Old 09-27-2012, 12:34 PM   #29
Hanakuso
I just got a reply back from Japanparts. They said they cannot offer a group buy discount since they are already having a 10% discount right now. I guess we could still do a group buy ourselves to save on shipping cost, but since Nigel is researching this, maybe that is the better route.
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
ayau (09-27-2012)
Old 09-27-2012, 03:38 PM   #30
ayau
Drives: Some rust bucket
we need to verify that the USDM models have the predrilled holes. unfortunately, i can't verify myself because i don't have a lift.
Old 09-27-2012, 04:32 PM   #31
Hanakuso
Perrin did awhile ago but didn't confirm 100% which part numbers we need. It looks like the side we get isn't even the full version
Originally Posted by PERRIN_Jeff View Post
Now under the car.You can see the shielding under the car and panels installed to help keep the air flow smooth. What you can't see from the picture is how thick the pieces are.
1- Large plastic shield- This is like most plastic splash guards, a little flimsy, but it does the job.
2- Thick Aluminum Panel- This piece is impressive. Its a skid plate more than anything because of how thick it is. At nearly 1/8" thick this piece is almost designed to be jacked up on. But its not. It was done to protect the super low engine and header. Other cars from Subaru do not have this, but that is because the engines are not as in danger of being damaged under normal driving conditions.
3- Fiberglass woven nylon panel- Almost like cardboard but its not. Another splash guard, but since its close the exhaust, its made from a material that will not melt over time.
4- One plastic under panel- This is the other cool part. The problem is its only on one side. In Japan, the BRZ comes with full under body paneling. We only get half that material. Best part is there are threaded holes on both sides to accepct the JDM parts
Old 09-27-2012, 04:50 PM   #32
ayau
yeah, that piece just covers the brake lines. i'm gonna guess that you have to remove the stock piece before installing the jdm aero pieces.
i also see some holes on the middle rail. maybe that's where the bolts go.
Old 09-27-2012, 05:36 PM   #33
Hanakuso
Yeah I agree. Hopefully we can confirm if we have 3 rows of holes/screws on right/left side to fit the full panels.
Just thinking about it, a side benefit of these panels might actually decrease road noise and they will keep our underbody cleaner. Last time I went under my car I already noticed I was getting black spots everywhere
Old 09-27-2012, 07:13 PM   #34
ayau
yep. totally agree.
Old 09-28-2012, 09:44 PM   #35
zkubidu
Drives: SWP BRZ
I confirmed on my BRZ that the corresponding panel holes and screw holes are at the respective positions. I jumped the gun and ordered mine. Feel free to wait until I receive my kit to confirm fitment. Will keep y'all updated.
zkubidu is offline   Reply With Quote
The Following 8 Users Say Thank You to zkubidu For This Useful Post:
ayau (09-28-2012), civicdrivr (09-29-2012), Hanakuso (09-29-2012), ill86 (09-30-2012), johnb831 (09-30-2012), KGFRS86 (09-30-2012), Ro_Ja (09-29-2012), TuxedoCartman (10-22-2012)
Old 09-29-2012, 12:29 AM   #36
ayau
here's another pic of the underbody panels.
The Following User Says Thank You to ayau For This Useful Post:
Norkoastal (09-29-2012)
Old 09-29-2012, 07:58 AM   #37
denverizzles
i know people are looking at this from a performance perspective, but do how you these will hold up during snowy winters? could it also be used to protect the undercarriage from rust?
denverizzles is offline   Reply With Quote
Old 09-29-2012, 09:26 AM   #38
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I'm up for a group buy, I think these will help keep the undercarriage from getting damage. At least minimize it, plus they look cool
Asphaltfrs1 is offline   Reply With Quote
Old 09-29-2012, 11:34 AM   #39
Turbowned
Turbowned's Avatar
Now someone just needs to make a center section to cover off the exhaust and driveshaft. Aftermarket, are you listening?
Well, it's gotta be better than having nothing there at all. It'll protect the underbody finish from getting pelted with sand and salt.
Old 09-29-2012, 03:59 PM   #40
Hanakuso
That might be a bad idea since a lot of the items it would cover need proper cooling. The exhaust/cat might end up heating up the tranny, diff, etc too high
Old 09-30-2012, 12:48 AM   #41
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
Interested. But anyway the dealerships can order these for us?
jflBRZ is offline   Reply With Quote
Old 09-30-2012, 08:51 AM   #42
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
On the other hand, it'd suck if salt could get trapped above the panels (and thus be more difficult to wash away). I can't tell from the photos if that'll be a concern.
BTW, I wouldn't expect much in the way of fuel efficiency gains, but there will be a little on the highway. Force from drag:
F = 1/2 * p * Cd * A * v^2
p = air density
v = velocity
A = cross sectional area
Cd = drag coefficient
According to edmunds:
"There's more to aerodynamics than just drag," says Doug Frasher, strategic design chief at the Volvo Monitoring & Concept Center. "There's downforce and lift. And there is yawing moment, which is basically when you're in a crosswind, how much does the vehicle get steered by the wind that is pushing on it? And then there's noise. So we try to look for all of those factors.
"For a full-size truck, a change in drag coefficient of 0.01 is approximately equal to an improvement in fuel economy of 0.1 mpg on the combined city/highway driving cycle," says GM's Schenkel. "The same drag coefficient reduction can improve a car's fuel economy by approximately 0.2 mpg."
I assume it's a negligible difference city and ~0.4 MPG highway. The FT86's improvement might be marginally more.
Anyone know if these panels noticeably reduce wind/road noise?
Deslock is offline   Reply With Quote
Brz Limited Avalable (currently wait listed, but soon. This is not an add.) Floggin Tires Great Lakes 2 09-25-2012 01:13 AM
Japanparts.com Review Sportsguy83 User/Vendor/Sponsor Reviews, Feedback, Comments 7 08-03-2012 09:23 AM
Cars.com has BRZ's listed??? Rick Boxx BRZ First-Gen (2012+) — General Topics 0 05-13-2012 02:36 PM
Listed on Autotrader (US) cassidy0998 Scion FR-S / Toyota 86 GT86 General Forum 3 02-02-2012 11:16 AM
FR-S Officially Listed on the Scion Site goshamrocks13 Scion FR-S / Toyota 86 GT86 General Forum 32 10-07-2011 11:52 AM
