Old 10-10-2012, 02:46 PM   #43
2forme
@Drift-Office,
I meant absolutely no disrespect. I applaud the effort. I'm just saying that these dynos *COULD* make the Injen and AIRAID look like they make more power than they really would in day-to-day use.
With the hood open, every intake will always get fresh, cool air. However, driving around town with the hood closed, this wouldn't be the case for the AIRAID or the Injen because of how they are designed. They would suck in higher temps because of the heat soak in the engine bay. This doesn't apply as much to the stock (with snorkel) and the aFe, because they suck air directly from the front bumper area with very little to no gap between.
Also, by the time the engine is fully warm (which is the only time you should beat on your car), the engine bay is already good and toasty.
The Following User Says Thank You to 2forme For This Useful Post:
Drift-Office (10-11-2012)
Old 10-10-2012, 02:52 PM   #44
2forme
Originally Posted by Crossover Auto View Post
If someone has a good scan tool to gather this info before I do. Please post your results.
The following info needs to be collected for a more detailed intake shoot out.
MAF g/s airflow vs. load/rpm - how much air does each intake flow
Wideband AFR vs. load - how each affects the stock ECU tune
Short term and long term fuel trims changes - how the stock ECU tune is compensating for air flow changes
IAT(intake air temp) from idle to moving @ 40/70mph - how each reacts to air temperature which affects the ECU tune
I posted a lot of this information (minus the fuel trim stuff) in my roto mold shootout thread.
http://www.ft86club.com/forums/showthread.php?t=18598
I will say, that the stock tune did an amazing job at adjusting for the aFe since it held an identical AFR curve to the stock intake.
I'm going to do IAT readings between the aFe and the AIRAID as soon as we get a dry day around here. LOL. I have them in different logs taken on different days, but I want to compare them on the same day for the same temp.
Crossover Auto (10-10-2012)
Old 10-10-2012, 03:03 PM   #45
Crossover Auto
Drives: FR-S, BR-Z, 86
Originally Posted by Drift-Office View Post
Don't you mean susceptible?
semantics
That's great, but I leave that to the intake manufacturers ~ after all, they're judged by the end result - and based on their collective performance at the end of the dyno run...
While the end result is why most will purchase an intake. A more informed consumer or dealer should like to know these details, knowing the intake has good driveability, won't throw DTCs left and right, and wont adversely affect AFR which in turn alters MPG.
Crossover Auto is offline   Reply With Quote
Old 10-10-2012, 03:13 PM   #46
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
semantics
QFT!
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
Darkparadox911 (07-02-2015)
Old 10-10-2012, 03:19 PM   #47
xcelir8brz
Drives: 2013 BRZ Limited
Very interesting.
xcelir8brz is offline   Reply With Quote
Old 10-10-2012, 04:03 PM   #48
jumbaco
jumbaco's Avatar
Drives: FD
+1, interesting results. The Injen puts the MAF so close to the TB, I though it had to be a certain distance away from it.
jumbaco is offline   Reply With Quote
Old 10-10-2012, 05:48 PM   #49
zoomzoomers
zoomzoomers's Avatar
I'm really surprised about the results of this comparo. Of course, all I have to go on are these are the data posted. Good work guys and thanks.
Old 10-10-2012, 06:07 PM   #50
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
Great Test!!!
Thanks for all your work on this and to post the outcome of what you found!!
Greatly Appreciated
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 10-10-2012, 06:22 PM   #51
whitejdm
Drives: BRZ prem.
Great information in here but as with all intake threads it seems to raise just as many questions as answers. SO far I'm still sticking with the dropin filter/intake pipe combo.
whitejdm is offline   Reply With Quote
Old 10-10-2012, 06:31 PM   #52
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
I just really want to see the Airaid retested. No gains from it compared to stock? Something is wrong right?? Or am I reading the results wrong?
Style is offline   Reply With Quote
Old 10-10-2012, 06:37 PM   #53
2forme
They tested it on 2 different cars. I've seen it make virtually nothing personally. Visconti has seen it make nothing. I think that dyno is pretty legit.
Intakes don't make much power on these cars. Especially with an aftermarket tune.
Old 10-10-2012, 06:41 PM   #54
Style
LXXXVI
Style's Avatar
So why is it that the Injen intake has the craziest gains out of all the ones that they tested on this test?
Old 10-10-2012, 06:45 PM   #55
2forme
My belief is because they didn't run the dyno with a closed hood. The Injen isn't a CAI. But with the hood open and a fan blowing on it, it is. Oh, and because Injen bypasses some of the air past the MAFS, tricking it into running lean. This would be negated with an aftermarket tune.
Old 10-10-2012, 06:57 PM   #56
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I think MAF placement has everything to do with it and the tube they use in the intake pipe near the MAF for injen. You can see why the AIRAID chokes itself out in the high rpms because the AFRs dive into the 10s and under. That is straight robbing power.
NotSoJDM is offline   Reply With Quote
FRS Event, FR shootout, and FF shootout at Willow Springs Raceway Pekingduck FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 01-19-2013 12:17 AM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 05:05 PM
Intake Shootout! Free Baseline? :) Drift-Office Northwest 16 10-03-2012 12:28 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 07:36 PM
Injen Intake IN STOCK! Mach V Dan Engine, Exhaust, Bolt-Ons 0 08-14-2012 02:04 PM
