#71 | |||
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Besides, the compressor (be it SC or turbo) is always going to be putting our more air than the engine could ingest as an NA in any performance situation (WOT, high RPM etc). So none of them are really a restriction on the intake side of things. What Mandalay was getting at, is that turbos are essentially a huge restriction on the exhaust side. When you put a turbine into a fluid flow, you are converting energy from one form to another. In this case mechanical energy to spin the compressor and compress the intake charge. That costs energy. The exhaust flow is restricted and the exhaust gas pressure (and corresponding EGT) is much higher before the turbine. The heat will transfer to the combustion chamber and bring things closer to the knock threshold. I'm definitely not bashing turbochargers here, just that so many do not truly understand them, nor do they understand superchargers. I am waiting for a certain Rotrex based kit. I was going to develop one, until I found out my intended supplier is making a kit. Anyway :happy0180: |
#72 | |
Drives: 2013 raven black fr-s
I can go into a full thermodynamics lesson, as to why the nominal difference in engine temps at the same boost levels would not be a deciding factor on this car with a properly sized IC. |
#73 |
I do agree with one thing though, that SCs are more efficient on a thermodynamics basis.
#74 | |
#75 |
Drives: 2013 Scion FRS
USPSPRO, can you elaborate on who and when?
"I am waiting for a certain Rotrex based kit. I was going to develop one, until I found out my intended supplier is making a kit." I find the above sentence intriguing.
Scionara to you
| The Following User Says Thank You to Alienate For This Useful Post: | JoeBoxer (09-25-2012) |
#76 | |
If you don't mind me asking, why did you choose a rotrex kit? I've never had a car with a rotrex, only one with a centi and one with a roots. |
#77 |
Drives: honda civic si 08
I don't even understand what is being argued here. a SC at 8 psi will make the car feel much smoother and linear than a TC'd car running at 8psi. The only reason to ever choose turbo over sc is for more power.
| The Following User Says Thank You to catharsis For This Useful Post: | gmookher (10-13-2012) |
#78 |
Drives: SSM LT MT BRZ
OMG
I hate this stuff. 8psi is not 8psi, 8psi @ 120degrees is alot less air than 8psi at 90degrees....for starters....more TC engines have intercoolers than their SC bretheren, this is because alot of SC are Eaton roots style positive displacement and they are less friendly for air to air intercooler packaging, centrifugal SC's on the other hand can be plumbed just like a TC as far as intercooling is concerned. 8psi on a SC engine at the same temp as 8psi on a TC is close to the same thing but the SC will be down several % due to belt driven pulley losses. this is the advantage of a TC, all you lose is exhaust gas temperature at the tailpipe. as far as turbos being a restriction...a well designed system doesn't increase exhaust manifold pressure until well after there is a gain in intake flow, this is why real R&D pays attention to exhaust vs intake manifold pressure, to help determine and maintain engine scavaging and cross flow...and lets not forget that increased pressure in the exhaust manifold...translates into torque applied to the compressor wheel....translates into more compressed air... I have yet to see a SC motor match or better a turbo all the way across a map. there are advantages to both (except centrifugal...those are a waste of recycled beer cans...only good for people that don't want to properly design a FI system.) for a motor this size with this rev range turbo makes more sense...until someone wins the race to CVT driven SC's... |
| The Following User Says Thank You to SkullWorks For This Useful Post: | Alienate (09-26-2012) |
#79 |
When did this become an S/C vs. turbo thread? Jeez...
I do wish someone would develop a roots-style supercharger for this kit. We already know it fits, so someone doooo eeeet! Both my MR2 S/C and Audi S4 used roots blowers and they had THE best powerbands of any cars I've owned; my N/A and turbo cars couldn't touch 'em for responsiveness and power delivery. Basically, if someone can recreate a dyno plot like this with an S/C, I will be drooling. We're down a liter of displacement and up a point-and-a-half on compression, but who knows?
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#80 |
Drives: tata nano
^I dont know much about the different SC types, but I agree. Maximize that throttle response and powerband using the best technology available. I'm sure any company going the SC route will try to maximize appeal and push their advantages.
#81 |
I got this out of a Rotrex from the lowly 1zzfe that originally made 125 rwhp/ 125 tq. This is a DD setup on CA 91-octane piss gas.
![]() The throttle response (not shown on a dyno) was excellent, and the feel was soooo damn smooth. Felt like a giant superbike. |
| The Following User Says Thank You to uspspro For This Useful Post: | JoeBoxer (09-26-2012) |
#82 |
Drives: DGM BRZ Limited
A roots style SC with a proper A/W setup can work really well and make good power. A well designed turbo setup will make more power, with arguably more complexity.
What people often overlook is pressures. This is an NA engine, and cam profiles are designed as such. Get the backpressure to boost ratio right, with proper cam timing, and it will (and does) make huge power. Dial the overlap to keep pressures just right and you can get great results. With superchargers you don't have to worry too much about pressures, until you start getting boost blow-thru during overlap. Which should easily be tuned out with the cam actuators. There's a lot that goes into tuning. Not everyone is going to be pleased with every setup. But thats why its great to have options. If you can make 300whp with a roots on this platform it will be intense. |
#83 |
you will all be very happy with what you will find out at sema
mums the word till then Last edited by gmookher; 09-26-2012 at 11:42 AM. |
#84 |
Drives: 05 Ford F150 Scrow
TC or SC, in my opinion it all goes back to the individual. Bothe have Pros & Cons. Bothe can be fitted with IC, Air To Air or Air To Water.
It all depends on the design of the system. I say see the dyno chart and decide if it is ok for you or not. I say the man 2 design is Posited Vs Centrifugal. Positive will deliver a fixed amount of volume pear revolution, and centrifugal will double the speed and the volume quadruple. I believe on centrifugal SC or TC using the same compressor and housing, the dyno chart should be extremely similar and close. For me When I can afford a 86 (not in the near future), I would want something like the Edelbrock E-Force system. A TVS Eaton charger with Air to Water cooler. At the end to each his one. Last edited by Shiny; 09-30-2012 at 05:03 AM. |
| Supercharger or Turbo ? | #87 | Forced Induction | 192 | 01-25-2013 11:20 AM |
| HKS Supercharger getting closer | gtauto | AUSTRALIA | 166 | 09-03-2012 08:11 PM |
| TRD Supercharger anyone?? | poormans_LFA | Engine, Exhaust, Transmission | 48 | 04-28-2012 12:42 AM |
| Supercharger for Infiniti G25 | Lottta | Other Vehicles & General Automotive Discussions | 2 | 02-12-2012 10:10 PM |
