Old 10-11-2012, 04:20 AM   #15
EZWood
BAMF
EZWood's Avatar
Originally Posted by 86pro View Post
remember guys that it wears your belts waaaaaaaaaaaaaaaaay faster.
Pictures or it didn't happen.
Old 10-11-2012, 10:28 AM   #16
raz0rbladez909
I'm here for the beer
raz0rbladez909's Avatar
Drives: 2013 Scion FRS, 1971 Datsun 240z
Sounds like user error, or a problem with the product.
raz0rbladez909 is offline   Reply With Quote
Old 10-11-2012, 10:47 AM   #17
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
I really want to get one...I just think it will harm the engine. The stock one has rubber/balance points on it as well. I think I will just have to save up for a carbon driveshaft and lightweight flywheel.
SkitterSkotter is offline   Reply With Quote
Old 10-11-2012, 11:51 AM   #18
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
It will not harm a boxer engine.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-11-2012, 12:01 PM   #19
wlfpck
Drives: 2015 GTI
It is not a balancer. It is a dampener. The two are very different things.
As for harming the engine... I do not have the data on boxer engines and such. But for I-4 and I-6's there are numerous reports and data provided by Dinan, ATI, etc. that describe the dangers of an undampened pulley. I have posted this in another pulley thread.
For the boxer engine... maybe it doesn't matter. Idk.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 10-11-2012, 02:46 PM   #20
The Slow One
Track Junkie
Drives: Argento Scion FR-S
^I'm waiting to see if Fluidampr, will release one for our cars. I always had a thing for that company.
The Slow One is offline   Reply With Quote
Old 10-11-2012, 04:53 PM   #21
SkitterSkotter
Thanks, I do understand what you're saying...I'm just weary of installing it. If there were some hard data out there to fully support that adding a lightweight pulley is beneficial to the engine and does not increase wear I would be more than happy to get one. That said, I'm just not going to to take anecdotal evidence that the part is 'fine' for the engine. I plan on owning this car for 200,000+ miles so I'm being cautious with it.
Old 10-12-2012, 12:08 AM   #22
WolfsFang
Scrape Master
WolfsFang's Avatar
I dont know if this goes for our cars but. This messaged was asked to SoA, which they had asked FHI for the answer.
Isn't replacing the stock harmonic damper (pulley) bad? Subarus do not come with a harmonic damper or balancer like some other vehicles do. For other manufacturers' vehicles, this is a legitimate concern. Proof:
"Thank you for your patience as I checked with our Technical Services Department regarding your message below. They advised that the crank pulley is a pulley and nothing else. It is not used as a harmonic damper/balancer.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again."
Best wishes,
John J. Mergen
Customer Service Department
Subaru of America, Inc.
http://forums.nasioc.com/forums/showthread.php?t=444518
Are there any downsides to these pulleys? There have not been significant amounts of problems with pulleys. There have been some reports of high RPM issues with pulleys though. These issues tend to happen without regard to type or manufacturer. It possibly stems from rotational issues with the crank position sensor which is located near the pulley. The indication of error is a reduction of the fuel cutoff redline of the motor (false redline). The solution is to reinstall the stock pulley. As with any aftermarket part, even "perfect" ones, sometimes you run into a rogue issue. From research, this is not a widespread issue at all, only an advisory if this situation should occur.
The Following 2 Users Say Thank You to WolfsFang For This Useful Post:
diirk (11-29-2012), hyper4mance (09-17-2013)
Old 11-29-2012, 03:15 AM   #23
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
Originally Posted by WolfsFang View Post
I dont know if this goes for our cars but. This messaged was asked to SoA, which they had asked FHI for the answer.http://forums.nasioc.com/forums/showthread.php?t=444518
Great thanks for info
Teknian_Culprate13 is offline   Reply With Quote
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 02:10 AM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 02:00 PM
Ralco RZ Lightweight Crank Pulley HELP! JERZgrl88 Engine, Exhaust, Transmission 11 10-10-2012 01:41 PM
FS: Perrin lightweight pulley (Vancouver BC) stanm Canada Classifieds 0 09-15-2012 09:04 AM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 11:24 PM
