Southern California SoCal
View Poll Results: Who wants EcuTek Flash
Im down, sign me up 12 92.31%
Not interested 1 7.69%
Voters: 13. You may not vote on this poll
Old 10-01-2012, 04:34 PM   #15
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
Originally Posted by Khalis View Post
Meet and Tune at WORKS' place?! Let's go! :happy0180:
we can do that too.. let me run that by him
phenom86 is offline   Reply With Quote
Old 10-02-2012, 12:21 AM   #16
PMok
Codename: Stitch
PMok's Avatar
interested, but don't want to be the guinea pig... will consider it after seeing good results on someone else's car.
Old 10-02-2012, 12:56 AM   #17
Yruyur
Yruyur's Avatar
Does it include the racerom features? Will you be offering e85? On the fly map switching? 0-60 and boost gauges on the dash?
Old 10-02-2012, 11:20 AM   #18
phenom86
phenom86's Avatar
I've sent him the question, hes not a vendor yet on this forum until we finish all of his testing with the parts thats coming available from WORKS.
you serious with the boost gauge?! do you want that with the BOV sound too?
Old 10-02-2012, 11:24 AM   #19
Yruyur
Yruyur's Avatar
Yeah the Visconti has the boost on the gauge. Not that I'm fi but would be an option for others.
Old 10-03-2012, 02:32 AM   #20
shrike92
shrike92's Avatar
Drives: '13 CBS BRZ
Sounds cool, can't wait to see some numbers. I'm stuck down here in So-Cal but it's always good having more data available.
shrike92 is offline   Reply With Quote
Old 10-09-2012, 10:56 AM   #21
phenom86
phenom86's Avatar
Guys, Ive talked to Pete and he wants to hold a meet/flash/dyno day at WORKS. For the first 5 people he will dyno tune for $699.00 for an hour. He will first get your baseline then tune your car, he will take an hour per car.. I need the first 5 to lock down the date... Im looking at Nov. 3
The Following User Says Thank You to phenom86 For This Useful Post:
sdlynx (10-09-2012)
Old 10-09-2012, 11:49 AM   #22
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
What exactly does the tune do that is worth $699? Does it void the warranty? I'm interested but want to see documented facts and figures.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 10-09-2012, 12:38 PM   #23
phenom86
phenom86's Avatar
After they strap the car down to the rollers, they will insert a probe into the exhaust for air/fuel monitoring, and a test lead on the #1 plug wire. After verifying the correct fuel pressure and bringing the engine up to temp, they will start a run up to a specified RPM. There is a computer hooked to the dyno that will tell the operator what your HP and torque was for the run. After analyzing the data on the computer, he will make changes to gain power and torque. Gains are different for every car it all depends on what you have on it like exhaust, intake..etc. I prefer a dyno tune because its catered to your car not a plug and play type flash that its generic, so your gains can be different from another car but both are stock.
There are other topics on the flash but WORKS so far i think will be the first to offer a dyno tune flash..
frsguy707 (10-10-2012)
Old 10-09-2012, 01:57 PM   #24
sf86
sf86's Avatar
Drives: Red Scion FRS AT
this should work with Automatic Transmission right?
sf86 is offline   Reply With Quote
Old 10-09-2012, 02:42 PM   #25
phenom86
phenom86's Avatar
yes, it should.. he will do a dyno pull on 2nd or 3rd gear
Old 10-10-2012, 01:14 AM   #26
russv
First 86
russv's Avatar
Thanks for the info. I thought it was basically a plug and play software change.
Old 10-10-2012, 10:51 AM   #27
phenom86
phenom86's Avatar
I recommend getting a custom dyno flash than a plug and play version cuz you can what you want out of the car, I like HP but our car lacks torque so my goal is to make torque vs HP.. Our cars feels like it has an invisible turbo, damn torque dip
Old 10-10-2012, 12:37 PM   #28
Khalis
Khalis's Avatar
Drives: 2013 Ultramarine 86
Correct me if I'm wrong but aren't tunes the last mod you should get? Or at least after intake/header/exhaust so that you can maximize the performance of how these parts work with each other.
Khalis is offline   Reply With Quote
The Following User Says Thank You to Khalis For This Useful Post:
phenom86 (10-23-2012)
ECUTek Support KamalT Engine, Exhaust, Transmission 12 11-02-2015 12:22 PM
EcuTek options? twincamRob Engine, Exhaust, Transmission 6 09-04-2012 05:14 AM
Ecutek Cable jpit Northwest 0 09-04-2012 01:14 AM
Ecutek Cable brz007 Northwest 0 08-25-2012 06:11 PM
EcuTeK tuning available *BRZ & FR-S* Cotnoir Engine, Exhaust, Transmission 29 07-11-2012 07:15 PM
