Old 10-19-2012, 04:45 PM   #1
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
FRS on studded, upsized iPikes
Went with 215/50/17 Hannook ipikes instead of stock size 215/45 for the extra .42 inches ground clearance, and it fills the wells quite nice. It's .84 inches over total diameter - 3.4% over. Kept the TPMS out - will put them in the new summer wheels and mount the stock tires till they burn off.
I think it looks badass.
Khyron686 is offline   Reply With Quote
The Following User Says Thank You to Khyron686 For This Useful Post:
sajonf (10-19-2012)
Old 10-19-2012, 05:22 PM   #2
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
It does look pretty sweet for a winter setup. You will probably get snow before most of us. I am getting mine put on my stockers next week but probably won't mount them until just before the first snow (live in Missouri). Will leave my aftermarket wheels on until then. I had a 370Z with winters a couple years ago and that thing was a freaking snowmobile - I am sure this one will be even better.
sajonf is offline   Reply With Quote
Old 10-19-2012, 05:30 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
That's nice man! I didn't thought to get a size up for 16" winter tires. I'll post when it's in "winter mode"
Rayme is offline   Reply With Quote
Old 10-20-2012, 10:45 PM   #4
Cyrious G
Pro Tire Killer
Cyrious G's Avatar
Drives: 2013 Scion FRS
That car is gonna chew through the snow!
Cyrious G is offline   Reply With Quote
Old 10-20-2012, 10:59 PM   #5
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Nice setup. I am debating whether I want a dedicated snow tire set or if I want to try and get away with all seasons. My neighborhood is notoriously difficult to get out of when it is snowy.
FWD has spoiled me a bit. I've run summer tires in snowy weather without incident by using ample caution. Something tells me I won't be able to get away with that on the FR-S.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
The Following User Says Thank You to MmmHamSandwich For This Useful Post:
StarsGarrador (10-22-2012)
Old 10-21-2012, 12:20 AM   #6
just86
just86's Avatar
Drives: 2013 genesis rspec
exactly what i want
just86 is offline   Reply With Quote
Old 10-21-2012, 12:39 AM   #7
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
How rough is the ride on those tires?
TTGT is offline   Reply With Quote
Old 10-21-2012, 05:23 PM   #8
Khyron686
It's -3 C , so no snow but no noticable noise on the expressway. You can totally hear it at low speed, like driving on a bit of gravel. Obviously winter tires feel a bit "floaty" or mushy compared to harder summer, but the grip is great. I cannot wait for the snow/ice so I can kick the back around a bit.
Old 10-21-2012, 05:57 PM   #9
tawheed
Drives: '13 Sport Tech
My studded tires should be here in a couple of days. First time I've had studded winters, a little concerned about the noise but hopefully it won't be too bad. Wonder what winter in Alberta will bring this year, if it's like last year I'm worried the studs will go to waste!
tawheed is offline   Reply With Quote
Old 10-21-2012, 08:10 PM   #10
Foobar
SLO NO MO
Foobar's Avatar
Looks good! But isn't it .21 inches of additional clearance?
Old 10-21-2012, 09:10 PM   #11
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Studded snow tires do grab better on ice but they are extremely noisey. Also, they reduce braking distant and decrease accleration. Just be aware of sudden braking and dont be use to your current braking distant.
VietnamPhenom is offline   Reply With Quote
Old 10-21-2012, 09:13 PM   #12
White64Goat
After owning a 1989 240SX XE which had a very similar balance ratio as the FR-S & BRZ, I can tell you from experience with the 240 that after about 1/2 inch of snow, you are going nowhere (with stock tires)............believe me.
Old 10-21-2012, 09:19 PM   #13
fenton
I bought nokian hakki 7s this year.
195/55 r16. Can't wait but should be interesting in comparison to 2011 sti on winters I had last year
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline   Reply With Quote
Old 10-21-2012, 09:24 PM   #14
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by just86 View Post
exactly what i want
IL allows studded tires? Don't think so.
