Old 09-22-2012, 05:20 AM   #1
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
ok so ive been playing with this idea 2.8L v8 swap?
SPECIFICATIONS H1V8:
75° odd fire V8
2.8 LITER, 170 cu. in. displacement (3.0 liter optional)
84mm Bore X 63mm Stroke (67 stroke optional)
4 cams, 32 valves via internal silent chain
530mm wide x 485mm long x 530mm high
400HP @ 10,000 rpm with stock street cams (higher spec. is available)
245 ft-lbs torque @ 7500 rpm
200 lbs engine weight
Billet nitrided steel 180° crank
4340 H-beam con-rods with ARP bolts
Billet 6061-T6 aluminum crankcase
Dry sump 0il system with 4 stage pump
7.25" or 5.5" Twin disc clutch
DTA S80 full sequential ECU
Unique cylinder offset and cam drive
(source: http://www.h1v8.com/page/page/1562069.htm)
I have been thinking about this swap, the engine is about the same size as the fa20 but has 200-250 more bhp and a 10,000 rpm redline and only weighs 200 lbs stock
when i get around to buying a used/crashed frs/brz i would be doing the swap and stripping the car for track duty
and replacing the stock final drive with a 5:1 raito
any thoughts?
also i was wondering(yes i did a search and maybe i didnt use the right key words) but what is the dry weight of the FA20?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 4 Users Say Thank You to carbonBLUE For This Useful Post:
Boofneenee (12-18-2014), OjiGeorge (09-23-2012), pleong (01-20-2015), sato (12-10-2014)
Old 09-22-2012, 06:28 AM   #2
DSTL
Drives: 2013 BRZ Limited 6MT
Pretty aggressive. It's a great platform, keep us posted!
Edit: do you have one of these engines in your possession or experience with them? Are they legit / price?
DSTL is offline   Reply With Quote
Old 09-22-2012, 06:34 AM   #3
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Are you an existing customer?
"As of March 2012, the H1 and H2 engine technology has been sold. The new owner will further develop the technology for race applications and plans to offer it to other markets later this year. Hartley Enterprises retains the rights to build these engines in limited numbers for select existing customers and special projects in the US."
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 09-22-2012, 07:58 AM   #4
carbonBLUE
Reverse Burnouts
the idea was thrown up in the air, the engine comes ready-to-race, they go for around 12k-18k(edit:used) depending on what you want in the engine, they are well built and ive never heard of problems resulting in build quality from them, i love to rev, i love hp, but i also love na, and this is a nice little package, with the right final drive and with this car being light enough, also with the manual and automatic transmissions holding up to over 300+ tq from accelerated prefomance's turbo build, small modification to the transmission bell housing and it should bolt up just fine, i do want to retain the butter smooth shifting in the manual, if the build can be done without buying a new transmission, that would be great... all my option are open, we will come to one solution if we decide to go down this route, i will let further development and R&D progress before i attempt the build
still deciding if i want to go auto or manual with this engine aswell
i think you can get a brand new H1 for 30k or something like that, but you pretty much just check valve tolerances and change the oil and thats all you do to maintain them...
EDIT: they also have a 4.0L v10 with 600hp under development, that will weigh as much as a standard 2.4L car engine, forgot the source, i found some info on it when i was researching the engine....
(wont forget you)
2011 Infiniti G37x
Old 09-22-2012, 08:56 AM   #5
Turbowned
Turbowned's Avatar
Is that the engine made by putting two Hayabusa engines together? Those things are nuts!!
The Following User Says Thank You to Turbowned For This Useful Post:
LivingLegend (09-22-2012)
Old 09-22-2012, 09:01 AM   #6
Captain Insano
That would be awesome - 400 bhp NA in a BRZ/FRS. Too pricey for me, but if you are building an all out race/performance car that seems like it would be a very potent package with a little lightening of our platform and that engine.
Captain Insano is offline   Reply With Quote
Old 09-22-2012, 09:41 AM   #7
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
I need to get my hands on one of these engines.
Apex Chase is offline   Reply With Quote
Old 09-22-2012, 10:39 AM   #8
xwd
Cool engine but I don't know if I'd ever put one in a FR-S/BRZ. I'd put it in a Super 7 or some other tube frame kit car.
Old 09-22-2012, 04:12 PM   #9
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
^This. It's a neat idea but that engine would be a complete waste in something as heavy as the BRZ/ FRS. You need something below 2,000 lbs for an engine like that.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 09-22-2012, 04:16 PM   #10
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Yeah peak torque at 7500rpm is a huge turn off for me. I think it would be cool to strip down a scion iq and put that motor on the back though.
Old 09-22-2012, 04:25 PM   #11
dabocx
dabocx's Avatar
Drives: Scion FRS
If i had money to burn...
I have a 93 miata shell in my backyard
dabocx is offline   Reply With Quote
Old 09-22-2012, 07:12 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
This would work wonders for a drift car
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
StarsGarrador (09-23-2012)
Old 09-22-2012, 07:41 PM   #13
Jayde
Jayde's Avatar
Very interested in this project if you start it. Subscribed!
Jayde is offline   Reply With Quote
Old 09-23-2012, 03:53 AM   #14
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Not cheap. You'd be better off with an LSx.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
What do you think about this idea... FRSowner Scion FR-S / Toyota 86 GT86 General Forum 10 07-20-2012 03:26 PM
Dealership playing games w/ price? Chewie4299 BRZ First-Gen (2012+) — General Topics 14 07-02-2012 06:11 PM
Playing music off of USB question Hanzo Electronics | Audio | NAV | Infotainment 22 06-26-2012 10:44 AM
My first time playing... ruskymx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 06-25-2012 02:19 AM
