Old 10-06-2012, 04:43 PM   #183
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Brakes are on. Essex did a great job with the instructions. Only a pair of unexpected complications during install. I'll have them on the track tomorrow during the FRS86 meet at Autoclub Speedway in Fontana tomorrow. If you are around come by and say hi.
Here is a photo of the finished product. A longer review, install outline, and more photos are on my blog if you want to see.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
The Following 3 Users Say Thank You to Matt Andrews For This Useful Post:
03Z33 (10-06-2012), Dave-ROR (10-07-2012), track_warrior (10-07-2012)
Old 10-07-2012, 03:18 PM   #184
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by CSG David View Post
It LOOKS like the AME Tracer TM-02. Thanks for the correction though. What was I thinking?!?!
I wonder which ones are lighter?
Looks great, cant wait to hear you impressions on these, im getting mine around the 15th. BTW what wheels are those?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 10-07-2012, 03:46 PM   #185
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Looks good... only if they made both front & rear brake upgrade. IF they ever do, I'm totally going this setup!
Old 10-07-2012, 03:47 PM   #186
BRAWL
Drives: Toyota 86 GTS Velocity Orange
I will likely get a set of these in about 12 months after getting my car and then wheels to suit them
BRAWL is offline   Reply With Quote
Old 10-07-2012, 10:23 PM   #187
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They will be, for show.. but why do you want more in the rear of the car?
IMO there's enough brake back there already, there is definately no need for larger heatsinks back there, it doesn't use all of what's already available.
I was working on a buddies Boss 302 yesterday and his car is running full Ford Racing 302R race car brakes, the rears used on the race car (and therefore his) are factory Boss 302 rear brakes, the fronts are massive full floating discs with 70 or 76 vane (forget) rotors and 4 pot Brembo calipers. Point being, only upgrade the rears if it's required IMO.
Well unless it's a show car, then upgrade everything for show points
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-07-2012, 10:33 PM   #188
RYU
RYU's Avatar
Drives: really slow...
Speaking from my limited personal experience having fixed calipers on all 4 corners improves pedal feel and modulation. Better heat dissipation is also a given. Performance improvement? Maybe only marginal in this car.
Would like to hear thoughts from Essex on this.
RYU is offline   Reply With Quote
Old 10-07-2012, 10:40 PM   #189
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Certainly fixed calipers can improve feel and modulation, I would never argue that (and have stated it before). I would argue that it's going to be really noticable from the REAR of this car though.
Those are two of the reasons I've ordered the Sprint setup from Essex. The additional cooling from the rotors, lose of unsprung weight, cheaper pad replacements and longer pad life are others.
I really can't see myself ever bothering with the rear though, I don't believe we will get any great benefits from there and there is no need for additional cooling yet, the damn things don't even get warm enough on track to bake the paint off pads, it only takes a lap or two to bake the paint off the fronts
I also doubt modulation benefits in general in modern cars, EBD I think will remove a lot of that benefit seen in older cars that I've experienced it in.
I'll find out soon enough hopefully - for the fronts anyways!
Jeff and I had conversations about this months before the car was released but I welcome his thoughts as well!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-07-2012, 11:32 PM   #190
ichitaka05
Site Moderator
ichitaka05's Avatar
No, I don't need 4 pot in the rear. Just need 2 pot, more will be waste for this car.
Why I need/want 4/2 on this car when it's already good as is... I'm OCD like that. I cannot stand having different front & rear calipers set-up. Yes, I know that's totally "show car" concept... BUT I just feel I want 4/2 AP calipers.
Ro_Ja (10-08-2012)
Old 10-07-2012, 11:44 PM   #191
Matt Andrews
Drives: race cars
skip the rear caliper upgrade and just make a 2 piece rear rotor to knock off the weight. This set up is great. More when I can type more and download all the video. I believe the car set FTD at the autocross and ran 2:00 laps on the Roval this weekend during the speedventures / FRS86 meet in Fontana. Great modulation, great heat dissipation.
Good to meet the many folks from this board that I got to talk to.
Best,
Matt
The Following User Says Thank You to Matt Andrews For This Useful Post:
Ro_Ja (10-08-2012)
Old 10-07-2012, 11:45 PM   #192
Matt Andrews
Drives: race cars
Mach V's "awesome" wheel. 17x9 at under 18 lbs.
Old 10-08-2012, 12:02 AM   #193
track_warrior
Track Junkie
Matt, any rubbing at the track with 17x9? Im considering selling my 17x8's and moving to a 17x9 to run 255's.
Old 10-08-2012, 12:44 AM   #194
Matt Andrews
Drives: race cars
no rubbing on track. well, almost none. The rears touch just enough to turn the rolled fender black in a couple spots, but you can't see any evidence on the tire itself. It does rub at full lock in the parking lot. But I will run this setup again, and I have no problem putting my wife in the car. So no special knowledge needed to drive around issues.
track_warrior (10-08-2012)
Old 10-08-2012, 01:07 AM   #195
Racecomp Engineering
We cant wait to get these on our BRZ this week !
JEFFFFFFFF !
Old 10-08-2012, 02:24 AM   #196
ImAwesome
Drives: 99' M3, 13' SWP Brz
for me upgrading the rears just helps keep the factory distribution, if you take into account total swept area, proportioning valves, piston sizes, etc.
ImAwesome is offline   Reply With Quote
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
