#15 | |
Drives: FR-S whiteout
#16 | |
I have both now, 2008 GPW/red interior and 6M white FR-S |
| The Following User Says Thank You to tpolonyi For This Useful Post: | CSG Mike (10-02-2012) |
#17 | |
Drives: Nevermorange FRS
Have fun. |
#18 | |
Drives: '13 BRZ Limited '10 370ZR
I mentioned "modest" miles. For a seven year old car -- there seem to be quite a few 2005s around -- 15k is very low mileage. 30-50K is modest for a car that old. I wouldn't always try to get the lowest mileage one you can find. Sometimes too few miles means you'll get age based maintenance at the same time as mileage based maintenance.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT |
#19 |
Country Boy 4 Life
![]() My S2000. The S2000 = Pure car The S2000 feels more powerful. FR-S = Compromise The FR-S is much bigger and gets better mpg. Both are great cars. Cant really go Wrong with either. I loved the S2000, nothing has been like the 9000 rpm vtec song. But for me and my wife, the FR-S is a more practical car. |
| The Following User Says Thank You to Leonardo For This Useful Post: | veuxx (10-02-2012) |
#20 | |
Drives: A nice one
S2ks are cheap as fuck compared to fr-s's youd have to be on crack to buy a used S2k for 30+ g's |
#21 |
Vtec Jesus
Stock for stock the s2000 would always win on a track, assuming you can take both to their limits. Frs is still a better deal and won't get stolen.
#22 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
You're missing what he's saying. A car originally priced at $37k NEW vs. a 25k NEW car will be very different. A used car is only as good as it's first owner. I would take a better chassis, real roof, warranty, new, slightly less horsepower car with more interior room.
| The Following User Says Thank You to raul For This Useful Post: | hotpanda1 (04-22-2014) |
#23 | ||
I was simply clarifying since it was pretty clear the car is not going for 37k now and the price it was when new while not irrelevant is not very useful without the information about what they are going for now.
#24 | |
Drives: '06 AM V8V Coupe
), but as for power, I think if you drop 25k on a car and are also considering used (aka possible slight problems out of the box) then it's not too much of a stretch to do a little bolton/tune stuff, and the FA20 motor is looking pretty strong. When someone makes some slightly bigger cams for it, cams and tune should let you get very close to S2000 power, if you don't mind doing that.E85 on pretty much stock motor is almost hitting S2000 power, but there's an extra unknown reliability factor there. Tunes leaning out the fuel mix already close the gap quite a bit and massively improves top end power, but without the extra bit of specific torque that E85 gives you'll need power at higher revs. Seeing how the rods are holding up to quite a bit of boost on a high compression engine, it seems like the slight rev limit increase that Visconti is using would probably not be an issue although there's obviously no long term reliability data for that as well. Anyways, just a tune and exhaust closes most of the power gap already which you may want to consider. The torque is pretty strong from 5000 upwards as is, so I imagine cams (when they get made) wouldn't really sacrifice much, as you can land well over 5000 on most shifts. I don't know how well S2000s respond to similar mods, but seeing how it's got 168lb-ft of torque or something on the F20C it seems like there's not much room for improvement on the S2000 engines. |
#25 | |
OP: I've put well over 100k miles on s2ks, so what exactly are you looking for? To answer your question, yes, 200hp does feel rather underwhelming. A lot of people look at specs on paper, and assume that the FRS's 200hp is "only" down 20% from a s2k, but that doesn't tell the whole story. Not only does a S2k rev higher, it's geared FAR more aggressively, and these two facts are rarely conveyed. When you combine more revs, more aggressive gearing, and more power, the difference in torque delivered to the wheels is quite significant. The S2k isn't exactly a quick straight-line car anymore, but it wont have any issue pulling from a stoplight. To put it in perspective, a FRS would have trouble pulling from a current model minivan from a stop, but how many people buy a FRS to drag race?
#26 |
Drives: SWP 6 Spd Limited
I have driven both cars and I went with a BRZ. My reasoning behind my choice was that the S2000 just wasn't comfortable at all for me. I'm 6'1 215lbs. I just couldn't comfortably fit in the car. Same with the 370z. I can sit in them but not comfortably at all. When I saw my BRZ on the showroom floor I thought "no way i'm I fitting in that little car". The roof line honestly comes up to my belly button. Surprisingly though it actually has more than enough room for me. I have plenty of headroom to fit a helmet, enough space to stretch my legs, and with the telescoping steering wheel my arms don't have to be fully extended to steer.
Next to my MKIV this is the most comfortable sports car I've ever driven. Oh, and it gets 30mpg! I say if all you care about is having the best track times maybe go with the S2K, but if you actually want to drive your car everyday... FRS/BRZ. |
#27 | |
Drives: Firestorm Red FR-S
I just don't think its a deal. 40 more HP, but the car is 100lbs heavier. Out of warantee. Unless your finding one with under 30k miles for 18k miles. The FR-S proforms better on AutoX. S2000 are notoriously uncomfortable, and most people don't keep them for every day drivers. Oh and 10+mpg LESS then an FR-S/BRS. This is from Motortrend ""It only has 200 horsepower!" you may be screaming. Yes, but it uses that power respectably, reaching 60 mph in 6.4 seconds. "That's slower than the FR-S!" Yes, but this might've been due to the low number on the odometer. "The Mustang's a second faster to the quarter mile! USA!" Yes, but that gap falls to 0.4 second on the figure eight. The secret? The Mustang spends more time in transitions, giving the BRZ precious catch-up time." I think that shows HP isn't EVERYTHING. Mustang has 50% more HP, but what good did it do? Think about this... Take the S2000's 37,000 USD price tag and spend that on an FRS. Supercharger, Exhaust, Tune, Tires, and tons of extra's and suddenly you have a car with almost the same HP as the Mustang at 50% of the weight. I'm not saying you need to do that.. the car is WIN out of the box. But Slap on a Tune, Exhaust, Pulley, Tires, and you've beat the Mustang in a road coarse, and the S2000, and almost anything else out there. |
| The Following User Says Thank You to RedRocket For This Useful Post: | Jaden (04-19-2015) |
#28 | |
Drives: '03 S2000
http://www.fuelly.com/car/honda/s2000 To the OP, I would probably get the BRZ/FRS if you're dailying the car. The S2000 is really tiring every day. Plus, the upgraded tech and back seat make it much more liveable. I am trying to get my spouse to buy a BRZ/FRS, because they need to replace their daily very soon. I love the BRZ/FRS. If I was in the market for a sporty daily, it would be the twins. For me, the S2000 is my weekend car, which I feel is more of an appropriate niche for it. Therefore, I have to get the "practical" daily. |
| The Following User Says Thank You to IrishInIsengard For This Useful Post: | Darkrune (12-07-2013) |
| FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 04:52 PM |
| E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 10:46 PM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
