Old 10-19-2012, 10:53 AM   #15
ExWhyZer0
ExWhyZer0's Avatar
Drives: Whiteout FR-S M/T
I filled up with Shell 93 the other day. For some reason, when I filled up on 91 Kroger gas, it felt like my car ran better o.0
ExWhyZer0 is offline   Reply With Quote
Old 10-19-2012, 11:03 AM   #16
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
I don't think it has anything to do with the fact the type of fuel system on the car, more that we have high compression and the ECU is going to tweak everything down to prevent detonation when you get low quality fuel.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 10-19-2012, 11:20 AM   #17
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I've been having luck so far with the gas from Petro-Canada, I received 350 $ of gas card from my dealer so I kind have to go there…will probably still go there after just to be sure!
Rayme is offline   Reply With Quote
Old 10-19-2012, 04:41 PM   #18
ScionRacer
ScionRacer's Avatar
Drives: 2013 Scion FR-S Ultramarine
Unfortunately sunoco stopped selling their 94 around here years ago.I can sometimes find 93 and there is always 92, but i have noticed that different tanks of fuel do have an effect on how the engine performs.
i have had good luck with Sunoco 93 and marathon 93.Sheetz,Speedway and True north/BP have had negative effects on drive ability for me.
As a rule of thumb regardless of timing,i have always went by compression ratio
naturally aspirated engines 10.5.1 up to 11.5.1 minimum 93
naturally aspirated engines 9.0.1 to 10.5.1 minimum of 91
naturally aspirated engines 7.5.1 to 8.5.1 minimum of 87
I would run nothing but 94 on my FRS if it was available around here.
ScionRacer is offline   Reply With Quote
Old 10-19-2012, 04:52 PM   #19
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Running sunoco 93 and no problems.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-19-2012, 06:21 PM   #20
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Direct Injection in general is very fuel sensitive. If I put shitty fuel in my MKV GTI (which was DI) it would throw a CEL.
Old 10-20-2012, 09:25 AM   #21
FRiSson
Drives: FR-S MT
These rules are not universally applicable anymore. The wider use of direct injection along with computerized modeling of the combustion chamber has made engines far more resistant to knock. The Mazda Skyactiv is an engine with a 12:5 compression ratio that runs on regular gas.
FRiSson is offline   Reply With Quote
Old 10-20-2012, 09:37 AM   #22
FRiSson
Drives: FR-S MT
Petro-Canada is a Top-Tier supplier.
Old 10-20-2012, 10:19 AM   #23
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
All gasoline is produced to same standards and is no different for station to station. I work at a refinery trust me.
TTGT is offline   Reply With Quote
Old 10-20-2012, 10:44 AM   #24
DeeezNuuuts83
Drives: 2006 Evo IX SE
If your area has nice cars, see if you can notice a trend of them being at certain stations. For example, the one I go to will usually have a Ferrari, Lamborghini, Porsche, Lotus, etc. there every other time I fill up. That is typically a good sign, especially if they're gear heads (which you can find out if you strike up a conversation with them).
DeeezNuuuts83 is offline   Reply With Quote
The Following User Says Thank You to DeeezNuuuts83 For This Useful Post:
makesdrivingfunagain (02-22-2014)
Old 10-20-2012, 10:52 AM   #25
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
But don't the individual gas stations place their own additives and detergents to the gas? Shell will tell you in their commercials that they have better gas because of what they've added to it.
Nevermore is offline   Reply With Quote
Old 10-20-2012, 12:19 PM   #26
TTGT
TTGT's Avatar
They all have their own additives that the truckers add to fuel gas mix when loading trucks, but they are all basically the same detregents. we supply shell,and a bunch of others.. cant remember off top of head. I think it is crazy for them to advertise gas is better from on place to another after seeing the process first hand.lol
Old 10-20-2012, 12:20 PM   #27
TTGT
TTGT's Avatar
Dont get me wrong not saying every gas station is equal, cause they are not. but the gas they are sold is all the same.
Old 10-20-2012, 01:32 PM   #28
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
So is the cash only gas station in the less wealthy part of town that has pretty cheap gas the same as the exon on the local highway?
Lee358 is offline   Reply With Quote
