#71 | |
Drives: Skoda Yeti DSG diesel 4x4
High[more] octane = higher power and better[more] MPG. |
#72 | |
Drives: 2013 Raven FR-S
Edit Add: the increase in MPG is marginal, and nowhere near the cost of the higher octane fuel. Last edited by Ravenlokk; 09-28-2012 at 05:22 AM. Reason: addition |
#73 | |
Drives: Supercharged Golf Cart
It's all about the compression ratio. Octane booster for example doesn't add octane, it increases the RATING of octane by raising the point at which it ignites, that's all. How much can I compress this gasoline before it ignites? 87? 89? 91? 93? Boom! No extra octane. Just use wiki if you still don't know, or any of the various websites that will tell you the same. |
#74 | |
"the higher octane get more MPG than the the lower octane in an engine designed to use high octane." |
#75 |
Not with direct injection.
The Mazda CX-5 2L engine uses 91 octane in Oz, the lowest we have but is 13:1 the same as many diesel engines these days. It's tuned to run on low octane unlike the GT 86 which is tuned to run on 98 octane with a slightly lower compression ratio. Both have direct injection. Last edited by sierra; 09-29-2012 at 07:50 PM. Reason: Sounds more polite. |
#76 | |
One more try: the octane rating refers to the point at which the gasoline ignites, or more specifically, its ability to resist early detonation. Nothing you say will change the science behind that, unless physics operate differently in your world...besides your toilets. Instead of continuously arguing, why don't you just google the phrase "octane rating". Everything I have typed will be revealed to you since you don't want to hear it from me. Is it so wrong to try to learn something that differed from your previously accepted knowledge? |
#77 | |
My point is that using a lower octane fuel than the design/tune requires, loses power, raises fuel consumption and could cause engine damage. Using a high octane fuel in an engine requiring low octane will not increase power unless that capability is built in and could burn the valves as the low flame travel rate continues past the exhaust valves. No need to get your knickers in a twist about who knows the most. Interesting that the direct injection Mazda engine uses our lowest 91 octane with 13:1 Does it inject just before the plug fires so that the fuel is ignited before it can be detonated? If that's the case then why would the 86 require 98 octane or is that because it also has the port injection? Last edited by sierra; 09-28-2012 at 09:44 PM. |
#78 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
Thats why Mazda was able to test gasoline engines upwards of 16:1CR on pump gas, and still make very little NoX and emissions, although temps were reaching its limit. From what im told, the SKY-R Rotary will use multi-port direct injection to boost fuel economy and emissions nearly 45% and raise performance upwards of 25%. DI is the way to go for many makers, but so far Mazda's technology is ultimately winning in IRL numbers. Even if the Skyactive Branding is a silly marketing ploy.
#79 | ||
Drives: 2012 honda civic ex
as you "must" burn this fuel,to get the performance designed into the engine. so,to be blunt,we "pay" more to fuel the "beast",with no additional benefit! it's sorta like being f**ked,WITHOUT being kissed first!,if you will! Quote:
may i suggest buying "stock" in the major oil companies? |
#80 |
MODERATOR-SAMA
....welll.....benefits can be slightly argued..
i consider cleaning burning emissions, as a result of engine seeing less knock, and less frequent ECU adjustments, allowing me to see better power at any given RPM, a benefit from using 93 octane. Just as i would with 100 octane. while the benefit-per-dollar might not be ideal, its still a benefit.
#81 |
perhaps,but know that the engine "has" to run on 93 octane,so it shouldn't be
knocking at all if you are burning the correct fuel,ie: 93 octane,and your (e.c.u.) should NOT be making any adjustments either!..i am NOT an engineer,and i would defer to them,but this makes total sense to me! just burn the right gas,and as the aussies say, "no worries!" mate! |
#82 | |
I thought the 13:1 Mazda had just direct injection while the 86 has both direct injection and port injection? http://www.mazda.com/mazdaspirit/env/engine/disi.html What is multi port direct injection? Surely it's one or the other? |
#83 |
Im currently running 91, but i'll be switching to 94 soon. I'm a cheap SoB.. I expense all my gas, and at the moment my work cc doesn't work at stations that offer 94... lol. Free 91 > Paying for 94. I'm sorry FR-S
#84 | |
MODERATOR-SAMA
On the other hand, mazda skyactive uses 1 direct injector to feed 6 ports of fuel per cylinder. They claim its not a spray pattern, more like small multi-spray tubes. ![]() ![]()
| Gas Premium or regular? | Dragon86 | Scion FR-S / Toyota 86 GT86 General Forum | 315 | 06-20-2017 10:14 PM |
| FRS arrival for regular customers question | NWIguy | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-05-2012 08:54 AM |
| Anyone have a pic of the regular seats? | DuMa | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 12-14-2011 12:29 AM |
| So is it a hatch or regular trunk? | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-09-2011 07:26 PM |
| Consequences to Adding Regular Gas? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-06-2011 12:52 AM |
