Old 10-03-2012, 05:51 PM   #1
jeebus
AutoX with spare/jack in?
I have never taken my spare/jack out of any car when I've AutoX'd. I always figure that little bit of extra weight might help rear traction.
What's everyone's take on this?
jeebus is offline   Reply With Quote
Old 10-03-2012, 07:53 PM   #2
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Less weight is always better. Everyone will agree.
However if I'm lazy I might not take it out either. Depends on what the event is and what I am trying to accomplish. My car is not fully prepped or anything anyway.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
karma003 (10-12-2012)
Old 10-03-2012, 08:30 PM   #3
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
What Blaine said...if you want the extra "stability" weight. Fill the gas tank...Lighter is better..it 35lbs.... plus another 30lbs for the muffler... so that minus 65 lbs right there...
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Old 10-03-2012, 09:40 PM   #4
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Run it with them in, then run it with them out then repeat multiple times... You wont run consistently faster times in one configuration than the other.
Out is directionally correct, but it won't be a quantifiable improvement.
Sccabrz192 is offline   Reply With Quote
Old 10-03-2012, 09:58 PM   #5
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
i leave mine in. its a pain in the butt to take in and out, i mean i'm too lazy to do so
mechaghost is offline   Reply With Quote
Old 10-03-2012, 11:53 PM   #6
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
For racing is as Scooby South said, it's going to be negligible for most.
I can tell you this though, you know when you have a full tank of gas and when you have an 1/4 tank of gas in this car though.
Best bet is to stick with one set-up and learn that. Keep things consistent and it will be easier to learn and improve on.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-04-2012, 12:15 AM   #7
jeebus
Bill
Well I already have a muffler delete...so I'm part way there
Old 10-04-2012, 12:31 AM   #8
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
I could go into calculations regarding 35 pounds located exactly where the jack is in our car and how those pounds would impact the car as it rotates, transitions, brakes and accelerates, but my god that would be so boring.
I'll simplify. If ANY race team were allowed to remove 35 pounds from their car as easily as we can pop 35 pounds out of the back of ours, THEY WOULD HAVE IT REMOVED BEFORE THE INK DRIED ON THE RULE BOOK! Take it out. It's not that hard to do!
Jedi1 is offline   Reply With Quote
Old 10-04-2012, 10:36 AM   #9
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
The trick about weight savings is you don't just think of it in terms of just one item. Yes the jack doesn't weigh much, 1 gallon of gas doesn't weigh much, etc. But if you run minimum gas, light wheels, remove all the junk from the trunk, floormats, glovebox junk, muffler delete etc. this could be over 100lbs. Now if you can't tell when you have a passenger in the car or not, you just aren't going fast enough yet IMO.
While most of us aren't fast enough that we can't run our fastest run on a full tank with all the junk in the car, it is just smart and very easy prep that does help.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-04-2012, 02:26 PM   #10
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I usually take the spare tire and jack out, I also have a muffler delete, lightweight wheels, and run with minimal fuel it all adds up. If I decide to switch from RTR to STX next year, I'll be looking at more weight savings via a lighter battery (20+lbs), lighter brakes, and hopefully lighter coilovers.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-06-2012, 04:27 PM   #11
Vanguard
Drives: Ford F-150 (not for long)
Many clubs require you to pull stuff like that from your trunk. But seriously, why would you not want to in the first place? Weight savings is weight savings.
Vanguard is offline   Reply With Quote
Will u remove the spare tire? Bahraini86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 133 05-06-2019 11:18 AM
Inexpensive spare wheel Captain Snooze Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-05-2012 06:36 AM
Volume of spare tire well? djliquidsteele Electronics | Audio | NAV | Infotainment 1 06-18-2012 12:22 AM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
