#5881 | |
Site Moderator
Drives: ichi 86 Project
I rather be told, I am the sexiest person they ever met than told the harsh truth LMAO On serious note, most of the time, I rather hear harsh truth |
#5882 | |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
![]() Yeah I'm debating if I should tell my friend the truth or let him be oblivious to the fact.
![]() Walk like a King, Be like a Sir, Swag it out like a Boss |
#5883 |
That Guy
Drives: 2013 asphalt FRS MT
#5884 | |
Site Moderator
Hm... I think, it's up on topic. Some stuff, even it might be harsh, true gotta be told. Some stuff, just leave it be |
#5885 |
Site Moderator
& time for my breakfast, lunch & dinner~
#5886 | |
That Guy
I'm a strong believer that sensors don't just have two operating states, working and not. They get old, and inaccurate. That's why instrumentation technicians are full time employees in any manufacturing plant, to re-calibrate sensors on a regular basis. I had a Neon that was knocking ever so lightly at WOT. In the end the cause was a faulty crankshaft position sensor. I never had a code though. With the way you describe you're driving habits and what I know about toyotas combustion chambers and the BSFC they operate at, I still think you should be doing a little better. But then there's the aerodynamics of a soft top, even up it isn't great. Meh, there's not much a can really do from here and I'm starting to sound preachy so I'll shut up. |
#5887 | |
Drives: '06 AM V8V Coupe
The way I'm driving I would expect something like 30mpg average due to all the cold starting and stuff. I'm considering just buying some Seafoam, but doing the whole vacuum hose thing seems really sketchy. Pouring into the gas tank frightens me, as that seems like it could hurt the fuel system. I suppose that's how all the cleaners go though...is there any safe cleaning method? lol |
#5888 |
Kuruma Otaku
Major League Soccer.
As a hockey fan, how much alcohol will I need for this to be entertaining? Also,@serialk11r. I don't think you understand how much worse it could be. My new Supra has solid motor mounts, the 600 hp clutch I've already bitched about, an aluminum one piece driveshaft that likes to resonate at 3500 rpm, a piggy back fuel controller that is converting from speed-density to whatever a Karman-Vortex needs, and a turbo sized for maybe 450 hp at the crank, but not tuned for it yet and probably only at 300 hp crank, plus a boost controller that seems to start opening the wastegate at under 5 psi. Driveability? What's that. But... Because Supra.
Because titanium. |
#5889 | |
That Guy
I go right to the inlet of the throttle body. It's not gonna be pretty. You're gonna have to hold the throttle open a fair amount to keep the engine running, and if it's working well there will be thick white smoke billowing out of the tail pipe. After you get through the can, shut it off right away and leave it for an hour. Then start it up, run it until the even worse smoke is done then shut it down again and change the oil. |
#5890 | |
#5891 |
@Calum
Okay I looked at my logs, I have no idea what to make of the ignition advance...for one thing, it never went over 36, but then I hadn't revved the engine over 3200 since it was cold...gotta go over more data and stuff later. Idle is at 11 ish which is apparently normal. As I understand timing at low speed is low since there's more time for the charge to burn. EDIT: okay found a few more data points. These are the ones that stood out to me (I have no idea what normal timing is supposed to look like but...) 3700rpm, 85% load, 18 degrees 5200rpm, 79% load, 18.5 degrees. I think my logging is a little wonky, I should check off that "poll all sensors before recording" or whatever option. |
#5892 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Soooo, one of the local bus drivers at my University totally looks like @Giccin...
Momo? Y U NO TELL ME U DRIVE BUS IN MY TOWN???
- The Ancient BRZ Sacrament by Zaku |
#5893 |
Drives: BRZ LZR
@ichitaka05, I love your blog! It's like I see what's going through your mind at the time!
I also need to take you for a ride in a Supra...
#5894 | |
Site Moderator
& yes, I wanna ride in your Supra... maybe next yr summer or spring, when I get off work |
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-21-2014 11:46 PM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
