Old 09-22-2012, 03:33 PM   #1
BRZranger
Roll center location? :iono:
Anyone smart / resourceful enough to figure out and diagram where our car's roll center location is on stock, 20mm drop, 1" drop, and 1.5" drop?
BRZranger is offline   Reply With Quote
Old 10-01-2012, 03:09 AM   #2
DEnd
Drives: anyone seen my steering wheel?
Yeah I'm smart enough to do it. But I'm not gonna... Simply because I don't have the measurements.
DEnd is offline   Reply With Quote
Old 10-01-2012, 08:39 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
educate yourself and obtain the resources
Old 10-01-2012, 08:58 AM   #4
speed-wiz
speed-wiz's Avatar
Drives: MR2
CG calculation
speed-wiz is offline   Reply With Quote
Old 10-01-2012, 06:07 PM   #5
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Not the same thing.
SubieNate is offline   Reply With Quote
Old 10-18-2012, 08:10 PM   #6
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Bump!
This is an important topic. In the VW world there was a lot of information about this and parts to correct the roll center for various levels of drop.
Are all of these suspension "vendors" are marketing parts without good R&D?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-19-2012, 06:41 PM   #7
SOneThreeCoupe
Drives: 1992 Nissan 240SX
My guess is that Sam Strano probably has the measurements and more likely than not the roll center location for both stock and at his ride height. Failing him, there's always Scooby South and Sccabrz192.
Given the fact that nothing has ever been good enough for me, if I had access to one of the cars I'd have all the measurements for you.
SOneThreeCoupe is offline   Reply With Quote
Old 10-20-2012, 11:21 PM   #8
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
Look at your lower control arms and imagine a line going from the outboard LCA's going inboard pass there mounting points until they intercept and that's your roll center. Now go get a protractor and go get some measurement.
WillRacer1jz is offline   Reply With Quote
Old 10-27-2012, 11:59 PM   #9
DEnd
Umm... No.
On the front draw a line through the lca and another on 90 degrees off the strut mounting point. Where these two lines intersect is the instant center (IC). Draw a line from the IC to the center of the contact patch. If you do this for both sides where the IC to contact patch lines intersect is the front roll center.
For the rear draw lines through each of the control arms where the same side lines intersect is the IC. Like the fronts draw a line from the IC to the center of the contact patch, and where the lines for each side intersect is the rear roll center.
Old 10-28-2012, 01:08 AM   #10
gmookher
more importantly, whose LCA's correctly address this for cars running more than 20mm of drop?
Old 10-28-2012, 02:54 AM   #11
BRZranger
I don't think anyone's does. After dropping 1.5" i don't notice any negative or unwanted effects.
Reading about Roll center adapter (RCA) on the STI forums, some don't notice any real benefits. Some reports of broken whiteline RCA and some removing them after install.
Old 10-28-2012, 05:58 AM   #12
DEnd
More body roll might actually be a good thing, depending on what the camber change is, the car may benefit from a more aggressive camber curve.
Old 10-28-2012, 08:14 AM   #13
gmookher
are you suggesting that up front? I dont see any squatty benefits up front...
Old 10-29-2012, 07:15 AM   #14
DEnd
I don't know the specifics for this car, but typically lowering the car results in an increase of the distance from the roll center to the center of gravity. This results in more body roll. This body roll results in a camber change at the wheels, this may or may not be beneficial. Whether or not it is depends on how the car behaves and which behavior you want at which ever track or corner you are trying to tune for.
uberstupid
Pin your BRZ/FRS Location on Google maps! ShoGun Scion FR-S / Toyota 86 GT86 General Forum 137 02-12-2019 07:00 PM
new badge location... Leonardo Cosmetic Modification (Interior/Exterior/Lighting) 11 08-29-2012 11:06 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
FRS/BRZ map location suggestion phenom86 Site Announcements / Questions / Issues 0 07-05-2012 04:15 PM
