Old 10-10-2012, 06:03 PM   #57
2forme
Originally Posted by NotSoJDM View Post
I think MAF placement has everything to do with it and the tube they use in the intake pipe near the MAF for injen. You can see why the AIRAID chokes itself out in the high rpms because the AFRs dive into the 10s and under. That is straight robbing power.
That's what I said LOL. The tube allows unmetered air to pass the MAFS. This causes the ECU to add less fuel (because it thinks there is less air). Leaner mixture makes more power. With a proper tune, this "inner pipe" is useless.
Oh, and the cold air on the dyno helps haha.
Old 10-10-2012, 06:47 PM   #58
spanky4177
spanky4177's Avatar
Drives: 2013 Firestorm & WhiteOut FR-S 6MT
Greddy vs Injen
What's up everybody Just got my 5pc Aero Five Axis body kit installed. I'm about to order a Borla cat back exhaust system but don't know which cold air intake to get?? I'm kinda leaning toward the Greddy or Injen but not sure which one is better?
spanky4177 is offline   Reply With Quote
Old 10-10-2012, 07:17 PM   #59
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Well not exactly. I think you're on the right track though. That tube doesn't allow unmetered air to pass through the pipe. MAF readings are calculated using pipe diameter and filament reading taken from the sensor itself. So any air that doesn't specifically pass over the sensor itself is purely a calculated value based on what I listed above. Rather I think this small tube is altering that calculated theoretical air flow value by changing the effects of the airflow.
I have to run a flow simulation to test my theory. But the short of it is I think that tube is altering the turbulent/laminar flow characteristics of the air past the sensor at the higher airflow rates in the upper rpms. And by doing so affects the MAF reading to help lean it out up top.
But yes, all of this is rather moot when you consider that this can be compensate for on the tune.
Just so we are clear. I am not disagreeing with your statements. I share the same thoughts on mostly all of it. I'm just sharing my opinion as to the effects of the small air tube.
NotSoJDM is offline   Reply With Quote
The Following User Says Thank You to NotSoJDM For This Useful Post:
2forme (10-10-2012)
Old 10-10-2012, 07:44 PM   #60
86drift
86drift's Avatar
Drives: Toyota 86 GT
Not sure if anyone's mentioned it, but the ECU has learning algo which is used in the first 100kms after an ECU reset. I wonder if the AFRs will be corrected by the ECU after the learning has finished. The Airaid instructions say to reset the ECU (disconnect the battery during install).
86drift is offline   Reply With Quote
Old 10-10-2012, 08:00 PM   #61
2forme
From my tests, my AFR's and power didn't vary more than about 1hp from a freshly reset ECU and an ECU that had been driven for over 500 miles.
Take it for what it's worth. But the end result didn't change much for me.
The Following User Says Thank You to 2forme For This Useful Post:
86drift (10-10-2012)
Old 10-10-2012, 09:33 PM   #62
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
That's what correction factors are for ~ standards. It would be different if I had done this in winter time and shown "uncorrected" numbers as opposed to SAE or STD.
For the most part, and generally speaking yes... BUT...
So with all the discussions about snorkels being on or off, I figured I'd post this :
In the case of the AiRaid intake, some had said that leaving the snorkel on would mean up to a 20% restriction. Would you like to guess which run was with a high CFM carpet fan blowing at the intake (in addition to the hood being open and another dyno fan blowing) and which was without?
I brought this up when @mechaghost posted his findings but some people were more keen to see better numbers then I think.
Regards
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
AVOturboworld (10-10-2012)
Old 10-10-2012, 09:58 PM   #63
2forme
Lol, I wasn't referring to ambient temp. I was referring to supplying cold air to an intake that isn't cold air. The AIRAID and Injen intakes both suck in hot air when the hood is closed and the car is warm.
Old 10-10-2012, 11:50 PM   #64
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Adding part of the snorkel to the Airaid
Would adding part of the snorkel help the Airaid?
This modification has the air entering from the colder side of the radiator.
I realize it may reduce the intake size.
I realize the air entrance isn't smooth or velocity stack shaped.
Does colder air make up for the slight reduction this little mod may offer?
Airaid made a mistake not extending the intake like the AFE, just my opinion.
I'm going to get some fiberglass and mold a scoop for this Airaid that extends into the "colder area"
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-10-2012, 11:57 PM   #65
zoomzoomers
zoomzoomers's Avatar
I don't have any numbers, ir data, but common sense would dictate the when the car is in motion the Airaid intake gets its air in front of the radiator and the motor, i.e. Everything that would be giving off any significant amount of heat.
Old 10-11-2012, 12:00 AM   #66
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
So.... When is a company going to come out and make an aftermarket snorkel that is larger and more efficient than the stocker? Almost seems like common sense, it would convert all the intakes into cold air intakes...
TyperRspec789 is offline   Reply With Quote
Old 10-11-2012, 12:05 AM   #67
zoomzoomers
I don't think it's that simple. Sure, colder air is always good, but cooler air won't help the fact that there is a bottle neck at the inlet constricting the incoming air.
Old 10-11-2012, 06:33 AM   #68
Shagaliscious
Drives: Firestorm FR-S (MT)
Ok, I was discussing this with a friend at work. He said he wouldn't get an intake because it might void your warranty. I realize dealerships can technically use anything that isn't stock against you, but has anyone heard of someone getting denied warranty work because of an intake?
Old 10-11-2012, 07:17 AM   #69
2forme
Tony, if you look at my roto mold shoot out thread, I address this exact scenario with dynos. I cut my snorkel just like this one.
If it's too early and you don't feel like reading, the cliff notes is I saw an immediate gain in HP when I removed the snorkel, from restriction alone. Wasn't a huge gain... maybe 2-3 whp.
Old 10-11-2012, 07:31 AM   #70
tonystewart
Good morning
I did read it, thanks, and I do realize I'm reaching for straws, lol,
I was "Hoping" for some colder air, hahaha
FRS Event, FR shootout, and FF shootout at Willow Springs Raceway Pekingduck FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 01-18-2013 11:17 PM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 04:05 PM
Intake Shootout! Free Baseline? :) Drift-Office Northwest 16 10-02-2012 11:28 PM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 06:36 PM
Injen Intake IN STOCK! Mach V Dan Engine, Exhaust, Bolt-Ons 0 08-14-2012 01:04 PM
