#99 |
Drives: Whiteout FR-S
I can twait to see the dyno graph on this baby! I'm sure well see some of this shortly after SEMA.
#100 | |
Drives: Vortech Supercharged M6 FR-S UM
#101 |
Drives: subatoy
I would expect this set up to be cheaper than AVO's turbo kit cuz there isn't a manifold which should drive cost down significantly but of course this is never the case.
#102 |
Drives: 2013 Whiteout FR-S
What are the numbers on this supercharger?
| The Following User Says Thank You to SalM For This Useful Post: | cobrabyte (10-18-2012) |
#103 |
Drives: 13 whiteout scion frs
omg that is beautiful.. just what im looking for not to much not to little but just perfect !!!!
#104 |
None of the Vortech kits on other companies cars at SEMA have been tuned from what i have heard so i wouldn't expect any numbers until after unless Vortech releases them.
#105 |
Drives: Nevermorange FRS
This is the ONLY thing I've seen on this entire forum I've wanted enough to sacrifice the warranty for.
#106 |
Vortech V-3 H67 Self-Lubricated Supercharger with Billet Impeller – An all new compressor stage designed specifically for the FA20 Boxer engine
Vortech Maxflow Air-to-Air Charge Cooler Integrated oversized MAF housing Mandrel Bent Aluminum Charge Ducting Billet Aluminum Mounting Bracket Assembly Rotomolded Intake Airbox with conical filter utilizing factory cold air draw-through point Compressor Bypass Valve Premium Silicone Sleeves Stainless Steel Clamps |
| The Following 3 Users Say Thank You to gmookher For This Useful Post: |
#107 |
#108 |
funny guy...
oversized allows for more flo rate faster, will beat any and all hunduhs because race car |
#109 |
I do try.
I ask about the larger tube (I understand flow rate) because it is my understanding the factory ECU tune is determinate on the MAF being in a tube a of a specific dimension. If you change the dimension of the tube, the ECU gets an inaccurate reading of the flow of air. So how would this change in diameter of tubing where the MAF is located not require a tune on the ECU? If does, then that's ok too. I'm just wrapping my head around what's all entailed with installation of this kit. |
#110 | |
#111 |
Drives: Toyota GT86
What's the tuning solution for the kit? FMU with an R4 software?
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr) |
#112 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| Supercharger or Turbo ? | #87 | Forced Induction | 192 | 01-25-2013 10:20 AM |
| HKS Supercharger getting closer | gtauto | AUSTRALIA | 166 | 09-03-2012 07:11 PM |
| TRD Supercharger anyone?? | poormans_LFA | Engine, Exhaust, Transmission | 48 | 04-27-2012 11:42 PM |
| Supercharger for Infiniti G25 | Lottta | Other Vehicles & General Automotive Discussions | 2 | 02-12-2012 09:10 PM |
