Old 09-25-2012, 05:05 PM   #29
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I swapped all the fluids in the car today, 300V in the engine, Gear300 in the transmission and rear end. Happy to report the shifting feels much smoother and less notchy.
The job was very easy too once you take the transmission guard plate off.
To do the differential and rear end all you need is a 10mm allen socket. The Motul bottle has a little filler built into it, that makes the job pretty easy.
Adam
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
MattR (09-26-2012)
Old 09-25-2012, 05:11 PM   #30
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Adam
is it easy to do the tranny and diff fluid change on my driveway with 4 jackstands
Old 09-25-2012, 05:19 PM   #31
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I was wondering the same thing.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 09-25-2012, 05:57 PM   #32
No Limit Motorsport
If you can get the car high enough in the air, it should be straight forward
Old 09-25-2012, 10:09 PM   #33
Skye
Drives: TR2,CooperS,BRZ
Has anyone used GL 5 75W90 in their transmission? Or subaru special - S STI oil?
Skye is offline   Reply With Quote
Old 09-25-2012, 10:20 PM   #34
roddy
roddy's Avatar
Drives: '13 Ultramarine
I would try to avoid a GL-5. GL-4 should be safe.
I did mine on jackstands...no problems.
The Following User Says Thank You to roddy For This Useful Post:
Skye (09-25-2012)
Old 09-26-2012, 02:33 AM   #35
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Posted a couple questions on your facebook page, how do you like the 300v now that you have put it in the car? I'm probably going to try it next time at 7500 miles and do the rear diff fluid at 10k.
Old 09-26-2012, 07:56 AM   #36
No Limit Motorsport
If you guys read the manual it says use GL-3 or higher fluid. People are getting hung up on the GL-3 thing. Anything GL-4 is perfectly fine.
F1point4 (09-26-2012)
Old 09-26-2012, 10:54 AM   #37
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Thanks Adam for the clarification. Just for further clarity, my FR-S manual and the BRZ service manual (Page 50) on this site http://www.ft86club.com/forums/showthread.php?t=8374 say GL-3 standard.
Despite the differences, I'd put my faith in Subaru's technical writers since they build the cars.
Here is the page from my FR-S manual.
FRS_MTF_Recommendation by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
roddy (09-26-2012)
Old 09-26-2012, 07:18 PM   #38
roddy
roddy's Avatar
I read the manual and mine reads like the 2nd one posted... As I said above, GL4 should be fine. SOME GL5s are ok, while others contain additives that are not friendly to "yellow metals" (like brass) that are used in transmission synchros. To be safe, I would only use a GL5 oil in the differential.
Old 09-26-2012, 08:22 PM   #39
gmookher
search the forum for pentosin
Old 07-31-2013, 08:42 PM   #40
diss7
Drives: AE86, 2x GT86, TE27
Bringing a thread back from the dead,
But, its funny how every one attacked OP , yet TRD fluids being supplied in NZ, are pretty well bang on with what OP was thinking of using.
Seeing as TRD oils are basically a premium factory option, it would take a fair bit of confidence to say that TRD are wrong.
Link for reference http://www.ft86club.com/forums/showthread.php?t=29022
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
CSG Mike (07-31-2013)
Old 08-01-2013, 10:54 AM   #41
bluesubie
Drives: 2004 Subaru Forester 2.5XT
IMO the OP wasn't attacked for using Motul, but for asking about X-cess 5W-40 which is not a good idea unless you have an engine built with bearing clearances that spec XW-40. He's also using a crazy thick 75W-140 viscosity in the rear diff. Yes, sometimes people are a bit too harsh.
I think you're just showing off that Kiwi's get this new special API SN Motul 0W-20, while we still have the old API SM Motul Eco-lite 0W-20.
-Dennis
bluesubie is offline   Reply With Quote
Old 08-01-2013, 05:06 PM   #42
diss7
-Dennis
The trd diff oil is 75w140..
And so we should get the best stuff here, after all they charge us 50-100% more for things that you guys get! Ha ha $45k for car, $2.50/L for gas etc.
Motul Oil's & K&N oil filter deals! No Limit Motorsport Mechanical Maintenance and Tools 1 09-18-2012 02:20 PM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Fluids change after break-in yomny Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-05-2012 01:18 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
