Old 10-20-2012, 08:08 PM   #645
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Installed my non-offset axleback today...looks and sounds good!
By the way, both tips look even.
kwood9000 is offline   Reply With Quote
The Following User Says Thank You to kwood9000 For This Useful Post:
Sportsguy83 (10-20-2012)
Old 10-20-2012, 10:38 PM   #646
sdshores08
sdshores08's Avatar
Drives: 2013 Ultramarine FR-S, AT
Installed mine from the group buy. The right tip sticks out about an inch further than the left one, but I'm more than happy with it since it gives the car the sound it has been missing. If it bothers me later I'll just take it to a muffler shop for a quick-fix.
sdshores08 is offline   Reply With Quote
Old 10-21-2012, 11:47 AM   #647
zooki
Drives: waiting on a 2021...
Installed mine a couple of days ago. The tips on mine are even(or close enough I can't tell). Now I just want to ride around with the windows down...
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
DGMBRZ (10-22-2012)
Old 10-21-2012, 01:58 PM   #648
gonzo
Drives: frs
The back part of my front pipe was really misaligned. It made a huge exhaust leak that was extremely loud and it sounds like my car is farting constantly. I got under and took off those spring bolts, loosened every other bolt, then refastened the spring bolts.
Kept tightening, the gap was still there. Tightened more and more until the spring bolt broke off and the spring shot 20 yards out from under my car. I am very lucky it didn't hit my eye, because I got lasik 6 months ago and any force on my eye can tear the flap that exists on top.
Anyways, I'm calling nameless tomorrow. I feel that they owe me not only a new front pipe that will actually seal but also a new spring bolt that broke from over tightening while trying to install their defective exhaust.
gonzo is offline   Reply With Quote
Old 10-21-2012, 01:59 PM   #649
gonzo
Drives: frs
Old 10-21-2012, 02:03 PM   #650
gonzo
Drives: frs
That gap would not close no matter how hard I tightened the bolts.
Extremely disappointed with the build quality of the exhaust. These amazing welds people are talking about were mediocre at a few joints. My front pipe would NOT fit no matter what. And now people are having alignment problems with the tip. Nameless should take their time with this exhaust. I expect a perfect exhaust if I'm paying over 1k....
Old 10-21-2012, 02:04 PM   #651
gonzo
Drives: frs
I'll let you guys know what happens on Monday or Tuesday
Old 10-21-2012, 02:11 PM   #652
2pt5RS
Berz
Did you put the donut gasket from the OEM cat on the HFC? It doesn't look like it in the pics.
It looks just like this
and slides/fits over this:
2pt5RS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2pt5RS For This Useful Post:
gonzo (10-21-2012), QFry (10-21-2012)
Old 10-21-2012, 02:16 PM   #653
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
If something isn't right, you shouldn't try to force it. That will save you a lot of grief for future mechanical work. It is easier to take the time to figure out what is wrong instead of trying to fix what you just broke/bent/stripped/messed up. >< Also Dude, get some safety glasses and wear them! Protect those eyes! I'm glad you didn't hurt them.
HotLava FRS MT
Neziah is offline   Reply With Quote
The Following User Says Thank You to Neziah For This Useful Post:
gonzo (10-21-2012)
Old 10-21-2012, 02:23 PM   #654
Zaneman
Drives: 2013 BRZ limited
Originally Posted by 2pt5RS View Post
There is no gasket in between those pipes so of course it won't seal correctly. Its not a V band.
Zaneman is offline   Reply With Quote
Old 10-21-2012, 02:24 PM   #655
2pt5RS
Berz
Actually, there is. I put my front pipe in on Wednesday and didn't put that gasket in. I had the same results he did until I realized I didn't put this donut gasket back. Dropped the pipe and put it in and the issue went away.
Unless you're agreeing with me.
Old 10-21-2012, 02:26 PM   #656
QFry
QFry's Avatar
Drives: '13 Argento FR-S
its a completely adjustable exhaust (no matter what exhaust you get)...if you loosened every single mounting point and every joint, installed the correct gasket and tightened that particular unit then it should seal. If you did all of that and it still wont seal then yes call Jason and John at Nameless they WILL help you out, but pics of mediocre welds please...
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 10-21-2012, 02:37 PM   #657
Zaneman
Yes I was saying in his picture there was not a gasket, not that there should not be one.
The Following User Says Thank You to Zaneman For This Useful Post:
2pt5RS (10-21-2012)
Old 10-21-2012, 02:37 PM   #658
xwd
Welds are welds, as long as it's not going to crack it's sitting under the car...
But yeah looks like you forgot to re-use the donut gasket, was a common issue on the WRX catbacks as well. The Perrin catback does not re-use the donut gasket but it's made not to.
Also make sure that's the first joint you try to tighten and not the last.
BRZ performance driving demo - looks great Oriental Life BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-11-2012 02:20 AM
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
Performance automatics madfast Engine, Exhaust, Transmission 118 08-25-2011 03:26 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
