#645 |
Drives: '04 MR2 '10 MX5
Thanks for posting that video. The workings are very interesting.
#646 | |
Drives: '13 Firestorm FR-S MT, '04 Tacoma
I know many are frustrated with this issue but you can't be so quick to condemn the company as a whole who (as it sounds from other posts here) is working very hard to nail down the root cause of this issue. To paraphrase: "You can't hold a whole automotive company responsible for the behavior of a few, sick twisted individuals. For if you do, then shouldn't we blame the whole automotive industry? And if the whole automotive industry is guilty, then isn't this an indictment of our manufacturing companies in general? I put it to you, Greg - isn't this an indictment of our entire American society? Well, you can do whatever you want to us, but we're not going to sit here and listen to you badmouth the United States of America. Gentlemen!" |
#647 |
#648 | |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
![]() Three questions (if you can answer them) A) Is the implementation of the FA20's system "steplessly variable" or is there only one advance and one retard timing available? B) I'm assuming the hydraulic pressure for actuation is travels down the camshaft; are the entry and egress points for the VVT system's oil closest to or farther away from the cam gear? (Edit: Or is the oil supply coming from the oil pump on the valve cover?) C) What's the size of the largest particle which could safely work itself in and out of the system?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn Last edited by @Art_Mighty; 09-22-2012 at 08:47 PM. |
#649 |
Drives: Honda Fit
Or it's a poor design poorly executed. The engine is way too complicated for a back-to-basics inexpensive sports car. (Or maybe the standard for what is complicated and what is not complicated has shifted in the last few years. I can't tell. But I think it's too complicated.) |
#650 | |
uosɹǝdʎɐl ʇɹǝdxǝ
It's pretty clear to me that an engine management system which has to control the timing of spark, valve opening, fuel control over TWO independent injection systems up to 7500 RPM over a range of different operating conditions (both inside and outside the engine) is nearly as complex as you can make it. The only complexity inducing mechanism missing is a forced induction system of some kind (and that's coming). Our cars have a 4-channel ABS / Traction Control / Stability management system with user controllable threasholds and deactivation. The stability management system actively monitors the car's yaw rate and then intervenes when the driver has exceeded it's allowable limits. There's a brake force distribution system which allows the car to vary brake force per-wheel based inputs from steering angle, brake force applied, and vehicle speed. You have an electrically driven, speed sensitieve, varable effort power steering system with it's motor embedded in the steering column itself so the engine can sit 10mm lower. The ABS, Steering, Gauge Cluster, Air Bag, Tire Pressure Sensor, Audio System, Transmission, Engine (split up into the ECU and the FCU; Fuel Control Unit) all have independent computers which speak to each other in real time through the car's CAN BUS Modern day cars are VERY complex but consider that 10 years ago getting all of this integrated into a car meant you were spending $60,000. The FR-S/GT 86/ BRZ are a value at twice the price. For everything they got wrong on this car, they got a lot right (just saying...)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn Last edited by @Art_Mighty; 09-22-2012 at 01:10 PM. |
#651 | |
Done
Drives: WRB BRZ
#652 |
uosɹǝdʎɐl ʇɹǝdxǝ
It depends on the state...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#653 |
Drives: Whiteout FR-S
After 3 weeks of my FR-S being in the shop, it is finally back in my hands and working perfectly =)
First they changed out the exhaust cam gear, which didn't fix it, so they changed out the ECU and that seemed to fix it. 300+ miles since the fix and still no problems! |
#654 |
Done
Drives: WRB BRZ
md isn't specific and I've been digging deep...but we can submit early for lemon so I guess it makes no difference. I just prefer specifics.
guess I'll just hope for a fix before it comes to this. I love this car, it's my 1st Subaru. I hope we all get what we want. |
#655 | |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
#656 |
Drives: Hyundai genesis 2.0t
Well add me to the list for cel due to crankshaft postion sensor, engine management problems, and abs problems. Had 2500 miles. It's a fr-s. in shop now.
#657 | |
uosɹǝdʎɐl ʇɹǝdxǝ
If MD doesn't have specifics spelled out, I would assume you have 30 actual days. I would get in touch with a Lemon Law Attorney, file and then use that as leverage to get the outcome you want. My state (IL) specifically states 30 "business days" so that would mean I would have to be without the car for 6 weeks before that threshold passed.
#658 |
uosɹǝdʎɐl ʇɹǝdxǝ
Don't forget to give us the last six of the vin (with the last two numbers XX'ed out: example "6783XX")
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 06:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 10:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 01:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 10:00 AM |
