#29 | |
Drives: FR-S MT
Tire Rack tested them vs all-season and dedicated snows in 2009. Here are some of the results on a snowy surface: 0-60 mph Winter tires - 19.1 seconds All-season - 22.9 seconds Summer tires - 69 seconds 60-0 mph Winter tires - 156 feet All-season - 184 feet Summer tires - 351 feet Even in dry conditions, if the temperature dips close to freezing, the summer tire compound will harden like bubble gum left outside. So if you keep your car inside in the winter, you'll need to keep it inside except on the warmest days. Summer tires - 69 seconds Tire Rack test: http://www.edmunds.com/car-reviews/f...vs-summer.html |
| The Following User Says Thank You to FRiSson For This Useful Post: | WRXGuy1 (09-29-2012) |
#30 |
Drives: FRS
I am going to find roof racks put my snowboard on top and drive the car with stock tires until I have an issue. If I dont have enough traction I will go the snow tire route.
#31 | |
Ninja Cat Mod
With that being sad, the part I bold reminded me when an old friend of mine and his s10. He didn't care how bad the weather got he'd would just go out and drive his truck into or over snowbanks. He would always show me the damage he'd done to his truck when he did that and liked it as if it was something to brag about. SMH. Anyway, I thought I share that.
Education is Important, but Race Cars are more Importanter |
#32 |
Drives: '15 WRX '13 Legacy '07 Colorado
I should'a added a smily to indicate some sarcasm, wasn't trying to say 2wd is better, just poke some fun at 4wd drivers. I also had a 4wd toyota pickup, it was stable as a billy goat, but I live and work in the seacoast so 2wd does the job. My truck is good for 6-8 inches so of heavy and 'round a foot of lighter snow. You're definitely wrong about my truck fishtailing in 18 inches but... cause you can't really fishtail if you're not moving, heh. The Ranger I drove was flat out horrible though, a constant fight to keep a straight line in just a few inches.
Anyway, car, truck, 2 4 or awd, it's really down to picking your battles. As long as someone drives sensibly and keeps the speed down, I think these cars will do just fine in the winter, as good as any other 2wd car. |
#33 |
Drives: FR-S MT
In my experience, the ordinary laws of physics and man do not apply in Rhode Island. Everything is different, surprising and interesting in that state.
#34 | |
Drives: FRS
Its so true RI is strange we sorta do out own thing. Fun Facts Rhode Island was the first of the 13 original colonies to declare independence from British rule, declaring itself independent on May 4, 1776, two months before any other colony. The State was also the last of the thirteen original colonies to ratify the United States Constitution. |
#35 | ||||
Drives: 2012 honda civic ex
just tap your brakes,while downshifting,this should get you home! if you want, ,or HAVE to venture out in heavier snow,you definitely WILL need dedicated snow tires. |
#36 | |
Drives: 2015 Dodge Challenger SXT
#37 |
yes! i totally agree! a car such as a dodge magnum has satisfactory "ballast" in that it is a heavier car,and the more "ballast" you have in slippery conditions,the better off you are.
the weight creates "traction" which with proper throttle control, will be sufficient to keep you moving even when equipped with (a.s.) tires.the roads around andover,and salem get plowed virtually right away,so it is possible if your timing is right, to travel around satisfactorily in a "heavier" car. not so sure about the frs,because it is a very light car,and even with "nannies" could be a "bear" venturing out with (as) tires.i'll bet the "nannies" may make a difference though, if one is careful! we'll see! |
#38 |
Actually overall Lighter cars are better for snow driving, yes heavier cars have more weight to push down on the tires to get traction, however they also need proportionality more traction to get that extra weight moving, plus heavier cars are harder to stop and more prone to slide off the road because their mass keeps them moving more so than a lighter car, at worse case I would say the BRZ will be the same in the snow, but really i'm pretty sure it will be better in the snow than the Magnum was.
#39 |
well i don't agree,however i am hoping the car will be "satisfactory" in light snow travel,so i can get home if i get caught in a nasty one! it's all i am concerned with,get home,and let the plows do their thing! i really don't want to have to spend $1,000 or so for a good set of dedicated snows,but in reality,it's what truly needs to be done to travel under snowy conditions in THIS car! actually,the trick is to get back before the storms hit anyway! he! he! he!
#40 | |
Drives: FR-S MT
However, all other things being equal, the 2,500 lb car will behave much better in the snow as it has far less mass and requires less force to stop. |
#41 |
"ballast",or weight is required,regardless of how it is distributed when traveling in heavy snow.if this was NOT true,then we would have the (frs) plowing snow in the winter? as such,it IS the reason why you see 10 wheel dump trucks "loaded" with "tons" of sand in the back for traction,because if they didn't do this,they WOULD get stuck,and your road would NOT get plowed! the frs should be ok in the light stuff,anything heavier,and you can bet the house,i won't be out in it for the reasons already given,no weight, too damn light,AND the possibility of snow packing up under it,raising the ass end off the ground.
the car is too light,and as such,IF you stop moving,especially in heavy wet snow,it will be very difficult to get moving again,with out dedicated snows. again!..if the snow is light,i don't see an issue,but ANYTHING heavier,and time to call a hook!..just sayin' (b.t.w.) requiring less brake force doesn't mean much,if you cannot get moving in the first place! |
#42 | |
Drives: FR-S MT
A plow requires heavy weight because it needs the momentum to break push heavy drifts of snow. That is not the issue for a small car. However, your advice is sound. If you do decide to fit a plow to your car, you should ballast the hell out of it. |
| Winter Rims | RandomHero | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 11-05-2012 09:06 PM |
| Winter tires | lookout | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-09-2012 05:00 PM |
| winter driving | paraguin | BRZ First-Gen (2012+) — General Topics | 25 | 08-03-2012 06:26 PM |
| For the winter | brichard0625 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-30-2012 05:16 PM |
| Winter steelies | whtchocla7e | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-29-2012 11:21 AM |
