Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-06-2012, 05:16 AM   #1
70NYD
70NYD's Avatar
Drives: RX8 S1
RANDOM QUESTIONS THREAD
Hi people,
i thought i would make this, we need a place were we can ask little questions that do not warrant a new thread each time..
i am not sure if the main forum has one of these, but everyone is welcome to post here.. just if you are answering questions with respect to where to buy what in stores, mind what part of the world the question comes from
cheers
ps could we sticky this?
70NYD is offline   Reply With Quote
Old 10-06-2012, 08:44 AM   #2
st162celica
Drives: 86 GTS Manual - Tornado Grey
Great idea.
Not sure if all members would post here though, guess some people rather start their own threads.
Let me start it off.
Can i enable the tacho sweep on my 86. Havent searched for it, but i remember something that we can ? If yes then how ?
st162celica is offline   Reply With Quote
Old 10-06-2012, 08:51 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Tachometer indicator needle movement function when starting
the vehicle
When the engine switch is turned to “ON” position (vehicles without a
keyless access with push button start system), or the push-button
ignition switch is turned to “ON” mode (vehicles with a keyless access
with push button start system), the tachometer indicator needle points
to the highest value once and then quickly returns.
■Changing between activated/deactivated
Step 1 Press the “ODO/TRIP” switch repeatedly until the setting
screen is displayed.
Step 2 Each time the switch is pressed and held, the function
changes between activated/deactivated.
“S-on”: Activated
“S-oFF”: Deactivated
This is from the BRZ manual; I am assuming it is the same for the 86.
davey90 (10-06-2012)
Old 10-06-2012, 09:10 AM   #4
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
will try this now!
EDIT: Not working on 86 GTS - cycled through the ODO while the car is powered "ON" (that mean's without starting the engine,right?). No setting for S-On or S-OFF. Unless i did it wrong all i saw was ODO, Trip A, Trip B then back to ODO
davey90 is offline   Reply With Quote
Old 10-06-2012, 09:27 AM   #5
Nardi330
Nardi330's Avatar
Drives: 86
BRZ is different to 86 with this one. It's a BRZ unique feature.
86 has techno sweep too but only after setting the shift light and only sweep to the shift light rpm. Unlikely BRZ which goes all the way to redline.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
st162celica (10-07-2012)
Old 10-06-2012, 10:22 AM   #6
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
^ yep, if you set the shift indicator on the 86, it sweeps up to that value and back down. just set it to 7400rpm and ur good to go :P
proficience is offline   Reply With Quote
Old 10-06-2012, 01:26 PM   #7
ZZT86
ZZT86's Avatar
Drives: BR86
Does the GTS have an alarm system? I notice in the Subaru drivers manual, possibly US spec, that it's there, although going by Toyota web specs that it's immobiliser only.
ZZT86 is offline   Reply With Quote
Old 10-06-2012, 05:32 PM   #8
Nardi330
Nardi330's Avatar
Drives: 86
No alarm. Not every feature on US spec cars are on our car. Another one we don't get is tyre pressure monitoring system.
We have immobilisor tho.
ZZT86 (10-08-2012)
Old 10-06-2012, 08:47 PM   #9
autogyro
Drives: Toyota 86 GTS
Is the BRZ's sat nav any good? I'm still tossing up between a BRZ and an 86 and I hear the 86's sat nav is a bit hit and miss. Thanks guys.
autogyro is offline   Reply With Quote
Old 10-06-2012, 08:58 PM   #10
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
isnt it the same?
Surok is offline   Reply With Quote
Old 10-06-2012, 11:14 PM   #11
Cappuccino
Drives: 2012 Tornado Grey Toyota 86 GTS
I have had no issues with my GPS on the 86 and I use it everyday.
Richard BRZ comes with an Eclipse stereo instead of the Fujitsu Ten that is found in the 86
Cappuccino is offline   Reply With Quote
Old 10-06-2012, 11:35 PM   #12
Nardi330
Nardi330's Avatar
Drives: 86
For the record, sat nav on BRZ is optional but standard on 86 GTS and as above they are not the same units.
If I want sat nav on BRZ, I'd rather go aftermarket.
I also don't have problem with my sat nav in my GTS. I just wish the touch screen is more responsive and it doesn't lock up the features when the car is moving.
Old 10-06-2012, 11:54 PM   #13
ColSeBas
Drives: None. Saving though!
Does anyone know who owns a white 86 around the Hills area in Sydney? Saw it on election day and glad to see one in my area!
ColSeBas is offline   Reply With Quote
Old 10-07-2012, 12:56 AM   #14
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
Wait, what?
What features get frozen?
Palmy is offline   Reply With Quote
Random pictures thread! switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 8545 04-10-2020 01:58 AM
Random Gifs Thread travace Off-Topic Lounge [WARNING: NO POLITICS] 2 09-02-2012 01:56 PM
Random Sports Thread S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 27 05-03-2012 03:54 PM
Random Picture thread WheelFast Other Vehicles & General Automotive Discussions 2 01-16-2012 02:28 AM
