Old 08-26-2012, 01:59 PM   #29
Nubbs
Nubbs's Avatar
Originally Posted by Deslock View Post
From the photos, I'm guessing that the 48" bars are just a little too short. Did the end caps come installed on the bars, or are they hard to remove? If not, I might shorten the 58" bars to be flush with the towers (using a pipe cutter or
Having written that, it looks fine as is. I plan to add a rack in the Spring.
You could easily shorten the bars up after you have it fine tuned. I simply roughed mine out and threw it up there. You could most likely get away with 48" cross bars, the distance between the rear towers is just over 43" which leaves a little under 2.5" inside the rear tower. I'd personally just go with the 58" bars and cut them flush which is what I'll do before it goes back up. And clear vinyl where the feet go to prevent wear and tear. If mounted on a clean roof not removed regularly, wear will be minimal if any. Still a cheaper investment to just protect your paint from the start than fixing it later on.
Nubbs is offline   Reply With Quote
Old 08-26-2012, 11:21 PM   #30
dietz
Drives: Raven / 6MT FR-S
Originally Posted by Bounce View Post
I'm gonna try put a kayak on top
Ditto. I thought my Jackson rockstar might fit inside, (it fits in a fiat 500, 2dr civic, Saturn sl1 and other small cars) but it doesn't. Maybe a medium or small would, but not the large. On the roof is probably better anyway.
dietz is offline   Reply With Quote
Old 08-27-2012, 09:29 AM   #31
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
That's pretty awesome.
Making the car work for your needs is what it's about.
Spd229 is offline   Reply With Quote
The Following User Says Thank You to Spd229 For This Useful Post:
Jon H (01-31-2013)
Old 09-11-2012, 11:14 AM   #32
CliffG
Driver
CliffG's Avatar
Drives: 2013 FR-S, Whiteout
@ NUBBS: any problems so far?
@ FOOBAR: no hitch; UHAUL says maybe Oct/Nov & say if you drive to Phoenix they'll fabricate a prototype FREE
Cliff
Wherever you go, there you are.
CliffG is offline   Reply With Quote
Old 09-24-2012, 11:42 PM   #33
Looker_007
Looker_007's Avatar
Drives: Firstorm A/T
Well I'm not waiting.
Got a scrap yard hitch off a 97 Toyota van, cut the frame mounting ends from it, drilled holes through it to bolt to 2 eyebolt/towhooks from scrapped WRXs.
It's at my powder coater now.
Looker_007 is offline   Reply With Quote
The Following 10 Users Say Thank You to Looker_007 For This Useful Post:
Alabang 86 (05-07-2013), avusblue (09-26-2012), Deslock (09-25-2012), dietz (09-25-2012), FrX (09-25-2012), Khyron686 (09-28-2012), Pete (01-08-2013), QFry (09-26-2012), Spartan65 (09-26-2012), ultra (05-04-2013)
Old 09-24-2012, 11:47 PM   #34
Looker_007
Looker_007's Avatar
Just have to figure out where to connect the brake lights to the trailer wiring, the turn signals and running lights are done.
Old 09-26-2012, 01:50 PM   #35
wheelhaus
wheelhaus's Avatar
Nice that is exactly what I'm hoping to do over the winter, but I have some friends who can weld so I may have to commission them to help with the assembly...
Old 09-26-2012, 01:59 PM   #36
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I can see it now towing my Go Kart to the track with my FRS
like this.
Spartan65 is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartan65 For This Useful Post:
TJ3000 (05-04-2014), ultra (05-04-2013)
Old 09-26-2012, 08:38 PM   #37
CliffG
Driver
CliffG's Avatar
Not For Purists
The Yakima roof rack (with ends of bars cut off) is functional & my bike is happy on it. The esthetics po-lees have not pulled me over yet.
Cliff
The Following 2 Users Say Thank You to CliffG For This Useful Post:
brzr (07-08-2014), Tomcat07 (07-11-2014)
Old 09-26-2012, 09:48 PM   #38
ccoley
Drives: Asphalt FRS
I bought a SeaSucker rack a month or so ago. It works flawlessly. I've driven from Toronto to Ottawa (4.5 hours) doing 130km/hr almost the entire way with no issues at all. Takes a few minutes to install and 30 seconds to remove.
I can't stand the look of these clunky racks on top of a sports car. I'd be afraid of scratching the paint.
ccoley is offline   Reply With Quote
Old 09-28-2012, 12:22 PM   #39
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Picture with and without bike please (:
Tylub is offline   Reply With Quote
Old 12-08-2012, 09:01 AM   #40
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
How's the roof rack treating you so far?
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 12-13-2012, 11:53 PM   #41
inimitable
inimitable's Avatar
Drives: SSM 6-MT limited
Looks sweet.
Just wondering how much the total cost of the rack and whatever other components needed ran you OP?
...also, if you don't mind pointing me in the direction that you found all of that stuff?
Thanks in advance
inimitable is offline   Reply With Quote
Old 12-14-2012, 08:09 AM   #42
White64Goat
I believe in the owners manual it says that this car is NOT to be used for towing. Must be a reason why they'd write that in there.......
That set-up above on Looker is a lawsuit waiting to happen when that mishmash comes apart. Tow hooks are not designed to be used as a tow hitch attachment point....
From page 222 of the BRZ owners manual:
SUBARU does not recommend towing a trailer with your vehicle. Your
vehicle is not designed for trailer towing.
anyone fit a bike rack yet? earthsscum BRZ First-Gen (2012+) — General Topics 108 05-26-2019 11:39 AM
Factory Roof Rack? \o/ Scion FR-S / Toyota 86 GT86 General Forum 92 02-15-2013 03:25 AM
Eibach Pro-kit from tire-rack Z86 AUSTRALIA 0 07-13-2012 06:14 PM
Brz limited on the rack at tire rack Nate219BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-06-2012 03:01 PM
Tire Rack still needs a BRZ! Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-12-2012 02:35 PM
