Old 10-15-2012, 07:16 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Tapping my oil feed
So i ve been looking at my engine for quite some time now with the turbo sitting there. I ve been thinking about hooking up my oil feed line to my pressure switch right below the oil filter. After looking at every kit on the market it seems like they are all feeding from a different location except for Treadstone. So, should i just go off from the switch or from somewhere else?
Silverdub is offline   Reply With Quote
Old 10-15-2012, 09:41 PM   #2
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
we run ours off the oil pressure switch hole. Its a 28bksp thread so it will require a 28bksp male to 1/8 npt female with a t fitting so you can still retain the stock oil pressure sending unit. If you are running a external oil pressure gauge then I recommend running a single -3 line off that hole to a distribution block that can be mounted remotely since 2 tees inline hanging from the port would crack off eventually from vibration fatigue. If you dont already have these we have them in either configuration.
The only other way to run the line is if you are running a oil cooler kit as the sandwich adapters usually come with 1 or 2 1/8 npt ports.
Hope this answers your questions.
Dave
ANTI_LAG is offline   Reply With Quote
Old 10-15-2012, 09:48 PM   #3
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Where did you see the treadstone kit ? It not on the site is it?..
RWD-boxer is offline   Reply With Quote
Old 10-16-2012, 06:16 PM   #4
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Dave
Thanks a lot for the info! I just went and got my T fitting and adaptors but it looks like the 1/8npt and 1/8bspt and just about the same i cant even see a difference between them... I just need to order my AN fittings, hose fittings and braided hose from jegs but before i do so, i want to be sure to figure out my coolant hoses as well.
Old 10-16-2012, 06:33 PM   #5
ANTI_LAG
ANTI_LAG's Avatar
Remove the outlet (flow) coolant hose from the throttle body, insert -6 barb to an, run to turbo, then from turbo back to that port in the same manner.
We sell kits just let me know your hose lengths needed and what turbo you have, lines can be stainless or black braid race hose, fittings in red/blue or black.
Old 10-17-2012, 12:17 PM   #6
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Thread count is only 1 tooth off per inch. What is worse is they will start to thread even if its the wrong fitting.
Jeff@Racer X Fab is offline   Reply With Quote
Old 10-17-2012, 12:20 PM   #7
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i was thinking of getting my water feeds from the bottom, the small hose right over the thermostat, i did think about the one unnder the throttle body at first, i have to look at it again and find the best solution for my turbo placement...
Old 10-17-2012, 02:14 PM   #8
treadstone performance
Drives: scion frs
We just got done running all our waterlines and oil lines, give us a call up to help you out with the fittings.
Treadstone Performance
888-789-4586
treadstone performance is offline   Reply With Quote
Old 10-17-2012, 04:15 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
888-789-4586
wow, thats what i call awesome support for a guy thats not even a customer!
Old 10-17-2012, 04:22 PM   #10
Drives: scion frs
LOL, well thats how we make you a customer
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Tapping sound above 70 mph Fugazi BRZ First-Gen (2012+) — General Topics 24 10-20-2015 04:04 AM
Scion FRS and Subaru BRZ FENDER FLARESin the design stages. Need Feed back eight08customs Cosmetic Modification (Interior/Exterior/Lighting) 27 03-16-2014 08:46 AM
Ebisu Live Feed TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 0 08-18-2012 10:44 AM
