Old 10-14-2012, 04:07 AM   #29
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Excellent writeup. I don't think I have read a more thorough and well thought out review of a product. Nice job making the exhaust work and not just returning it in a panic like some of us probably would.
Old 10-14-2012, 07:51 AM   #30
cnk
Drives: '13 DGM BRZ Limited
You mention that you followed Grimmspeed's directions to remove the overpipe which doesn't involve jacking up the engine. Did you have to jack up the engine to install the Perrin overpipe or were you able to snake it in from the top?
Old 10-14-2012, 09:28 AM   #31
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Good catch and edited my post. Yes we were able to install it without jacking up the engine. I believe this message is brought to you by the makers of lifts, where work gets easy.
I can only imagine how hard it is on jack stands. While possible, it would not be fun breaking loose the oem nuts that hold the exhaust in place.
F1point4 is offline   Reply With Quote
Old 10-14-2012, 09:44 AM   #32
2pt5RS
Berz
Looks great! Are you using the OEM exhaust bushings, or did you upgrade those as well?
2pt5RS is offline   Reply With Quote
Old 10-14-2012, 09:48 AM   #33
F1point4
Photo Specialist
F1point4's Avatar
We used the OEM hangar bushings. I wanted to upgrade but frankly, I cheaped out here.
Old 10-14-2012, 09:53 AM   #34
2forme
1500$ for a headerback? Good lord. You can't even hear the resonated version!
Really nice build quality. A bit disappointing that you need to hammer your car so that it doesn't rattle, though....
Old 10-14-2012, 10:03 AM   #35
2pt5RS
Berz
seriously!?
I'm waiting on my exhaust to be delivered, but ordered the 12mm hangars from kartboy. Can't beat $8 each...
Old 10-14-2012, 10:13 AM   #36
F1point4
Photo Specialist
F1point4's Avatar
seriously!?
Didn't do my research, glad to know they are that cheap. Please note the Perrin hanger studs are narrower than the OEM ones. This likely the reason why the mini v-band clamps are included. Without knowing exact measurements, If the opening in the rubber hanger is too big then I think the exhaust will bounce around too much.
Let us know how your install goes
Old 10-14-2012, 10:19 AM   #37
Opposed
Drives: 2013 Asphalt FR-S
Well done review! This exhaust is fantastic. Now, I hate to be that guy, but specs on the wheels???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-14-2012, 10:21 AM   #38
F1point4
Photo Specialist
F1point4's Avatar
http://www.ft86club.com/forums/showp...9&postcount=68
Since then I lowered the car on Racecomp Engineering Yellow Springs.
Old 10-14-2012, 10:35 AM   #39
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by gmookher View Post
if you have rattles you havent tightened things down right
I'm full perrin rattle free..tho I agree, that clearance in your photo could be improved upon on my car too. I JUST sent Jeff a note asking hime to make note of your install, feeback on this.
I can attest to the fact that everything was torqued down properly -- twice, in fact. That's why it was mind-boggling to diagnose.
The presence of the flex joint ahead of the resonator is what caused our issues. The combination of heat and the presence of that flex joint allowed the resonator to move away from the installed position and start making contact with the body. The cold/hot photos show the deviation in position between cold temperatures and hot.
If you have similar clearance, I would suggest running to the auto store and picking up some radiant foil like we used. While driving around, I pulled the e-brake boot and slid my hand between the carpet and the body -- HOT! Really, really hot. After banging-out the small u-shaped channel and applying the radiant foil, I could hardly feel any heat in that same location. It may save you from a slow deterioration of the metal in that shaft tunnel.
cobrabyte is offline   Reply With Quote
Old 10-14-2012, 01:10 PM   #40
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Love this writeup.... thanks.
Perrin is definitely a top contender for my exhaust dollars.
Chewie4299 is offline   Reply With Quote
Old 10-14-2012, 03:01 PM   #41
luscious
luscious's Avatar
Drives: 2013 FR-S Argento MT
Nice write up....and nice Europa!
luscious is offline   Reply With Quote
Old 10-14-2012, 03:04 PM   #42
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
seriously!?
how many hangers do we need?
exhaust, headerback, perrin
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Brand New SRT Headerback Exhaust System prest1ge Southwest 5 10-16-2012 06:06 PM
