#15 |
Drives: 2013 FR-S Asphalt
#16 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Swift
#17 |
Drives: 2013 Subaru BRZ
Lower than the sportlines? At that point you really should be considering coilovers, if you care about preserving the handling.
As JoeBoxer said, anything over 1" and you might start to worry about negative effects on handling and tire wear. |
#18 |
#19 | |
Drives: 13 fr-s whiteout
Tein s-tech 1.5 drop This is as close as your going to get to coilovers. Any lower and your in big long term trouble.
I'll be back!!
#20 |
Drives: Scion FR-S Raven
did you have to use a camber kit in the front with the eibach sportline?
#21 |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
#22 |
Drives: DC5
I generally dont recommend lowering springs, but if you must i would only suggest Swift springs as they specifically engineer each application to suit the stroke range of the factory damper. They are the most widely used springs in of all pro racing in Japan as well as many Le Mans race teams and Nascar teams secretly switching over to Swift springs.
Heres some more info on their springs and their benefits http://swiftsprings.com/faq.html |
#23 | |
Drives: 2013 FR-S Whiteout
#24 | ||
#25 |
#26 |
According to other sources, the BRZ fronts are stiffer and rears are softer compared to the FR-S?
http://www.ft86club.com/forums/showthread.php?t=8739 http://********.com/forum/showthread...S-Spring-Rates Either way, good to know it's based off BRZ rates.
#27 | |
--Dan Mach V |
| STI BRZ springs now available | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 12-02-2012 11:57 AM |
| trd springs or no? | FT86R | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-30-2012 03:52 PM |
| Springs??? | Ashley | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-23-2012 11:15 AM |
| STi Springs | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-14-2012 01:19 PM |
| Springs rates for BRZ and FRZ? | Evil86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-30-2012 10:35 AM |
