Old 09-24-2012, 04:04 PM   #57
KGFRS86
SoCal Asphalt FR-S Owner
KGFRS86's Avatar
Drives: 13' Asphalt FR-S
I wish I found this thread before I spent $22 on LED's with another company. :[
KGFRS86 is offline   Reply With Quote
Old 09-26-2012, 01:00 PM   #58
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Originally Posted by jjdrivesajazz View Post
T10 5smd 5050 is a perfect fit, some people decide to leave the housing cover off for more brightness.
Hey Bud, sent you a PM in regards to my recent order. So far no info (day 3)
just making sure all is good -- sorry if come off impatient
I blame it on the BRZ
ProjectD is offline   Reply With Quote
Old 09-26-2012, 02:11 PM   #59
jjdrivesajazz
Drives:
I only got your PM today, and I have already responded.
jjdrivesajazz is offline   Reply With Quote
Old 09-26-2012, 05:53 PM   #60
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
I installed all the lights into my car and it's a much nicer feel at night time with the bright LED lights. The only thing is, to me at least, the LED reverse lights don't seem that bright for me. In the pictures they look a lot brighter then they feel for me so at night it's a bit hard to see where I'm going in reverse. Anyone else feel the same?
speedracer38 is offline   Reply With Quote
Old 09-27-2012, 02:14 AM   #61
ProjectD
ProjectD's Avatar
Got the email - Thanks! Can't wait
Old 09-29-2012, 05:46 AM   #62
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Posted this in the other Automation thread but might be useful to others: At first, I couldn't get the lights to work in the trunk. I thought I might have had defective leds, but then I tried spreading out the contacts/wires on the leds so they are a bit farther from each other. That worked!
I don't know if this is normal, but it looks like the contacts in the socket are farther apart than the wires on the leds.
Phaedrus29 is offline   Reply With Quote
Old 10-15-2012, 10:54 PM   #63
jjdrivesajazz
Drives:
^thanks
Old 11-09-2012, 05:09 PM   #64
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by drtepper View Post
I have a quick question:
How does the dome light handle the dimming effect on the BRZ? I've seen some cheaper LED kits in my day and they do a little strobe until they run out of voltage, which might be kind of annoying.
Do these manage to do like a tiered dim or do they just do a quick cut off.. or are they also affected by the strobe-to-off transition?
I changed my oem bulb to an LED set also, so far there's no strobing effect. Same dimming effect with the halogen bulb.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
jjdrivesajazz (12-25-2012)
Old 11-25-2012, 10:57 AM   #65
noc
I'm sure this has been said before, but pictures don't do it any justice!! I installed the entire kit on my BRZ and they look great
Reverse LED's were a pain to install, but I shone a light on the connector and you can see the arrow pointing in the direction for "lock." just twist in the opposite direction and you can easily pull out the bulb. Just be careful of scratching your arm up. I laid a towel down and got on my back to do this; I'm a skinny guy and I still got some scrapes on my forearm.
noc is offline   Reply With Quote
The Following User Says Thank You to noc For This Useful Post:
jjdrivesajazz (11-25-2012)
Old 12-25-2012, 03:14 PM   #66
jjdrivesajazz
Drives:
merry christmas!
Old 01-10-2013, 12:45 AM   #67
rbizzle004
Just received and installed my lights today. Stage 2 Dome Light, Reverse Lights, Trunk light and doors lights. Was rather quick and painless. Hardest being the reverse lights. But everything looks great. I think I will have to order the license plate lights here soon.
rbizzle004 is offline   Reply With Quote
The Following User Says Thank You to rbizzle004 For This Useful Post:
jjdrivesajazz (01-11-2013)
Old 01-11-2013, 02:34 AM   #68
jjdrivesajazz
Drives:
thanks!
Old 02-22-2013, 10:24 PM   #69
wrohdejr
Drives: 2013 subaru limited wrb brz
Originally Posted by boarder1995 View Post
Assistance please...I've got all my LEDs working except the passenger door light. I swapped it with the driver's door and it's not the light, it's the socket. So, when I removed the light originally I didn't disconnect the wires and think I shorted it out as I popped the bulb out with a driver. I know, bad move. Is there a dedicated fuse for this socket? the other door still lights along with the overhead light. I've unplugged and re-plugged the regular bulbs and they don't work either. Anyone know what I'm missing, or what I've messed up? When it gets daylight again, I'll take a volt meter to it.
On another note, the lights look great! My wife's really impressed with the look on "her" car.
Did you figure out what went wrong and how to fix this? I just had the same thing happen to me!
wrohdejr is offline   Reply With Quote
Old 03-11-2013, 03:11 PM   #70
Inzandity
I actually got pulled over last night for the LED license plate lights. Cop said it looked "too blue" against my WRB BRZ. I think it was just a sorry excuse to pull me over.
Sent from my SCH-I605 using Tapatalk 2
Inzandity is offline   Reply With Quote
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 09:17 PM
SG886 license plate ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-18-2012 06:35 PM
Another license plate idea.... michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 4 06-07-2012 09:24 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 07:25 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 12:04 PM
