Old 09-19-2012, 10:13 AM   #1
FR-S #2637
Drives: 2013 FR-S Firestorm A/T
FR-S Speed/RPM Calculator
I have a document called "Vehicle Speed/RPM Correlation Calculator" which is from the FT86Club and came from somewhere on this website. The figures are for the FR-S with manual transmission. Is there a similar document for the automatic? I can do the math (ratio of AT vs. MT gear ratios times the MT figures) but there may be some slippage in the AT that I'd like to quantify. Does such a document for the AT car exist?
FR-S #2637 is offline   Reply With Quote
Old 09-19-2012, 10:17 AM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
Where is the one for manual? I need this to set up my Torque app.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-19-2012, 10:33 AM   #3
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
i tried to set one up the other day but i dont know the exact wheel diameter for our tires.. when i use a calculator it gives me 24.62 in diameter..heres what i got with the rev limiter at 7800.
Tire diameter (in.): 24.62
RPM: 7800
1st Gear Ratio: 3.626
2nd Gear Ratio: 2.188
3rd Gear Ratio: 1.541
4th Gear Ratio: 1.213
5th Gear Ratio: 1.000
6th Gear Ratio: 0.767
Final Drive Ratio: 4.100
1st Gear (mph): 38
1st Gear (kmh): 61
2nd Gear (mph): 64
2nd Gear (kmh): 102
3rd Gear (mph): 90
3rd Gear (kmh): 145
4th Gear (mph): 115
4th Gear (kmh): 184
5th Gear (mph): 139
5th Gear (kmh): 223
6th Gear (mph): 182
6th Gear (kmh): 291
By the way @ synack what information do you have to put in torque app
website i used http://www.apexgarage.com/tech/gear_ratios.shtml
brichard0625 is offline   Reply With Quote
Old 09-19-2012, 10:53 AM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
I need information for what speed is the car going at 2000rpm for each gear.
1st gear @ 2000 = ??mph
2nd @ 2000 = ??mph
For Manual and all 6 gears.
I don't have the car right now to test it but I was hoping for there to be some documentation or something else.
Old 09-19-2012, 10:58 AM   #5
brichard0625
Old 09-19-2012, 11:02 AM   #6
brichard0625
2nd @ 2000 = ??mph
Where can you put that information at on the torque app? I remember seeing something like this but i cant find it anymore
Old 09-19-2012, 11:05 AM   #7
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
According to the Michelin website the Primacy HP 215/45R17 tires have a diameter of 24.7 inches (844 revs per mile).
Edit: Oops, forgot to refresh before posting. Looks like you already had that info
Smudgeous is offline   Reply With Quote
Old 09-19-2012, 11:40 AM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
THANK YOU
Actually there is a new plugin that gives a retro UI for Torque and it gives some extra features. In one of the settings menus I was asked for MPHs at 2000rpm so I just figured I would want to give it as much data as possible.
It's called Racing Meter.
Old 09-19-2012, 11:41 AM   #9
brichard0625
THANK YOU
O cool i didnt even know im going to look at that now
transmission
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
BRZ top speed speedracer38 BRZ First-Gen (2012+) — General Topics 66 07-08-2012 03:37 PM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
