Old 10-17-2012, 09:37 PM   #71
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Wanted to highlight before and after
20121005-RCEYellow-CuscoLCA-16 by VictorN07, on Flickr
And after
20121012-WhitelinePerrinBushing_Headerback-9 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 10-17-2012, 10:15 PM   #72
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Slight improvement, I guess.
Phaedrus29 is offline   Reply With Quote
Old 10-17-2012, 10:21 PM   #73
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Do you need to remove the shields if you install only the front pipe + catback? In the photos it looks like you have room in the little cut out in the rear shield to reach the bolts on the overpipe/frontpipe connection.
Amadeus is offline   Reply With Quote
Old 10-17-2012, 10:32 PM   #74
F1point4
Photo Specialist
F1point4's Avatar
Yes you have to remove the fiberglass panel; No you do not need to drop the silver skin pan to replace the front pipe and over pipe. Unfortunately I do not have good pictures of this.
For proof, we did the Whiteline positive shift kit with only removing the fiberglass cover. We had to drop the front pipe to undo the transmission brace. see the below thread for more info
http://www.ft86club.com/forums/showthread.php?t=19782
Old 10-17-2012, 10:39 PM   #75
Amadeus
Amadeus's Avatar
Thanks!
Old 10-19-2012, 12:14 PM   #76
gmookher
Originally Posted by PERRIN_Chris View Post
Most likely if we did have a header, it will not have a cat.
So there is hope? Is my jedi mind trick working on Jeff? Prayers perhaps being heard by someone above? I do face east and all..
I've been begging for a race only spec header, not at all for street use type of product, for anyone truly serious about stuff like forced induction like a Vortech, not looking for the back pressures common in turbo applications, and not concerned with sound levels at all. Pure power maker, catless. Price wont matter to this customer, build quality and power will. Must be built for the abusive driver. For the guy who wants to do cams etc. That spec of product, that will marry the rest of your piping and cans from street use over to track duty.
Please?
Old 10-22-2012, 06:03 PM   #77
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
Just install my header back Perrin yesterday bought from BRZ-Parts.com , everything works fine, no issue very well packing. I acutually switch from SRT(way too loud for me) lucky I sold before I get it hear one from my friend's FR-S with it. This header back is very high quality and very easy to install. I install all by myself with jack stand. 2.5 hours. Thank you for all the post before so that I can save tons of time. No drone at any speed. The sound is perfect for me. Did not really have time to try it just drive a day but rpm pick my very smooth and yes can feel more power too. Can't wait for Perrin's tune and intake!
scioneric is offline   Reply With Quote
Old 10-22-2012, 06:16 PM   #78
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Looks like a nice exhaust there
JWMotoring is offline   Reply With Quote
Old 10-23-2012, 09:07 AM   #79
jehu
Drives: JDM LN130 Toyota Hilux Surf
resonated?
jehu is offline   Reply With Quote
Old 10-23-2012, 01:17 PM   #80
scioneric
scioneric's Avatar
Originally Posted by jehu View Post
resonated?
Yes Header back resonated.
Old 10-26-2012, 07:35 PM   #81
cnk
Drives: '13 DGM BRZ Limited
Did my Perrin headerback installation today. Looks like the OP and I had the same gorilla torque that nut down from the front pipe to overpipe. Unfortunately, I didn't get lucky and have the stud snap on me. Instead, the nut was seized and when I put some heat on it to try to remove, the nut stripped the threads on the stud and just spun in place. Had to Dremel the nut off. That added another couple hours to the job, but it's all installed now. Only thing that I discovered is that one of the locking collars was missing a set screw so I'll have to call Perrin.
Old 10-27-2012, 01:49 PM   #82
Eric1855
Drives: LP DSP / CSP '13 BRZ
I put my Perrin headerback on today. Surprisingly easy, it took about 3 hours without a lift.
The longest part was getting the car up on all 4 jackstands and taking the damn under trays off.
Eric1855 is offline   Reply With Quote
Old 10-27-2012, 01:55 PM   #83
DSOmegaX
DSOmegaX's Avatar
Installed frontpipe and overpipe yesterday to complete my headerback. Changed the tone of the exhaust dramatically compared to just the catback section!
@dsomegax.cars
Old 10-27-2012, 02:47 PM   #84
Opposed
Drives: 2013 Asphalt FR-S
Are you running the catless front pipe or catted? And are you resonated or non?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
exhaust, headerback, perrin
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Brand New SRT Headerback Exhaust System prest1ge Southwest 5 10-16-2012 06:06 PM
