Old 09-25-2012, 06:27 AM   #29
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I imagine a small bump to a WRX 16mm rear bar along with Sam's front bar wouldn't be too dramatic of a change and might work quite nicely.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 09-25-2012, 08:27 AM   #30
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by simpleisbest View Post
Rear? You mean front, right?
Ooops! You're right, I made a typo. No rear bar for now haha
Fixed it... I dont know what mistake you're talking about :P
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
simpleisbest (09-26-2012)
Old 09-25-2012, 08:53 AM   #31
QuikJ
Drives: '13 Subaru BRZ
Depending on the class. IRC, stock class you can only add one bar.
QuikJ is offline   Reply With Quote
Old 09-25-2012, 09:59 AM   #32
Kido1986
Dodging cones
Kido1986's Avatar
Yeah, one bar only.
Old 09-25-2012, 10:01 AM   #33
xwd
PM'd you Sam.
Old 09-25-2012, 11:10 AM   #34
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
That's a very dramatic change. I don't think you want to try that until you get a front on. I don't want a bigger rear bar at this point myself.
Sam Strano is offline   Reply With Quote
Old 09-25-2012, 05:09 PM   #35
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
I would only experiment with the WRX bar with your bar sitting on the front. I believe Bill Cook tried a bigger rear bar and the car was all over the place. I guess we'll see what happens and how the handling feels with yours on then I can always pick up a WRX rear for cheap to play. I understand that Stock only allows 1 bar but it still could be fun and not that hard to remove I'd imagine.
How hard is it to remove the front bar on these cars? My old G8 was a PIA to remove the front because you had to pry up power steering hoses and rotate the bar a billion times before it would come out.
Old 09-25-2012, 08:14 PM   #36
mike2100
mike2100's Avatar
Drives: 23 BRZ
Any comments on getting spring rates and damping right before tweaking with anti-sway bars?
mike2100 is offline   Reply With Quote
Old 09-26-2012, 11:15 AM   #37
Sam Strano
Sam Strano's Avatar
The front bar is not bad. Really the biggest pain is taking off the underbody panels and all the bolts there. The bar itself is not hard (though it helps a lot if you have wobble extensions).
Old 09-26-2012, 11:25 AM   #38
Sam Strano
Sam Strano's Avatar
Depends. In stock class you cannot change springs at all. Damping doesn't control bar like it does spring rate. Bars aren't damped by shocks at all. Bars will change balance, but again shocks don't change actual balance of the car they change the rate at which things happen (like how fast the car generates roll and pitch, or takes a set).
Old 09-26-2012, 11:46 AM   #39
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I agree with Sam but maybe to phrase it a little different...
The purpose of the sway bar is to increase the corner spring rate during maneuvers where the two sides of the car (left/right) are functioning independently (rolling/pitching during cornering). If you plan to significantly increase the spring rates of the car, you will need to reevaluate the need for the sway bar based on your desire for the way the car handles. If you go to a very high spring rate, and leave a stiff bar, the car will be very likely to skip or hop over undulations during cornering, which is undesired. As you increase the spring stiffness, your need for a sway bar will decrease and you should reduce the size appropriately based on the cars attitude. If you do a modest spring rate change, chances are you will feel the car "handles better" with the bar + the springs because you didn't go very aggressive. From my understanding, Sam has sized this bar to be a modest rate increase, such that it can be used in a variety of applications... sounds like to be suitable for both the stock and ST crowds
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
mike2100 (09-26-2012)
Old 09-26-2012, 01:10 PM   #40
Sam Strano
Sam Strano's Avatar
More progress..... We have the bushing thing worked out on production, just need to get them made. Down to details now. I am hoping we have bars ready to roll by 10/19. Fingers Crossed.
The Following User Says Thank You to Sam Strano For This Useful Post:
Old 09-26-2012, 02:50 PM   #41
mike2100
mike2100's Avatar
Drives: 23 BRZ
Ah, sorry. Autocross never enters my mind when I think of this stuff
Old 09-26-2012, 06:50 PM   #42
simpleisbest
Senior Citizen
Drives: Scion FR-S
That would be awesome!!! Fingers crossed here, too!
simpleisbest is offline   Reply With Quote
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 09:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 07:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 07:52 PM
