Old 09-27-2012, 03:32 PM   #15
jeebus
Originally Posted by RYU View Post
Tires?
still stock. I'm actually surprised how much more capable the tires are at gripping after the alignment changes as well.
Originally Posted by Norkoastal View Post
Newbish questions forming...... Can you tell me what exactly you added and the intended goal? Im always game for a more "pure" alignment and tracking angle for my DD (reduced tramlining or wandering at highway speeds). Are these just track mods or things that made DD more enjoyable and tire wear the same?
Stock front camber is like 0 on this car. That sucks for AutoX/Track use because you tend to roll over on the tires more and get weird wear. it also sucks for people that drive aggressively enough on the street. So I added a set of crash bolts up front and dialed in about a degree of negative camber. Do a search on here for crash bolts...you will find the part #. They were like $9.50 for the pair from Subaru. I initially got it aligned to get my toe in check, because it was possible I got too much front toe in from the camber change. However, since I was on the rack, I got the front set to very slightly toe out and the back to more aggressively toe in, than stock.
I'm very pleased with the results.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
RYU (09-27-2012)
Old 09-27-2012, 04:17 PM   #16
RYU
RYU's Avatar
Drives: really slow...
@jeebus - Interesting on your toe settings. I was actually thinking of doing the same. Was considering going 1mm out in front and 1mm in for the rear but because this is a daily I may start out at 0 and 0. My other car runs 2mm out in front and 4mm in for the rear. I go thru rear tires every <5k miles but it's a point and shoot track weapon
@Norkoastal - Alignment settings get to be much to do with personal preference as you get down into the details. Tire pressure makes a huge difference surprisingly. Just my $0.02 but what RCE recommends as a baseline makes sense; Camber/Toe: Front 1.5/0 Rear 1.5/0 probably a good starting point.
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
Norkoastal (09-27-2012)
Old 09-27-2012, 04:31 PM   #17
jeebus
I'm at 1/32" out (.79mm) front and somewhere between 1/32" and 1/16" in (.79mm - 1.58mm) rear.
We'll see how tire wear is. I don't suspect it will be that bad. This is my daily as well.
Old 10-01-2012, 06:08 PM   #18
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
In regards to the crash bolts you guys are talking about...
Is this 1) the 14mm dia. bolt that goes in the top hole for more play or 2) a lobed bolt for the bottom hole?
Thanks.
2point0 is offline   Reply With Quote
Old 10-01-2012, 06:21 PM   #19
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Thanks.
X2
Norkoastal is offline   Reply With Quote
Toyota Advertising Complaints nzer Off-Topic Lounge [WARNING: NO POLITICS] 21 08-31-2012 08:35 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 11:06 AM
Highway complaints ZetaVI NY / NJ / CT / PA 7 02-10-2012 12:01 PM
For the complaints (changed title) KAuss Scion FR-S / Toyota 86 GT86 General Forum 29 12-01-2011 04:32 PM
