#15 | |
#16 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
It absolutely makes a difference. IMO the Airaid dyno run should be scrapped and done again since Airaid has stated many times in their intake development thread that when they put it on a flowbench after removing the snorkel that they measured a 20% improvement in airflow. It is clearly a bottleneck for the Airaid in particular. The velocity stack design of the Airaid inlet is actually very good at drawing in fresh, cool air versus the snorkel.
The instructions for the Airaid do not require snorkel removal but it is strongly suggested by all their reps and everyone that installs their intakes for max performance. That's likely a contributing factor to why you're seeing the top end loss on the dyno. Quote:
#17 |
Drives: '13 DGM BRZ Limited
^+1
Same applies to the aFe Takeda intake. Snorkel removal is part of their installation directions. |
#18 | |
Don't get too hung up on the velocity stacks. The aFe doesn't have a hardcore velocity stack at the mouth, or one in the chamber, and it still outflows the AIRAID unit by an average of 20g/s according to the MAFS. In addition, the aFe pulled in cooler air. |
#19 | |
I'm having trouble understanding how the Injen, with its open faced design, would make the most power. It has no inlet directing cool air from inside the bumper, just an open face that's at least 3-4 inches away from where the snorkel resides. It can and will draw in hot air rising off the block and header that gets trapped under the hood while idling. The other systems are all well sealed and have inlets much closer to the snorkel air source. It just doesn't make sense to me; maybe since the hood was up during the dyno pulls it didn't draw in as much hot air. |
#20 | |
Drives: FRS
On that note has Injen said anything about fixing whatever the issue is?
_____________________________________________
http://genometuning.com http://www.BlackHandGaming.com |
#21 | |
They probably had the hood open, and a fan blowing on it. |
#22 |
Drives: Lexus GS300
#23 |
Drives: 2013 Scion Frs(Scarlet)
I was going to say that...if they were all tested the same way then it is what is really. I took the snorkel out of my bumper and the gap is pretty much the same and with out the snorkel according to the results my car pulled in about 7 more g/s and kept the intake cooler during wot with the stock intake and hks intake filter. Only thing is that when the car is idling for a good amount of time the intake ran really hot. Injen has been in the game for quite some time and maybe theres more to their design than we know..who knows!
And if im not mistaken doesnt hot air always rise and on the top of the box there are vents, maybe they serve more purpose than we think! |
#24 |
Drives: 86
We need to have E92M3GUY add these to the Dyno Database
#25 |
Right, but the aFe and stock intakes pull air from the front bumper regardless of whether or not the hood is open. The Injen and AIRAID units pull more air from the engine bay. As the temps rise in the engine bay, the power these intakes put out decrease (the effect is rather quick, actually). By just leaving the hood open for all intakes, you're negating this advantage, which can produce unrealistic results.
#26 | |
#27 | |
Plus the presence of the snorkel in all these tests (where the Airaid and Takeda need a snorkel delete for best results) is why I think everyone should take these results with a huge grain of salt. |
#28 | |
| FRS Event, FR shootout, and FF shootout at Willow Springs Raceway | Pekingduck | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 01-18-2013 11:17 PM |
| INJEN and aFe Intake System, In stock and ready to ship!! | 10k Redline | Engine, Exhaust, Bolt-Ons | 5 | 10-03-2012 04:05 PM |
| Intake Shootout! Free Baseline? :) | Drift-Office | Northwest | 16 | 10-02-2012 11:28 PM |
| Airaid Intake System Official GB - The pre-order | AJUSA.com | Engine, Exhaust, Bolt-Ons | 212 | 09-19-2012 06:36 PM |
| Injen Intake IN STOCK! | Mach V Dan | Engine, Exhaust, Bolt-Ons | 0 | 08-14-2012 01:04 PM |
