Old 10-05-2012, 10:08 AM   #43
KamalT
Drives: Pearl 86 GT
Hi, Just a question,
What is the lifespan of these carbon units??
compare to AL and Steel
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 10-05-2012, 05:58 PM   #44
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
The carbon shaft will hold up forever unless you bang the shaft on something hard it should never fail on you. The steel ujoints will however fail sometime but more than likely after the car has broken down already.
Xanatos is offline   Reply With Quote
The Following User Says Thank You to Xanatos For This Useful Post:
KamalT (10-06-2012)
Old 10-05-2012, 11:28 PM   #45
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I want one
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-06-2012, 07:08 AM   #46
BRAWL
Drives: Toyota 86 GTS Velocity Orange
So....Carbon Fibre Driveshafts....
I changed my 300zx to an alluminium 1pce shaft (stock 2-pce), but as I did it as part of a conversion from AT to MT (including lightened flywheel) it's hard to tell how much impact just the shaft had.
Anyone doing this mod is going to get some noticable benefit and if they feel that warrants the cost of the shaft then it is money well spent
BRAWL is offline   Reply With Quote
Old 10-06-2012, 05:36 PM   #47
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
I would be curious to try out a car that had one back to back. I installed one on my '05 STI and the results were excellent.
TheSt|G is offline   Reply With Quote
Old 10-08-2012, 06:48 PM   #48
Captain Insano
This AT owner is interested* in CF DS development...
*I know some people think ATs are not worth the time to modify and I am not here to disagree with you, everybody is entitled to their own opinion(s). Please let's not take the thread off track. Thanks!! :-)
Captain Insano is offline   Reply With Quote
Old 10-09-2012, 01:15 AM   #49
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
From aluminum to CF? You would notice just about nothing. I'm surprised no one has mentioned what a massive waste of money this is. If you're running 8's or less it can be more beneficial than aluminum or nice if you show your car, otherwise, money down the drain.
GenkiElite is offline   Reply With Quote
Old 10-09-2012, 05:54 AM   #50
BRAWL
Can someone provide a weight for the stock unit versus the CF one?
Old 10-09-2012, 08:19 AM   #51
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
From the 5th post in this thread.
http://www.ft86club.com/forums/showthread.php?t=16029
Old 11-16-2012, 09:09 AM   #52
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
any issues so far? everything is till tight?
Old 11-16-2012, 10:35 AM   #53
gmookher
theres got to be someone who can make a cheaper alum option for those who want less cost/bling
I'd buy this at $800. got one thats a demo, blemished or used?
Old 11-16-2012, 10:59 PM   #54
msile
msile's Avatar
Drives: ISF
Yes sir. 800 miles on it. Running like a champ.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 11-16-2012, 10:59 PM   #55
msile
msile's Avatar
Drives: ISF
Bling? Under the car?
Old 11-17-2012, 10:32 PM   #56
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
Originally Posted by mike2100 View Post
1100 bucks to lose over 10 lbs rotational mass. That's bordering on reasonable (compared to 800-1400 for wheels that drop 12-24 lbs). But I still like it. Props for doing this mod. I could see this on my future to do list, but probably when I run out of other things to do.
Based on the final drive ratio, the drive shaft spins and has to accelerate/decelerate over 4x faster then the wheels/tires. The effective radius of the rotating mass is, of course, much greater on the wheels/tires than it is on the driveshaft.
Either way, having less mass to propel and change the speed of is always a good thing.
Eau Rouge is offline   Reply With Quote
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 01:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 04:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 11:14 AM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 01:40 PM
