Old 10-17-2012, 10:16 PM   #15
einzlr
Drives: several
Also bring plenty of water and *remember* to drink it. In the excitement it's easy to get dehydrated without noticing and you just feel dizzy and tired. Also, as others have hinted at, leave your ego at home. Instructors have told me that they like instructing women because we're more receptive to learning and don't need to prove anything
einzlr is offline   Reply With Quote
Old 10-18-2012, 12:39 AM   #16
CSG Mike
CSG Mike's Avatar
Put in some good brake fluid (any DOT4 fluid is a good starting point, and won't cost you more than $35 for entry level stuff).
If you're 100% sure you'll do this again, invest in some pads. Otherwise, go with the stock pads, but when your brake pedal stops responding, back off the brake pads, because they're faded and you don't want to keep heating them up; they'll just melt away.
Take lots of water. Drink a full bottle between each session, if not more. Also take some sport drinks with electrolytes, and sip throughout the day.
Try to get paired up with an instructor that is familiar or drives a momentum car. They'll be able to best guide you through a style of driving suited to the FRS/BRZ.
Old 10-18-2012, 01:56 PM   #17
xyr03
Drives: Scion FRS
I think I'm going to keep every as is for now and get a good feel for the car. Do you guys they my breaks are gonna be gone by the time I'm done with track day? I do need the car to come back hom. lol
xyr03 is offline   Reply With Quote
Old 10-18-2012, 02:01 PM   #18
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by rice_classic View Post
Famous saying used by instructors to their students: "Don't try to impress me and don't try and scare me because nothing you can do will impress me and I'm already scared."
Bravo!!!
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-18-2012, 02:15 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The advice above is terrific, nothing really new needs to be said except for... Good luck managing your new addiction.
Too bad you are so far away, we could use you as in Instructor for ITR Expo, then you could see Christian's "god chariot" in person if he ever shows up
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2012, 02:16 PM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Personally I wouldn't attempt using stock pads and fluid unless you have real pads and fluid with you and are just being lazy (like I was at Mid Ohio).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2012, 08:11 PM   #21
CSG Mike
CSG Mike's Avatar
Putting in good brake fluid won't change how the car feels; it'll only prevent the feel from deteriorating.
Changing to race pads will affect how quickly the brakes ramp up in stopping power (the same amount of pedal input will make the car brake harder), but it won't change the ultimate grip level of the tires, or how quickly you brake if you're using ABS.
The brake fluid and pads are ultimately there to prevent the car's performance from degrading as you heat them up, rather than to make you faster. Also, we want to make sure you get home safely
Old 10-19-2012, 01:37 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The OEM brake pads and brake fluid are not intended for the heat and abuse that a single 20 minute session can put them through at most track days. Now your options are to break early and not get into ABS to try and protect them, or you can upgrade the pads and fluid and work on maximizing your brakes without having to worry about not finishing the session because your pedal goes to the floor.
Old 10-19-2012, 01:50 PM   #23
gmookher
camber bolts, brake pads, fluid, and tires at a minimum before tracking
Old 10-25-2012, 03:23 PM   #24
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Some great info in this thread, I'm keeping my eyes open for something like this here in Southern California (probably only Willow Springs, right?).
For first-timers, do you guys suggest a dedicated pad or just something that can serve double duty? I keep hearing that either RC5+ ($$) or DS2500 are good street/light track pads. My thinking is to minimize the extra work needed to go out and have fun. I don't want it to be a chore.
Also, any thoughts on Pyrotect helmets? Import Image Racing has full-face for $255, which seems like a great deal if they're a decent helmet (SA2010).
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 10-25-2012, 03:30 PM   #25
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
The car should be fine in stock form if you've never been to a track before. The car is new enough that your brake fluid should be fine. You're not gods gift to driving...maybe you are, who knows - but when you're first starting out, the car literally needs nothing.
I track rental cars all the time - never had an issue, even at an advanced level.
GTM_Challenge is offline   Reply With Quote
Old 10-25-2012, 03:59 PM   #26
diirk
diirk's Avatar
Drives: 4Runner
What ^^^ said.
I ran my car totally stock on the track a few weeks ago. It did just fine. No brake fade, minimal tire wear, handling was reasonable. I think for the first few trips to the track, running stock is a great way to learn the car. Bring a decent tire guage and call it a day. Check your temps cold then hot. If you're getting over 40psi hot, drop it a pound or two. 38psi hot seemed to work well for me on stock tires on a road course.
Pyrotech makes a good helmet. No worries there.
and as a disclaimer: this isn't my first rodeo. I've run a few events before in a variety of cars. The most important thing to prep for the track is yourself. Go there and learn.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-25-2012, 04:56 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I disagree on the fluid. Novices tend to drag brakes instead of getting on them hard and then getting off them. I've seen far more novices boil the heck out of fluid than I've seen advanced drivers do it.
More or less agree on the rest, I'd still do pads too though. Doesn't hurt.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-25-2012, 04:58 PM   #28
gmookher
for whatever reason, the factory filled fluids on this thing are pretty el cheapo feeling
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 01:05 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Louie Southern California 1 03-10-2012 01:31 AM
