Old 10-12-2012, 04:52 AM   #211
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
Would those smoked headlights be a ticketable offense? :|
Double4Free is offline   Reply With Quote
Old 10-12-2012, 06:52 AM   #212
jstans84
Drives: Scion FR-S
Why would it be? As long as you aren't changing the light output I don't see how it could be a problem. Since the headlight is a projector there is no actual need to have a chrome housing. Blacking it out only changes how it looks cosmetically not its functionality.
Sent from thousands of years ago into the future.
jstans84 is offline   Reply With Quote
Old 10-13-2012, 11:09 AM   #213
Derik210
That Army Guy
Derik210's Avatar
Drives: Firestorm FR-S MT
here is my finished product
Derik210 is offline   Reply With Quote
Old 10-13-2012, 12:52 PM   #214
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Wow... that is different. I'm not sure if I love it or hate it, but either way it has an interesting look! Nobody is going to confuse your car for anyone else's!
Old 10-13-2012, 05:34 PM   #215
TheProspect
TheProspect's Avatar
Drives: Hot-Lava fr-S Smoked Tail Lights
Should have done a black ring around the projector then red on the rest.. Would make it look so mean!@
My VTec Goes BWwWwWaAAaAaAAAAAaAaHHHHH!!!!!!
TheProspect is offline   Reply With Quote
Old 10-13-2012, 08:51 PM   #216
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
looks stoned
itisthumper is offline   Reply With Quote
Old 10-14-2012, 02:39 AM   #217
DarrenDriven
NW Region Moderator
I'd like to see a photo from the side, at an angle, to see how the chrome in the high beams look.
Old 10-29-2012, 09:38 AM   #218
_F-R-S_
Drives: 13 whiteout scion frs
Thanks again
_F-R-S_ is offline   Reply With Quote
Old 11-01-2012, 12:32 PM   #219
psk
Drives: scion fr-s
so would plasti dip work with this? or would the heat from baking it melt it?
psk is offline   Reply With Quote
Old 11-02-2012, 09:36 AM   #220
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Mine are in the oven right now. I'm stoked!!!!
"CulbyJack"
gmanculb is offline   Reply With Quote
Old 11-02-2012, 01:28 PM   #221
DarrenDriven
NW Region Moderator
Post some photos when they are done!
Old 11-02-2012, 03:18 PM   #222
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Size:  232.6 KBName:  ImageUploadedByTapatalk1351883868.655835.jpg
"CulbyJack"
The Following 4 Users Say Thank You to gmanculb For This Useful Post:
civicdrivr (11-03-2012), Dadhawk (11-02-2012), hmong337 (02-24-2014), suaveflooder (07-25-2013)
Old 11-03-2012, 01:42 PM   #223
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Alright guys. We have a failure. I'll preface this by saying this was the fourth or fifth time these were opened up due to experimenting with LED's and with the recent rain one light sprung a leak so I decided to open them both back up and I totally f'ed up the non-leaking light, go figure. I'm not sure what the cause of the failure was because there were 4 possible contributing factors which are:
Food debris was on the bottom of the oven, thanks Denise, and started smoking while light was in.
I went a few degrees hotter than usual and a few minutes longer, rushed and not thinking I guess. 225 degrees for 15 minutes whereas I usually go 200 degrees for 10 minutes.
I left the top rack in the oven and I usually only leave the one the lights will rest on in there. Radiant heat from the rack in proximity may have caused this.
And finally.... They've been baked 4 or 5 times. Bound to happen sooner or later if you keep exposing to heat.
The lens bubbled inside. It's like little pockets of air in the plastic. In the second picture you can also see micro fractures radiating away from the bubbled area.
I was expecting this to be a $1,000 learning experience but Toyota sells the replacement for $379, whew. Time to bake and move my Bi-Xenon Projectors over to the new housing as well as the blacked out shroud. Good news now is that I have a housing and shroud to experiment on and nail down the LED solution for this housing.
digital_assassin is offline   Reply With Quote
Old 11-03-2012, 02:13 PM   #224
DarrenDriven
NW Region Moderator
Damn! I looked at the photos, then scrolled back up and saw that it was you, Kevin!
Good to know that the replacement lights are not too expensive.
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
