Old 10-06-2012, 08:40 AM   #1
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Broken Wheel Nut on new rims
Hi guys I bought a set of composite Alloy wheel nuts and the last night I put on the 4th wheel sheared off as I was torquing them up. It is tight against the wheel what is the best way to get it off?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 10-06-2012, 08:45 AM   #2
70NYD
70NYD's Avatar
Drives: RX8 S1
Oh man so it snapped in line with the threads, not down the length??
Your best bet is to get a chisel and try to brake it. If that don't work you need to drill the stud out..
This is why noone, ever, should get aluminum nuts..
70NYD is offline   Reply With Quote
Old 10-06-2012, 09:01 AM   #3
doggy
doggy's Avatar
Drives: Scion FRS Firestorm MT
You mean CHEAP EBAY ones right?
I'v used lots of nuts from differenet brand (not cheapos) nuts - and NEVER had any problems... Even our race car is running on Rays aluminium nuts for last 3 years - and never ever had any problem..
Ussualy people overtight them - and then blame it on for them beeing aluminium. Its pretty easy to read over and find torque settings for all the nuts - and use a torque tool...
Easyest way to take off broken nut - is just to drill the stud out and replace it with new one.
doggy is offline   Reply With Quote
Old 10-06-2012, 01:40 PM   #4
70NYD
70NYD's Avatar
Drives: RX8 S1
No I mean ANY
aluminium nuts are a throw away item. They should be used once. Period. Regardless of the brand. This is from a metallurgical point of view. You can argue with annecdotes all day of you want to
Also since al alloys distort differently to steel alloys, as you said, they should be torqued slightly differently.
Old 10-06-2012, 01:58 PM   #5
Rawhyde
Drives: B4C Camaro, 2005 MINI JCW, Civic
Aluminum lug nuts? Why would anyone even make such a thing? The liability would be crushing. What is the point of using them? It seems like a risky way to save a small amount of weight.
Rawhyde is offline   Reply With Quote
Old 10-06-2012, 02:04 PM   #6
Cheddar
Saving them pennies...
I used 5zigen aluminum lugs for over 6 years. Torque to 80 pounds with a torque wrench that gets checked and calibrated every year.
Never had any issues. If you don't have a torque wrench you shouldn't be putting them on with a gun or by hand.
Cheddar is offline   Reply With Quote
Old 10-06-2012, 02:05 PM   #7
Cheddar
Because racecar
Old 10-06-2012, 03:02 PM   #8
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I am all for lightweight, but would never use AL lug nuts.
I've had enough trouble with AL spoke nipples on bike wheels, that I use brass and save weight in the spokes/rims instead.
uspspro is offline   Reply With Quote
Old 10-06-2012, 03:16 PM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'm going to make pewter lugs nutz... That'd by tyte yo! Pewter is da new bling y'all!
:I'm going to go bang my head against the wall now:
Old 10-06-2012, 03:25 PM   #10
Josh B
Buzz Killington
Drives: A slow truck
Aluminum lug nuts are intended to be used only once. When you torque them to the correct setting they stretch, a lot. Personally I don't see the point, just use some quality steel nuts or Ti if you have the money.
Sent from my PC36100 using Tapatalk 2
Josh B is offline   Reply With Quote
Old 10-06-2012, 03:36 PM   #11
ahausheer
Re-member
Drives: Toyota camry
Sorry but one case does not an argument make. Aluminum is too soft, you got lucky.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 10-06-2012, 06:56 PM   #12
GC GTS Aero Kit
These are what I used
BONKRS for life
Old 10-06-2012, 07:03 PM   #13
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i use an impact zip zip zip just right and you shouldnt have any problems, ive never over tightened a nut with my 600 ftlb gun, over tighten with a wrench, i have no faith in you... lol
or you can buy a tq stick for your impact and just got to town, i dont use wrenches on my FRS because the handle comes too close to the body, afraid i will harm something :P
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 10-06-2012, 07:04 PM   #14
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I've used Al nuts for my past few cars with no problems, weren't particularly high end, nor were they the cheapest ones available either. Always want to make a point of visually inspecting them for any flaws, and be sure that its snug in the key. Also, as has been stated never over torque!
edit add: I also use my impact to throw em on usually because its faster lol, but i'll usually hit em with a tq wrench after for the final tightening... I had a friend in highschool who didnt check tq and almost lost a wheel while driving.. 1 nut fell off before we noticed- scary stuff.
Ravenlokk is offline   Reply With Quote
Broken Sun Visor feldy Issues | Warranty | Recalls / TSB 99 10-10-2022 11:33 PM
Heart broken.....Subaru brz FT86FRS CANADA 26 09-09-2012 04:45 PM
Broken window = out of commission. Mitch BRZ First-Gen (2012+) — General Topics 11 09-03-2012 12:04 AM
First brz broken into...sigh zex CANADA 74 08-04-2012 06:17 PM
Broken Window Help! zex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-28-2012 04:54 PM
