Old 10-01-2012, 10:42 AM   #211
03Z33
drift
03Z33's Avatar
I also had this noise and was following the thread hoping for a solution. Then I had my roll bar installed and the sound is gone. Must be that it's not flexing as much now. Just thought I'd chime in, maybe others will notice this also if they install bracing like a rear strut bar?
I'll try the lube trick if the noise does return, but seems to be good for now
03Z33 is offline   Reply With Quote
The Following User Says Thank You to 03Z33 For This Useful Post:
Sigh-on-Rice (10-01-2012)
Old 10-01-2012, 11:28 AM   #212
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Originally Posted by Sigh-on-Rice View Post
Solution:
Quick and Easy Fix (Might be temporary): Apply a silicon lube spray (i.e. WD-40) inside of the two spots circled in red in the above picture.
Fix done by the dealers in Japan: Adjust the spacing of the two spots circled in red in the above picture to stop them from rubbing.
While I still have a few other noises to fix, the quick and easy here got rid of most of the noise I was dealing with.
:happy0180:
rupert is offline   Reply With Quote
The Following User Says Thank You to rupert For This Useful Post:
Old 10-01-2012, 12:04 PM   #213
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
The proper way to fix this is to install grease fittings into those two panels. That way grease can be added at regular maintenance intervals.
-J
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
The Following User Says Thank You to Jimbo For This Useful Post:
Old 10-01-2012, 12:33 PM   #214
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
I tried white lithium grease since I figured that it'd be longer lasting. I have a 30 mile drive to do soon. I'll report back ASAP.
Jidonsu is offline   Reply With Quote
The Following User Says Thank You to Jidonsu For This Useful Post:
Old 10-01-2012, 01:28 PM   #215
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by Kieranz View Post
Another happy customer. Tried some wd40 last night and no more clicking noises this morning. Good thing as I was going to break out the sledge and center punch tool last night.
Nice!!! Another great result.
That's very interesting and makes sense also.
:happy0180:
Nice!!!
After I got rid of the popping noise, I noticed the "other noise" #5 I posted in my first post.
-- 5 -- The rattling noise caused by the white plastic clips under the foam layer below the trunk liner. LINK
I played around with the foam layer once (push it up, down, left, right, and etc.) and the noise was gone.
Old 10-01-2012, 02:43 PM   #216
shaofis
Drives: BRZ (soon)
Took mine into the dealer to get it fixed.
They told me SOA is instructing dealers to use lubricant to fix this issue.
I'm a little concerned that this is a patch and not a real fix; but we'll see how it goes.
shaofis is offline   Reply With Quote
The Following User Says Thank You to shaofis For This Useful Post:
Old 10-01-2012, 03:12 PM   #217
Sigh-on-Rice
I agree. If it lasts for the life of the car, then it's perfectly fine. But if the dealer needs to be lubing it every so often, then it's definitely not a "real" fix. Maybe SOA is somewhat confident that this patch fix would work for a long enough time, which is a good news in a way.
Old 10-01-2012, 03:17 PM   #218
Jidonsu
White lithium grease did the trick and should last for some time.
Old 10-01-2012, 03:21 PM   #219
Sigh-on-Rice
Nice!!! I'll try that the next time if my car starts to make the noise again. Did you use the spray type? If not the spray type, how did you apply it?
Old 10-01-2012, 03:37 PM   #220
Jidonsu
I used the spray type that has a straw attachment. I just bought a canister of it by Liquid Wrench at the local Harbor Freight. I'm pretty sure the amount I sprayed in there was overkill. Haha. The car will need to air out.
Old 10-01-2012, 04:05 PM   #221
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Wow. Who would have thought it: two squirts with white lithium grease and a good wipe down and suddenly I don't have a single complaint. Life is good!
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Rayme (04-05-2013)
Old 10-01-2012, 04:15 PM   #222
Sigh-on-Rice
Nice. 2 successful people with White Lithium Grease. I updated my first post to add White Lithium Grease as a quick fix in addition to WD-40.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
whaap (10-01-2012)
Old 10-01-2012, 04:17 PM   #223
dsgerbc
Drives: BRZ(sold), STI
Maybe it's durable enough to last between oil changes. And they could add 'lube the rear deck' instructions to the walkthrough they do for regular service.
Old 10-01-2012, 09:31 PM   #224
shaofis
Drives: BRZ (soon)
Went to pick my car up after the dealer's fix and on the test drive the noise was still very much so there.
They kept the car and will be center punching a few welds.
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
