Old 10-20-2012, 12:28 AM   #15
frosty86
frosty86's Avatar
Drives: '13 FR-S (Whiteout) Manual
It seems that this car's transmission is sensitive to elevation and angle too... Stop & go on a slope, this car loves to make sounds like its gargling glass.
frosty86 is offline   Reply With Quote
Old 10-20-2012, 12:40 AM   #16
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Originally Posted by brufleth View Post
My WRX is bitchy when it first starts in the cold. Hard to shift and runs rough until it warms up. Could be a Subaru thing. Never had that happen with a Honda.
Same thing here, my wrx also got 15 mpg ave. during the cold months Lets hope this one's better when its 0 to -20 c
By the way, ALL the cars I hard when started at -20 sounded like complete shit, screeched and almost didn't wanna crank..I guess the fr-s will be the same, but worst
Rayme is offline   Reply With Quote
Old 10-20-2012, 02:46 AM   #17
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Cold air = more oxygen per square inch. NA motors LOVE cold weather, denser air means a ton more oxygen going in to the engine, as a result, more gas could be put in as well.
Someone mentioned skipping gears on the upshift? Don't. do not skip gears upshifting. Downshifting is fine, but not upshifting.
You should see rotary engines in the cold, would rev to 4k rpm's till warm, dump fuel and oil until it warms up. Was quite the spectacle
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 10-20-2012, 02:47 AM   #18
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by DBacon1052 View Post
Has anyone else had the tire pressure warning come on?
I run the tires @ 40 in the winter because of the tpms.
Spartan65 is offline   Reply With Quote
Old 10-20-2012, 11:14 AM   #19
SVThis
SVThis's Avatar
Drives: Scion FRS
Keep in mind that you lose about 1PSI for every 10 degree drop in temperatue. If you set your pressures when it was 90 degrees out and the temperature drops to 30, you've lost 6 PSI. Guess what, your TPMS light will activate.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 10-20-2012, 11:26 AM   #20
FirestormFRS
Originally Posted by HuntingtonFRS View Post
FirestormFRS you are in the Huntington, WV area? WHats your name>?
I live in Bville
FirestormFRS is offline   Reply With Quote
Old 10-20-2012, 01:05 PM   #21
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Why? The tire inflation pressure listed on the door jamb is the cold inflation pressure. Just fill the tires to the recommended setting when the tires are cold and you won't ever see the light.
Subie is offline   Reply With Quote
Old 10-20-2012, 02:08 PM   #22
Spartan65
Spartan65's Avatar
Bad habit from being in the Tire industry, tire pressure will change along with ambient temperature. Each 10 degree F change in temperature will change tire pressure by about 1 psi (pound per square inch). The pressure follows either up or down. Where I live we may have winter days in the Sixties, but night near freezing. 40psi the ride sucks, hard as hell. But in the morning my TPMS will not be on. until the day warms up.
Old 10-20-2012, 03:01 PM   #23
einzlr
Drives: several
Maybe you need to carry around a portable air compressor
We have similar day/night air temps in my area but I've never had a car's TPMS complain based solely on that. What's the range to keep the BRZ/FR-S happy? Based on what people are saying, it seems pickier than some other cars.
einzlr is offline   Reply With Quote
Old 10-20-2012, 03:31 PM   #24
Subie
Señor Member
Subie's Avatar
I don't think it's any pickier. Before my last road-trip I checked my tire pressure and was down 4 PSI on average per tire. The TPMS light had not yet come on; for most people (I say most to account for those living in areas with wide temperature swings from morning to mid-day) it's only good as a dummy light, indicating a punctured tire or a wake-up call to someone who doesn't do his due diligence in checking his tire pressure.
The Following User Says Thank You to Subie For This Useful Post:
einzlr (10-20-2012)
Old 10-20-2012, 04:53 PM   #25
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Mine did, but apparently it was a box cutter blade. So I had to patch up the tire
Asphaltfrs1 is offline   Reply With Quote
Old 10-20-2012, 07:32 PM   #26
TurnOne
Drives: BRZ Ltd. WR Blue 6MT
I am curious as to why you would recommend using every gear every time.
This isn't a sequential gearbox. You can skip gears all day long. More skipping will prolong the life of the clutch and generally prevent wear and tear.
More HP and more gears = more opportunity to skip gears.
Only thing you need to make sure and don't under rev or 'lug' the engine.
TurnOne is offline   Reply With Quote
Old 10-20-2012, 08:14 PM   #27
ScionRacer
ScionRacer's Avatar
Drives: 2013 Scion FR-S Ultramarine
I noticed a rougher when it has sat over the weekend not driven, but as soon the idle comes down it runs fine.
I normally skip shift 1-3-5 in the neighborhood at night,keeps the exhaust note toned down.
ScionRacer is offline   Reply With Quote
Old 10-20-2012, 11:09 PM   #28
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I haven't checked my tire pressure. Partially because they came filled with Nitrogen. It was my understanding that the advantage of Nitrogen is that tire pressure doesn't fluctuate as much as oxygen based on temperature.
Eurasianman is offline   Reply With Quote
wet weather MikesFRS Southern California 1 10-09-2012 02:17 PM
My mom hates import culture? LexusFman Other Vehicles & General Automotive Discussions 31 04-03-2012 11:08 PM
Yeah so, this is pretty badass 7thgear Other Vehicles & General Automotive Discussions 5 01-25-2012 09:54 PM
iRacing looks pretty boss. Guff Off-Topic Lounge [WARNING: NO POLITICS] 6 12-14-2011 11:22 AM
FR-S in inclement weather kounkong23 Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2011 12:16 AM
