
Old 10-20-2012, 01:58 AM   #22
IllusiveFRS
IllusiveFRS's Avatar
Drives: 13 Scion FRS, Asphalt
Quoted you for with pillowball mounts probably
13 FRS Asphalt
Jackson Racing Supercharged, Nameless Performance front pipe with cat and helmholtz resonator, Greddy EVO3 exhaust, tuned by Church Auto Testing. Cusco braces all around, KW V3 coilovers. Winmax brake pads with DBA rotors. Thank you CSG for all the useful help!
IllusiveFRS is offline   Reply With Quote
Old 10-20-2012, 02:02 AM   #23
JoeBoxer
JoeBoxer's Avatar
correct
Old 10-20-2012, 09:26 AM   #24
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
yah they are about 1506 at frsport.com im thinking of getting those..but im not sure hahaa..still debating between these and the tein flex's...the other company i ordered the tein flex's from said they didnt have any in stock so refunded my cash..so im back to square one again
Old 10-22-2012, 06:48 PM   #25
Norcalscionchamp
Norcalscionchamp's Avatar
Drives: Whiteout 6MT Scion FR-S
Or quoted you the $2500 price for a set of "street zero A" coilovers which is what I have with the TSW wheels...love them...super responsive with a smooth and comfortable ride...quality product comparable to KW's
Norcalscionchamp is offline   Reply With Quote
The Following User Says Thank You to Norcalscionchamp For This Useful Post:
MVLSCROWNZ (02-10-2015)
Old 10-22-2012, 07:21 PM   #26
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
anything else you did suspension wise besides the cusco coilovers?
Old 02-11-2013, 09:24 PM   #27
RT87
I see that these have no upper mounts. I don't know too much about suspension.. what are the pros and cons of this?
RT87 is offline   Reply With Quote
Old 03-31-2016, 08:17 AM   #28
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by FRS-HHH View Post
anyone know if these are any good? just curious..tried looking for some reviews but didnt find anything
I know I'm a bit late on the reply here, but maybe it will help someone.
Cusco Street Series are optimized to retain the character of stock street traits, and maximize flexibility on how you build a car for the street.
Each of the applications are carefully tested and valved so it isn't exactly cheap cookie-cutter design however, so the street use manners are excellent with long lasting shock body and valve seals and durable construction. Very good for folks with high percentage of street use who wants to extend the sporting character with high consistency and low maintenance long term ownership.
The applications for sports cars are made with sharpness in mind, and for others like wagons and sedans, more towards comfort and control of unwanted motions. That said, it isn't exactly made for motorsports, as maximizing true track performance requires a more focused and not as wide range of flexibility.
For performance Cusco makes a much higher grade mono-tube units called Zero3 Series, which feature a much higher performance envelope and customized to street application to full racing and rally using very different valving and rigidity combinations of parts in different packages.
FYI: Cusco coilover system convention uses the following naming. Just to help one make a selection:
Touring A- OEM configuration fixed height replacement shocks (using stock or drop coils) and with adjustable damper setting.
____
Street Series (Premium Twin-Tube design)
-flexibility in catering to wider range of street customization, ride height and stroke range.
Street A- adjustable damper control, compatible with eCon electronic controller. (Height control at spring preload perch only)
Street Zero- adjustable height at damper body, and independent from spring perch, so as not to bother the preload while changing height. (Fixed damper setting)
Street Zero A - combined with both of the above features of Adjustable damper setting, as well as independent height control and spring preload.
Zero3 Series (High-end monotube, some inverted)
Zero3S - High Grade monotube compatible with street use, and casual sunday racing on track, autocross etc on street summer radials.
Zero3R - Full competition capable monotube
Zero3G - Full Heavy Duty Gravel and Dirt compatible Rally system
Zero3X - Totally customizable Triple Adjust separate reservoir racing system.
___
Also, if you have followed my R&D on the RSR Sports-i and club Racer development, the choice based on that comparison will be this following.
RSR Sports-i compares to Cusco Zero3S
RSR Sports-i Club Racer compares to Cusco Zero3R
Additionally, KWV3 compares well to construction of Cusco Street A, (non-Zero) with use target of a little more competitive focus than Cusco Street Series, but not as refined in wide ranges of uses as mono-tube offerings from RSR or Cusco. The KWV3 however, are customized by a bunch of tuner independent shops so there are shop-specific version that are very good for competition use, if one can select from one of those shops (usually runs a much higher premium for good R&D though)
Moto Miwa
www.club4ag.com
R&D Driving Engineer, Product Planning Consultant
Consulting Member at Cusco, OEM+, RS-R.
www.club4ag.com
Moto-P is offline   Reply With Quote
The Following 2 Users Say Thank You to Moto-P For This Useful Post:
rcm47 (03-19-2017), Zaku (10-22-2016)
RS*R Sports-i Coilover system, Club4AG Moto Spec. - Group Buy Moto-P Brakes, Suspension, Chassis 87 03-26-2014 09:54 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 06:12 PM
Enjuku Racing - HKS Hi-Power Spec-L Exhaust System - Scion FR-S / Subaru BR-Z Enjuku Racing Engine, Exhaust, Bolt-Ons 0 07-20-2012 01:10 PM
New cusco transmission mount! Silverdub Engine, Exhaust, Transmission 5 07-11-2012 09:50 AM
