Old 10-20-2012, 04:09 PM   #3053
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by Mr.Jay View Post
maybe I'll flash back to stock and fill out the forum. I also got a Canadian cluster so I have to get the update for that too.
If you decide to flash back to stock, let's us know it goes. You'll be doing it from home this time ?
2URGSE
JPxM0Dz is offline
Old 10-20-2012, 04:15 PM   #3054
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I'm never flashing anywhere else haha. I like the tune the car feels way better just the high idle freaked me out a bit. bogging I'm hoping was a one time thing maybe ecu still learning or something cause I can replicate it so far.
Out of the FRS game
Mr.Jay is offline
Old 10-20-2012, 04:23 PM   #3055
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
The high idle drops down for me after it's warm. Yeah not happy about being back on stock file, tune is much more exciting
Pretty cool mornings around here lately, long range forcast into next week shows lows of -17 celcius
2URGSE
JPxM0Dz is offline
Old 10-20-2012, 05:47 PM   #3056
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I know people have discussed this i dont know where in the thread but mushy gas pedal? Will it go away or did i not let it idle long enough and messed it up
Lee358 is offline
Old 10-20-2012, 06:00 PM   #3057
Lee358
Lee358's Avatar
Double post
Lee358 is offline
Old 10-20-2012, 06:39 PM   #3058
Calum
That Guy
Drives: 2013 asphalt FRS MT
It goes away. It takes a day or so, for me anyway, after I flash the car then I can start to feel things get better. Then they get REALLY good and then taper back a bit. I'd say its just the learning curve of the ECU.
Calum is offline
Old 10-20-2012, 07:06 PM   #3059
Foobar
SLO NO MO
Foobar's Avatar
Still in learning mode - drive it around some more.
Foobar is offline
Old 10-20-2012, 07:08 PM   #3060
Foobar
SLO NO MO
Foobar's Avatar
Here's the test to see if it bogs without a proper intake tune:
Start out in first going about 5 MPH (basically coasting), then jam on the gas - floor the sucker. If it smoothly accelerates all the way through the tach, then you're good to go.
If it starts to sputter and bog like it's running out of fuel or air, congrats, you've got an aftermarket intake that needs additional ECUTek tweaking. Capture some logs of some 2000-7000 pulls, send it in to John, get a tweaked file, reflash it, retry the test.
Foobar is offline
Old 10-20-2012, 07:14 PM   #3061
boris
Drives: 2013 white scion frs
sorry for a noob question, but how do you switch maps?? because i have done so far is flashing the ecu with the rom i got from john. thanks.
boris is offline
Old 10-20-2012, 07:16 PM   #3062
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
pull the cruise control lever towards you until the rpm goes to 1k afterwards switch between maps via lever up or down rpm will move from 1k thru 4k letting you know which map you are on
I tried this and it didn't bog but on my way back from grabbing some paint it did it as I was coming up a hill. Very very random. I may just remove my intake and switch back to stock given that I will most likely go turbo in the future if not I will log some data and send it John's way
Out of the FRS game
Mr.Jay is offline
Old 10-20-2012, 07:19 PM   #3063
Foobar
SLO NO MO
Foobar's Avatar
If it seems erratic, the ECU might still be learning - how many miles have you put on it since flashing?
Foobar is offline
Old 10-20-2012, 07:21 PM   #3064
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
about 28km so almost nothing so far. weather been pretty bad here but I do plan to go for a nice long drive tonight so hopefully it is just the ecu still learning
Out of the FRS game
Mr.Jay is offline
Old 10-20-2012, 07:48 PM   #3065
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thumbs up Great Googly Moogly
John
The newest Automatic Transmission Tune is fantastic!
It pulls so much harder than the previous tune.
The stock intake works perfectly.
The idle is smooth as silk, any throttle input is instantaneous.
Torque hump, other than 1st gear, what torque hump? It's gone.
The laying over at 6200-6300 rpm is nonexistent since returning to stock intake.
Boy did I make a mistake buying an Airaid,
They should rename it Airdoesnotaid above 6200rpm
After flash I always allow 10 minutes of idle, never had an issue with a mushy pedal.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 10-20-2012, 08:06 PM   #3066
jpit
Drives: Subaru BRZ
Doesn't John have to give us a thirty day notice before he takes off for four hours?
jpit is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
