Old 07-12-2012, 10:55 PM   #29
Ben_G
Drives: Blue BRZ
Originally Posted by spiller View Post
@Ben_G these inserts will not change the height of the subframe in relation to the chassis because the car has a floating rear subframe. basically a small steel insert in a large rubber bush but only the small insert meets with the body, not the bush itself. So effectively these inserts are bringing a larger surface area of at the mounting points into contact with the subframe which reduces wiggle. Its difficult to explain but i hope that makes it a bit easier to understand.
@86drift so the front crossmember is solid mounted to the chassis? How is it attached?
OHHHHHHHHHHHHHH..........that's what 86Drift was getting at............ thanks both of you ..... learned something new today.....
Ben_G is offline   Reply With Quote
Old 07-12-2012, 11:08 PM   #30
86drift
86drift's Avatar
Drives: Toyota 86 GT
I haven't been under the car to confirm but from the walkaround on InsideLine: "Meanwhile, efforts to keep weight down and the front end of the car super low have resulted in a forward-facing lower control arm (yellow) and a simple crossmember (green) instead of a full perimeter subframe."
You can see where the crossmember is bolted to the chassis right next to where the lower control arm bolts to the crossmember.
86drift is offline   Reply With Quote
The Following User Says Thank You to 86drift For This Useful Post:
spiller (07-13-2012)
Old 07-13-2012, 12:13 AM   #31
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
thanks for those pics, very interesting. The control arm has two ball joints it seems, ive never owned a car with that sort of suspension set up but I do like the uncomplicated arrangment.
spiller is offline   Reply With Quote
Old 07-13-2012, 08:44 AM   #32
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Are all these products great for street and back road carving, or is it overkill? I've always loved a great handling car, but don't want to overdo it for street use.
DrDuquette is offline   Reply With Quote
Old 07-14-2012, 10:00 AM   #33
86drift
86drift's Avatar
It's definitely not overkill. I'd describe the changes to my car as making it more responsive to steering input and having less understeer. Ride quality is still good, just slightly firmer than stock.
My car is yet to see a track, but I'm very much enjoying street driving and the occasional mountain road.
DrDuquette (07-14-2012)
Old 07-17-2012, 07:04 PM   #34
86drift
86drift's Avatar
I have an update on specs for the Whiteline swaybars.
The below rates are % stiffness over the OEM bars.
Rear 16mm (3 way adjustable)
Soft Setting - 40.48%
Medium Setting - 88.78%
Hard Setting - 176.58%
Rear 18mm (3 way adjustable)
Soft Setting - 114.63%
Medium Setting - 178.04%
Hard Setting - 263.90%
Front 20mm (2 way adjustable)
Soft Setting - 118.5%
Hard Setting – 174%
Front 22mm (2 way adjustable)
Soft Setting - 218%
Hard Setting - 301.5%
Wepeel (10-14-2012)
Old 07-18-2012, 03:46 AM   #35
spiller
wow those 18 and 22mm sway bars really ramp it up dont they. probably overkill for a street car that will occasionally see the track?
Old 07-18-2012, 06:52 PM   #36
86drift
86drift's Avatar
I think they're be to big for a regular street car. Whiteline's recommendation is that they should be used if your running semi slick or full slick tyres.
I'm running 20mm front on soft and 16mm rear on medium and it's fantastic on the street. Once I get some semi-slicks and start racing I'll probably bump them up to the hard setting.
The Following 2 Users Say Thank You to 86drift For This Useful Post:
ill86 (12-15-2012), spiller (07-19-2012)
Old 09-15-2012, 08:16 PM   #37
86drift
86drift's Avatar
Now I'm a vendor I've been able to bring this thread back from the dead.
Now for some belated updates:
My first race with the products intalled.
What a great weekend. If you get a chance to do a track day grab it with both hands. These cars make you feel like a driving god.
Now for how the weekend went. I tested OEM vs Whiteline swaybars.
On Saturday I did 6 laps on the OEM bars and set a best time of 35.95. I then went out with the Whiteline rear bar installed (on medium) and did a 35.62 within 2 laps. A good improvement. Understeer was greatly reduced and oversteer managed with the right foot. This would be a good drift setup and it wanted to drive sideways around the whole track
On Sunday I did 4 laps with Whiteline front and rear bars (set on medium) and did a 35.33. Once again a good improvement. It was more balanced then with just the Whiteline rear bar. I then set both bars to hard and set a best time of 35.27. Setting the bars to hard made no noticeable difference in lap times. However it was more easily unsettled due to bumps.
As expected the thing holding the car back is the tyres. People in the know say a good set of semi-slicks are worth about 2 sec a lap. Since I was 1.8 sec behind the rx7 race car which won my class, I’m very happy with how quick it was.
ill86 (12-15-2012)
Old 10-12-2012, 02:55 AM   #38
86drift
86drift's Avatar
Now for one of my favorite mods. Whiteline have released a gearbox mount insert. Or Positive Shift Kit as they call it.
I have to say I was skeptical that it would improve an already excellent shift, but I've had it on my car the last couple of days and it's excellent. Since the gates stay in the same place irrespective of if you're on or off the gas it's easier to slot home the gears.
[ame="http://www.youtube.com/watch?v=dLzMO6_ZNHk"]BRZ / 86 / FR-S Whiteline Positive Shift Kit - YouTube[/ame]
nix (10-12-2012)
Old 10-12-2012, 08:38 AM   #39
nix
nix's Avatar
Drives: AVO BRZ
Huge difference! Looks better than the cusco one I have.
nix is offline   Reply With Quote
Old 10-12-2012, 09:03 AM   #40
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have the Whiteline positive shift kit on our car as well and love it. Headed to the track this weekend for a time attack and will have video reviews from the track up on Monday.
Whiteline always has had great products and pretty much the only stuff we run on our cars fro sways and bushings.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-12-2012, 05:21 PM   #41
Nardi330
Nardi330's Avatar
Drives: 86
I haven't installed mine, increase vibration much?
Thx
Nardi330 is offline   Reply With Quote
Old 10-12-2012, 08:47 PM   #42
nix
nix's Avatar
Drives: AVO BRZ
Thx
Me either but I meant in an engineering sense, cusco is solid billet and doesn't provide lateral support like this one seems to.
Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS Circuit Motorsports Brakes, Suspension, Chassis 64 12-18-2012 02:25 PM
Boston Motorsports: >>>Whiteline Suspension Components! Boston Motorsports Brakes, Suspension, Chassis 6 07-24-2012 01:07 PM
Whiteline Sway Bar Links at Redline360 Redline360 Brakes, Suspension, Chassis 0 06-28-2012 10:44 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 03:25 AM
