Southern California SoCal
Old 09-29-2012, 01:12 PM   #15
tnt
Drives: argento frs at
Originally Posted by drew935 View Post
No, they're not bad for the car. Yes, getting the correct ones as well as ones that are balanced like Swifts or Eibachs will make the car perform proper.
A sample of Tnt's after opti coat, if you don't mind bro.
not a problem at all .... just been so busy haven't have time to post any pics yet
tnt is offline   Reply With Quote
Old 09-30-2012, 02:59 AM   #16
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
I test-drove an FR-S at a dealer with the Tein H-Tech springs installed and fell in love! I have them installed on my car now and it improves the look without changing the ride too much. Very rough bumps are worse, but the normal dips and potholes etc. feel about the same. You can feel a difference when you throw it into the corners!
I would recommend the Tein H-Tech's from personal experience!
KVDB31 is offline   Reply With Quote
Old 09-30-2012, 07:47 AM   #17
_F-R-S_
Drives: 13 whiteout scion frs
Thanks. Just hear about those TRD springs all the time and figured they all were bad
_F-R-S_ is offline   Reply With Quote
Old 09-30-2012, 12:48 PM   #18
PMok
Codename: Stitch
PMok's Avatar
Originally Posted by _F-R-S_ View Post
arnt lowering springs going to be bad for the car? or do you just have to get the right ones? not trolling..
lowering springs can wear out your shocks faster. the lower you go the more it changes your suspension geometry and the OEM shocks were designed to pair with a certain set of springs, the OEM ones. A lot of people accept the risk and get the springs anyways because they want the look, for cheap. Shocks will probably still last a few years even with lowering springs so most people won't care. The "proper" way to lower your car is with coilovers (which are designed to allow adjusting ride height without changing spring rate), or a matched set of springs and shocks (a fixed change in ride height). For instance on my MR2 I added Eibach Pro Kit springs but also upgraded to Koni shocks at the same time. Still no problems some 10 years later...
Old 09-30-2012, 09:10 PM   #19
jflogerzi
jflogerzi's Avatar
wow thats looks nice! Something to shoot for with my Argento FR-S
Old 09-30-2012, 09:25 PM   #20
JAM381
JAM381's Avatar
Drives: 2013 FR-S Asphalt
Wow, serious misinformation I have had two cars a 2000 Celica lowered with TRD springs never had a problem with my shocks and struts and the same goes for my lowered TC with Eibachs after 8 years. Springs will work just fine for you unless you are doing auto cross all the time.
JAM381 is offline   Reply With Quote
Old 10-03-2012, 02:45 AM   #21
shrike92
shrike92's Avatar
Drives: '13 CBS BRZ
I have to agree that it's a risk.
I'm no expert but in any spring&damper system you're going to have unintended dynamic response if you change the spring rate (your spring) but not the damper (your shocks).
Your damping ratio will change, and as such so will the solution to the differential equation describing the dynamic response of your suspension system. If you change the damping ratio enough you could go from a situation where you're critically damped to under-damped (or over-damped). Not that one is better than the other but they each have their own behaviors and some are not desirable for racing conditions.
The caveat here is that you really can't know until you run the simulations but if you're just guessing it could lead to some unintended behavior.
shrike92 is offline   Reply With Quote
Old 10-03-2012, 01:48 PM   #22
KVDB31
KVDB31's Avatar
My understanding is that you are likely decreasing the life of your shocks, even if slightly. Worth it? Definitely!
When you are shopping, look for a note from the manufacturer that states the springs were designed for use with OEM shocks. I've seen that on a couple of them.
The Following User Says Thank You to KVDB31 For This Useful Post:
Itssrayyxd (03-14-2013)
Old 10-03-2012, 04:35 PM   #23
tnt
That's why dealers void the warranty on the suspension
Old 10-03-2012, 08:46 PM   #24
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Save the money from the (IMO UGLY) 5 axis kit and get coils.
Old 10-03-2012, 08:50 PM   #25
BlaineWasHere
Grip>Drift
Drives: FRS
How does AutoX ware out springs?
And having a lowered car on stock struts will ware the struts out faster. It's a fact proven by science. Like many people have stated in 18 million threads on this forum having the stock struts out of their sweet spot will ware them faster. It's a principal that applies to any car.
TRD springs prob have such a mild drop the ware rate on the struts is not increased enough for you to find it unacceptable.
Old 07-16-2014, 11:41 PM   #26
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
Awsome Rims! What size are those and name!
alex345 is offline   Reply With Quote
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 09:57 PM
FiveAxis body kit for OZ?? stevo_12v AUSTRALIA 35 10-03-2012 07:17 PM
FiveAxis denkigrve User/Vendor/Sponsor Reviews, Feedback, Comments 58 09-19-2012 02:22 AM
FiveAxis Kit Shipping GTS86 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:44 AM
New FiveAXIS Raven Wheels on the Scion FR-S Redline360 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 07-31-2012 01:00 AM
