Old 10-01-2012, 05:08 PM   #155
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Boss car there Draco. Good look
Now you have to update your avatar to reflect your new bulbs
The Following User Says Thank You to SkAsphalt For This Useful Post:
Draco-REX (10-01-2012)
Old 10-10-2012, 04:27 AM   #156
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Nicely modded car. Form over function while still remaining 'aesthetic'.. quite like that. Have you thought about changing the front wheel indicators to clear or leave them as-is(if its illegal)?
Also whats up with the crescent moon on the bin? lol
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Draco-REX (10-10-2012)
Old 10-10-2012, 05:03 AM   #157
serialk11r
Drives: '06 AM V8V Coupe
Wow dude, that rear shot you have is amazing. The spoiler looks amazing from an aesthetic standpoint, it flows perfectly with the pillars and trunk. I think the way the car is from the factory the rear window is lacking a bit of natural horizontal taper (which also isn't ideal for aero), but the spoiler you have there gives the illusion of a very aesthetically pleasing side taper on the rear window even though it's not actually there. From the side, the way it pokes out slightly from the back gives it a super race-car like look but it still looks OEM.
I do think they could've flattened the angle a tiny bit and then made it a fraction of an inch longer to hang a little closer to the bumper lengthwise (from front to rear of the car) but that's just me (I'm a fan of how midenginge cars with no trunk have a less chunky rear end due to a more integrated bumper, and longer trunk lips tend to give a more unified look IMO). Otherwise, it's perfect.
The Following User Says Thank You to serialk11r For This Useful Post:
Old 10-10-2012, 11:55 AM   #158
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
it's looking good man.
VSGTS14 is offline   Reply With Quote
The Following User Says Thank You to VSGTS14 For This Useful Post:
Old 10-10-2012, 12:52 PM   #159
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Car's looking great! Giving me some ideas, for sure. Keep it up!
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
Old 10-10-2012, 03:07 PM   #160
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Function over Form, you mean?
I have the side markers tinted. I'm ok with how they look for now and don't see a need to shell out for clear markers.
As for the moon, that bin is for doggy-droppings. So I guess they were trying to emulate the classic outhouse moon.
Old 10-10-2012, 03:19 PM   #161
stevo_12v
LOL.. I stuffed up there
Old 10-14-2012, 02:51 PM   #162
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
Probably my favorite BRZ build here so far. Clean with subtle mods. Exactly how I would do mine.
How many inches do the RCE Yellows drop the car? and what is the Starter Kit? I wonder how it compares to Eibach springs
itisthumper is offline   Reply With Quote
Old 10-21-2012, 08:10 AM   #163
Draco-REX
Corner Junkie
Draco-REX's Avatar
Sorry I didn't see this earlier.
The RCE Yellows drop the car 20mm all around. The starter kit also comes with Whiteline Com-C front strut mounts, crash bolts, and Whiteline rear camber bushings. The Com-C mounts locate the top of the struts inwards for more negative camber (better for mid-corner grip) and back for more caster (give a touch more steering weight and centering.) The crash bolts replace the upper bolts connecting the knuckle to the strut which allows you to get even more negative camber in the front. Both the mounts and bolts let me get -2 degrees of camber. The rear camber bushings replace the inboard bushings of the rear upper control arm. They let you dial in more negative camber in the rear.
The strut mount and crash bolts are excellent. The camber bushings are a pain to install and are kind of fiddly to adjust. I think it would be a better idea to go with adjustable lower control arms and/or the powerflex camber bushings.
Old 10-21-2012, 10:35 AM   #164
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
So do you have no issues with the Com-C's using the OEM struts and RCE yellows? I think the welded flat washer in the OEM upper spring perches is causing the bearings to bind up and cause the rubber to deform when turning. Did you use a conical washer in between the spring perch and Com-C? I believe there is also a lack of clearance between the two because of the negative camber added, which was causing them to collide over bumps and make loud rattling noises. My upper spring perches had marks on them from where they were hitting the Com-C's before I switched back to the stock top mounts and had no issues. I could also watch the rubber deform around the bearing when turning the wheel. The Com-C's had notchy bearings when I removed them, but I'm not convinced that the bearings were bad to begin with. I think the lack of a conical washer and the negative camber was putting the welded flat washer in a bad position and there wasn't proper contact with the inner bearing.
I have a new set of Com-C's from Whiteline and I'm hesitant to install them because neither Whiteline nor RCE seem willing to step up and solve the problem that everyone is having with this combination of parts.
Old 10-21-2012, 11:19 AM   #165
Draco-REX
Corner Junkie
Draco-REX's Avatar
Mine are a straight forward install. Stock upper perches, no extra washers, max camber of -2.0, no popping or other noises. They could be stock for how quiet they are.
I believe WL had a bad batch of bearings go through and/or people were using impacts and over-torquing the top nut. The whole install can be done with hand tools.
Old 10-21-2012, 12:07 PM   #166
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
beautiful br-z, well done draco
Jesse is offline   Reply With Quote
The Following User Says Thank You to Jesse For This Useful Post:
Draco-REX (10-21-2012)
Old 11-24-2012, 10:14 PM   #167
swift996
swift996's Avatar
Very tasteful mods. Have you had any issues with that front lip being too low? I'm looking to do the same once I get my car in.
Also - Thanks for the great amount of detail on all your mods. Get's me real excited for my build.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Draco-REX (11-25-2012)
Old 11-25-2012, 12:10 PM   #168
Draco-REX
Corner Junkie
Draco-REX's Avatar
With care, it's fine. The shark-nosed shape of the front means you get much more clearance if you approach at an angle. But I've gone over speed bumps without scraping.
The only time I've had a serious scrape is when I left a parking lot a little too quickly. The suspension compressed which let the lip scrape. If I had been thinking and left more conservatively, I wouldn't have scraped.
Now, I know some areas have much greater transitions between driveways and main roads than OH here, so you'l have to make your own decision. If you haven't seen the thread with my test fit pictures, this is the clearance you have to work with:
The Following User Says Thank You to Draco-REX For This Useful Post:
swift996 (11-25-2012)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
