Old 10-10-2012, 09:29 AM   #15
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Thanks. This will be a longer trip, unfotunately.
kmbkk is offline   Reply With Quote
Old 10-10-2012, 10:25 AM   #16
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Keep your head down, so you come back...so we can get your turbo install results! Ok, that's shallow.
Honestly, stay safe, and THANKS.
boarder1995 is offline   Reply With Quote
Old 10-10-2012, 10:42 AM   #17
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Don't worry, the turbo kit will continue with or without me here! I'll post updates as much as I can, and hopefully soon there will be a more detailed thread on the kit.
Old 10-10-2012, 10:44 AM   #18
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Originally Posted by dboz View Post
Any chance that CAI could suck up water??
If you drive the car into a river or lake!
Seriously, though, I don't think there will be a problem with water getting into the intake. I think it's mounted high enough to alleviate water ingestion. However, I'm not an expert on them, it's just my opinion.
Old 10-10-2012, 10:49 AM   #19
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Originally Posted by Mrqb22 View Post
When is someone going to out a twin turbo set up? You think there is enough room in there?
That would actually be pretty cool. You could do a true dual exhaust with a small turbo on each side. Not sure how practical it would be on a 4 cyl., but would definitely be something different. I was looking at doing a twin turbo setup on my Pontiac G8 GT, but never got around to it.
Old 10-10-2012, 12:01 PM   #20
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
that is the location where the stock piece before your airfilter picks up its air from so i doubt it.
good looking kit brah!
Silverdub is offline   Reply With Quote
Old 10-10-2012, 12:32 PM   #21
empower-auto
Kouki-Monster
empower-auto's Avatar
is this everyone's first car? wow.
twin turbo = stupid and no the car isn't going to hydrolock.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-10-2012, 02:37 PM   #22
xcelir8brz
Drives: 2013 BRZ Limited
Subscribed.
xcelir8brz is offline   Reply With Quote
Old 10-10-2012, 02:58 PM   #23
Synack
Boosted
Synack's Avatar
Drives: Sideways
It would be very tough... and interesting to say the least... as there are 2 banks of cylinders, but only 2 cylinders per bank. You would have to get an aftermarket manifold for each bank that would run into each turbo. I'm not sure how effective it would be with only 2 cylinders per bank, not a whole lot of exhaust running to each turbo.
For small engines (4 banger in this case) it is of course better to use a single turbo, because it produces sufficient exhaust gas just that one turbo efficiently. For larger engines, it is usually smarter to use a pair of small turbochargers instead of a big one, because small turbines result in less turbo lag. But they are able to produce enough exhaust gas to power both turbos.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 10-10-2012, 04:07 PM   #24
gmookher
It looks great but the heat soak off that turbo location by the intake pipe would concern me in any racing application. Prolly fine for a daily driver.
Old 10-10-2012, 04:31 PM   #25
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Oh, I forgot to mention, the piping will be powder-coated black!
Old 10-12-2012, 09:00 PM   #26
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Over pipe & test pipe in the works! Will be options for the kits!
Old 10-12-2012, 09:01 PM   #27
gmookher
so youre making a turbo and a complete exhaust too?
Old 10-12-2012, 09:27 PM   #28
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
At least through the test pipe (cat). They're thinking of doing a complete exhaust as well.
Crawford Performance Turbo BRZ ! Visconti Forced Induction 57 10-12-2012 07:45 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
need donor for treadstone turbo kit treadstone performance Forced Induction 113 07-19-2012 10:31 AM
