Old 06-10-2011, 03:49 PM   #99
ToyotaObsession
ToyotaObsession's Avatar
Drives: 2008 XRunner
Originally Posted by Maxim View Post
Explain why my tires have stayed at the same PSI without a single leak for 15k then....if it's not the molecule size it must be something.
The same reason mine have stayed at the same psi for 35K. Good tires.
“From the beginning, the concept was to put the driver back in the driver’s seat, and to eliminate computers as much as possible today. Powerful sports cars use a lot of computer technology so that anyone can drive and handle them. We decided not to go down that road.” - Tetsuya Tada
ToyotaObsession is offline   Reply With Quote
Old 06-10-2011, 03:50 PM   #100
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
And if the wheels weren't new wheels, the mounter did a good job scrubbing all the grit and crap off before mounting the new tires on. New tires on a dirty wheel will leak.
tranzformer is offline   Reply With Quote
Old 06-10-2011, 04:39 PM   #101
Maxim
Drives: 2010 GTI 2dr Tornado Red
The tires are nothing special. I've NEVER had tires hold air pressure this well. I will have to test my theory.
Maxim is offline   Reply With Quote
Old 06-10-2011, 05:29 PM   #102
ToyotaObsession
The same ones that came on my car lol.
But that's why tire places have wire brushes and a wire wheel. Newer alloys have a better design than the old steelies too.
Old 06-11-2011, 04:35 PM   #103
Levi
Drives: Toyota
Originally Posted by WingsofWar View Post
This is how id loose weight without to much sacrifice in-cabin comfort
Interior :
- FIA approved recliner racing bucket seats, not because they are light weight, but because i really like the design and materials used over many factory seats has to offer. - $1600 (new) $700-$1000 (used) ~ 40-60lbs
- sparetire/jack/tireiron/ removed - $0 ~ 15-20lbs
- Removing factory sound system and running a simpler system with less wires. $400-$800 ~ 10-15lbs
- Factory steering wheel and front airbags removed, replaced by Nardi steering wheel and quick release by WORKSBELL ~ $150-250 ~ 15lbs
Suspension:
- Light weight wheels, and a low profile tire filled with nitrogen. $1700-$1900 ~ 40lbs
- Control arms resurfaced and drilled. $0 ~ 4lbs
- Cross Drilled / Slotted Rotors for weight savings over blanks than seaching for greater braking performance $250-$300 ~ 5lbs
- Larger+Lighter brake caliper (wilwood would be my first aftermarket search if factory brakes do not satisfy) $1200 ~ 15lbs
- Coilovers (may or may not be save weight) $1200-$1600 ~ 20lbs
Chassis:
- Front and Rear Bumper supports removed. $0 ~ 20lbs
- I would remove the factory sound deadning (most manufacturers use a hardened tar that range anywhere from 40lbs-120lbs depending on the car) and replaced with a liquid base sound deadener, that virtually weighs 1/3 of tar and mat deadners. $250 ~ 30lbs
- Removing Heat shields in the underbody. $0 ~
- Removing Metal in non-flexing joints and locations of the chassis. IE tailgate, wheel well, doors, roof. $0 ~ $20-80
- Carbonfiber hood - $600 ~ 15lbs
- Carbonfiber Trunk - $400 ~ 10lbs
- Drop aluminum gas tank to be replaced with, 8 Gallon Fuel Cell + Aeromotive fuel pump + hardware. $600 ~ 40lbs
Power and Drivetrain:
- Lightweight flywheel - $200 ~ 10lbs
- CNC Lightweight Pullies (crank,alternator,tensioners,AC)- $150-300 ~ 3lbs
- Aluminum driveshaft if a steel shaft from the factory is used. Carbon maybe, but not really interested.
- Full Titanium header back exhaust. $2400 ~ 60lbs
- Odyssey lightweight battery $180 ~ 15lbs
id expect a realistic drop of 250-300lbs with all this...but optimistically 500lbs. I'm really having a hard time gauging a weight loss on the FR-S especially when its target curb weight is competitive with the current Miata at 2400lbs. Id expect to spend anywhere from $4000-$8000 for good weight savings at that level.
+ added weight
+ SCCA approved 10pt roll cage
+ Front 4pt engine brace
+ rear strut tower bar
+ Larger 3way adjustable front and rear anti-roll bar
+ Chassis Brace
+ Transmission Brace
+ Aluminum Transmission Oil cooler
+ Aluminum Radiator
+ Aluminum Oil Cooler
+ AN fitted SS oil cooling lines
+ Stiffer Tranmission and Engine Mounts
+ Aluminum Subframe bushings
+ Stage 2 twin disk Clutch w HD pressure plate
+ Carbon rear diffuser
+ Aluminum Front under tray/splitter
~speculated major weight add ons
Widebody Aero (see sig pic)
This sounds even more hard-core than the latest 911 GT3 RS 4.0 (and is).
But very right. I am going to remove from the FT-86 everything that I do not need and lighten everything I need. I'll only leave the stereo as lightweight configuration seen in some high-end sportscars (McLaren F1). Air conditioner is going to go, air bags also. I mean, there are so many old cars driving around that don't have them, also I had one, and I did not feel missing them. I'll try to build the FT-86 as closest to a bike. A bike has no a/c, stereo, air bags, sound insulation, cup holders, cigarret cinder and so. So should be a fun car.
Levi is offline   Reply With Quote
Old 06-11-2011, 06:59 PM   #104
tranzformer
Drives: Zoom Zoom
Sounds like a Darwin award waiting to happen to me. If you are only tracking your car, sure. But why risk your life in a DD? Airbags help save lives.
Old 06-12-2011, 01:43 AM   #105
ToyotaObsession
Question
Isn't it illegal to remove them on a street car? I know in Washington it's illegal. But I don't know if it's a federal law.
Old 06-12-2011, 04:09 AM   #106
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Well, he's in another country, so maybe it's perfectly OK there (but I highly doubt it).
ryun84 is offline   Reply With Quote
Old 06-12-2011, 07:03 AM   #107
Maxim
Why not just buy a bike? It'll cost half as much and be WAYYY faster. And likely more useful than the car after you're done with it.
Old 06-12-2011, 08:57 AM   #108
Levi
Drives: Toyota
Bike is a different thing. I prefere 4 wheels over 2. A bike is not always faster, it is faster on straight line and on small track, but on the N-Ring for instance a car is faster.
Old 06-12-2011, 08:59 AM   #109
bofa
Drives: Ms. Daisy
That's not necessarily true either.
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-12-2011, 10:22 AM   #110
Levi
Drives: Toyota
My old Alfa 145 Boxer didn't have airbags, and I didn't remove them, in that time airbags were optional.
Old 06-12-2011, 10:26 AM   #111
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
since when can't you remove airbags in America? Sounds like Washington is becoming communist.
chulooz is offline   Reply With Quote
Old 06-12-2011, 05:32 PM   #112
ToyotaObsession
Since this federal law was enacted.
http://www.nhtsa.gov/cars/rules/adap...e_ask_Ques.htm
Photographer's thread Giccin Off-Topic Lounge [WARNING: NO POLITICS] 1169 04-01-2026 09:55 AM
Intoxicated thread #87 Off-Topic Lounge [WARNING: NO POLITICS] 46 04-27-2012 07:17 PM
Joke Thread VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 27 07-09-2011 12:44 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 11:35 AM
