Old 10-17-2012, 01:00 AM   #2661
cruzinbill
Drives: Argento 6spd FR-S
Well I messed with it more today, all the features do work I just didnt know what I was doing. To check/set LC you hold it all the way to the floor and it will bounce off what its set too. then you use the cruise to adjust up or down.
FFS is the same it only works if you have it all the way to the floor.
I still dont get some stuff. like why if I have it on map 3 i think, and I have it set to outside temp, my gas gauge goes to empty.
So, It would be nice to have a list of what the different stuff is.
cruzinbill is offline
The Following User Says Thank You to cruzinbill For This Useful Post:
JPxM0Dz (10-17-2012)
Old 10-17-2012, 01:24 AM   #2662
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Yeah I messed around with it also switching between maps, however I did not see any info anywhere on the display for remaining fuel or other info depending on what map your running ??
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline
Old 10-17-2012, 01:59 AM   #2663
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Lightbulb
D'oh!
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline
Old 10-17-2012, 02:06 AM   #2664
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
I had the same issue, the tank went back up when i filled the tank, but i dont know if its fixed or just stuck at full. Will know when i go home tonight.
LeavingNormal is offline
Old 10-17-2012, 02:08 AM   #2665
Genomaxter
Drives: 2013 firestorm FRS
I think the tune is great overall after using it for a day, but I do have one issue. Below 1.6k rpms the engine studders a good bit and it sounds like it can't decide to use direct injection or not. This gets very noticeable in traffic. I'm hoping it can learn its way through it, but it's not as good as stock was in that range..
Genomaxter is offline
The Following User Says Thank You to Genomaxter For This Useful Post:
xjohnx (10-17-2012)
Old 10-17-2012, 02:17 AM   #2666
cruzinbill
see if it works normal tho if you set it to mpg, not the avg one but the "live feed" one. I believe then the gas gauge works normal and it is displaying the ATF ration in the readout below.
I could be wrong, but seems to me thats what it is, and this is on map 3
Old 10-17-2012, 02:45 AM   #2667
LeavingNormal
FRS2DTH
Thumbs up
Ok map 3 on MPG, I will check and report back.
Old 10-17-2012, 03:49 AM   #2668
Visconti
Drives: 05 STi
Map 1 - Fuel Tank %
Map 2 - A/F Ratio + Flat Foot Shifting, Launch Control, AutoBlip
Map 3 - 0-60 Timer + Flat Foot Shifting, Launch Control, AutoBlip
Map 4 - 1/4 Timer + Flat Foot Shifting, Launch Control, AutoBlip
Seems like the fuel gauge is getting pissed off at the 0-60 & 1/4 timer.
Switch out of map 3/4 after doing your run.
Ill have more updates / info tomorrow
John
Visconti is offline
The Following 4 Users Say Thank You to Visconti For This Useful Post:
cruzinbill (10-17-2012), JPxM0Dz (10-17-2012), LeavingNormal (10-17-2012), Subynewbie (10-17-2012)
Old 10-17-2012, 07:54 AM   #2669
LeavingNormal
FRS2DTH
Thumbs up
Ok so obviously the list that Visconti posted was right. #1 is fuel tank percentage, its a bit jumpy but its definitely reading out a constant percentage. But my actual fuel gauge is stuck at full now instead of empty. usually after a day of driving to and from work ill be down a quarter tank, visually at least according to the percentage i have 84% left which sounds about right if you factor in how wrong the needle is.
I'll fill out a form for ya when i get a chance here John, thanks for the list too, helps me make sense of the numbers now.
Old 10-17-2012, 09:06 AM   #2670
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
My maps are different I guess
Map1 AFR and if the ac is on the rpms jump back and forth from 800-1200 when I'm at idle
Map2 something like 0-60
Map3 I think is 1/4 mile time and my gas gauge drops to empty
Map4 I have no idea
I haven't been messing with it much except when John was having me test. I am waiting to get the tune that will put me on the same page as the others.
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline
Old 10-17-2012, 09:53 AM   #2671
KamalT
Drives: Pearl 86 GT
Waiting patiently for my tune...
White GT | Visconti_TUNED
KamalT is offline
Old 10-17-2012, 12:04 PM   #2672
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
John, do I need to fill out the new form if I have not yet received a tune file?
I have filled out previous forms.
Thanks.
SkAsphalt is offline
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 10-17-2012, 12:24 PM   #2673
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Woooooo got my new tune. Now I just have to fight the urge to leave work...
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
Old 10-17-2012, 12:29 PM   #2674
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Map4 I have no idea
So you have the latest tune with different map locations ?
2URGSE
JPxM0Dz is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
