Old 10-15-2012, 08:04 PM   #1639
Marrk
Drives: Honda Fit
Originally Posted by @Art_Mighty View Post
My belife is that the tolerances inside the cam gears are actually a little TOO tight for some of them function properly. It goes to this concept of tolerances "stacking up" inside the cam gear (this was mentioned in Toyota's official communication). Inside these things there are basically a bunch of parts. If each one of them is a little on the large side then all of them together won't move too well...
...in a way I really appreciate that this could even be a problem because it means that the engineers who worked on the cam gears are designing the tolerances for ware. As our motors get older these delicate and expensive assemblies will continue to function as intended.
So to your question; the harder the break-in the looser the tolerances become?
Okay. Let's say these lovely, tight tolerances are a good thing. Engines are breaking. Maybe it's too much of a good thing.
How do you figure that "delicate and expensive" is going to improve durability? I'm not following your logic here.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
ftc~brz (10-16-2012)
Old 10-15-2012, 08:16 PM   #1640
JohnS_Rosamond
Drives: Mazda MX5
On the hard break in versus soft:
I was under the impression that the "softer" break in was to save the rings and cylinder bores (more even wear). If you're hard on the engine to "break in" the VVT units, you are by default sacrificing the cylinders. I would rather save the cylinders get the CEL and wait for top end to work itself out.
JohnS_Rosamond is offline   Reply With Quote
The Following 2 Users Say Thank You to JohnS_Rosamond For This Useful Post:
@Art_Mighty (10-15-2012), ftc~brz (10-16-2012)
Old 10-15-2012, 08:18 PM   #1641
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
I'm not saying that "delicate and expensive" improves durability. I am implying that these cam may be engineered in such a fashion where as they ware with age they continue to function normally.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following User Says Thank You to @Art_Mighty For This Useful Post:
Old 10-15-2012, 08:22 PM   #1642
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
AMEN Brother!
That is indeed the problem here with these two different break-in requirements. Crappy cam gears now or engine rebuilds later?
Old 10-15-2012, 08:43 PM   #1643
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
I don't think it's a big deal for the rings or cylinder bores. Engines can be broken in within a couple of hours on a dyno, and not suffer any reliability problems. It goes on all the time. You have to remember that you're breaking in everything on the car. Brakes, clutch, tires, struts, transmission, diff, chassis etc..
Just as an example, a new clutch can come with a 500 mile break in.
TheRipler is offline   Reply With Quote
Old 10-15-2012, 08:59 PM   #1644
eurospeed
Originally Posted by darnbry View Post
I'm having the same issues as everyone cel and sl light on plus the shaking of engine and misfire while in idle mode. My question is has anyone got any compensation for this ? And how did you get it?
You need to call Scion corporate and start a case with them. Also, at what mileage did your CEL occur and what are the last four of your VIN (use XX for last two). Thanks.
eurospeed is offline   Reply With Quote
Old 10-15-2012, 09:08 PM   #1645
eurospeed
Originally Posted by ap5512 View Post
Now, the confusion I have is...is the TSB for Subaru which replaces the HPFP going to fix the CEL/SL issue? I've read horror stories about CAM sprockets being replaced and other major mechanical repairs being done. I almost feel like they cleared the CEL so I won't find out the true issue and they are going to do the TSB which I think only fixes the chirping noise OR they aren't that knowledgeable about the issues facing our cars. Am I missing something here and what do you guys think I should do??? Hopefully you guys can help me clear up some of this confusion..thanks.
The HPFP noise and the CEL/idle issue are two distinctly different problems. A TSB only exists for the HPFP noise and not the CEL/idle issue. Regarding cam sprockets, the horror stories are real sometimes requiring multiple component replacements and even leading to engine failure in some instances. This has not been, by any stretch, a pleasant experience for most of us affected.
The Following 2 Users Say Thank You to eurospeed For This Useful Post:
ap5512 (10-16-2012), ftc~brz (10-16-2012)
Old 10-15-2012, 11:04 PM   #1646
Marrk
Drives: Honda Fit
You have that backwards. A hard break-in is to seat the rings — a good thing. The cylinder bores are, in fact, imprinted with a hatch-mark pattern so that they are "rough" when new. The idea is that the slightly over-sized new rings will wear against the rough cylinder walls and seat against them. The roughness of the bores actually gets smooth very quickly. Some people say the entire process is over in the first twenty miles.
With a "rough" break-in, you are using compression to force the rings against the rough cylinder walls.
Old 10-15-2012, 11:24 PM   #1647
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Don't know if it's true or not, correct me if I'm wrong. I've also heard that cars that are driven long periods of time at lower RPMs can develop a lip near the top of the stroke, and if the car is driven hard after this lip develops it can damage the rings as the higher RPMs cause the pistons and rods to push out further than they normally would at the lower RPMs.
Cade01 is offline   Reply With Quote
Old 10-15-2012, 11:27 PM   #1648
CMOS
Drives: 2012 FUJI Z
At the minimum of 10hz those things should have been mated by the time the factory finished on the dyno. I'm more worried about the chunks of metal in the oil having sufficient time to be blown away rather then trapped in between.
CMOS is offline   Reply With Quote
Old 10-15-2012, 11:55 PM   #1649
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
Originally Posted by FRSowner View Post
Has anyone done an average mileage of when the CEL issue hits? I've been following this thread with dread as my FR-S is right in the middle of the affected VIN's. I'm at about 2200 miles and so far, everything's been cool.
See my post #1209 this thred.
86BRZ is offline   Reply With Quote
Old 10-16-2012, 01:18 AM   #1650
kaitak98
Drives: '13 GBS BRZ
My problem is that I really haven't had the idle issue. Only the CEL and SL. The car seems to run a little rough and be down a bit on power but it is a small enough that I question whether I'm imagining it. But it idles rock solid at 650 only blipping a bit if the ac comes on.
The problem came up 3 starts after the dealer had the intake off to check the cricket issue. When I went back they rechecked all the work and cleared the code. It was back 3 starts later. The timing makes me think it has to be an electronic issue but the more I read the more I don't know. Reading that the reflash could just be masking a real cam issue... I'm not sure what to think.
Depending on how long it takes to fix this problem and with the GPS and the crickets I'm thinking of asking for the extended warranty to be compped. If they have faith in the product all it will cost them is their share of the profit on the extended coverage.
Any thought on the CEL/SL with no idle drop?
To add info to my line in the OP....
BRZ Limited MT 2200 miles 6028xx Going in to be seen by factory rep 10/17. Atlanta,GA
kaitak98 is offline   Reply With Quote
The Following User Says Thank You to kaitak98 For This Useful Post:
eurospeed (10-16-2012)
Old 10-16-2012, 02:25 AM   #1651
atledreier
Drives: GT86 DGM
Is your code the same as the others here kaitak98?
atledreier is offline   Reply With Quote
Old 10-16-2012, 06:11 AM   #1652
KrzysFR
Drives: GT 86, black
Just got back from the dealership, got code P0019. Told them to clear the code and to not touch my car until they get more details from HQ. It seems that there is no technical bulletin yet published by Toyota France for the CEL/Idle issue (or there is but they don't want to tell me).
At least I can drive the car and wait for someone to call me back with actual knowledge about how to fix this.
KrzysFR is offline   Reply With Quote
The Following User Says Thank You to KrzysFR For This Useful Post:
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
