Old 09-18-2012, 04:31 PM   #15
master345
Drives: jag xjs
Stock tires
I was thinking about going with something like this. It seems silly to throw away the new tires that come on the car, or try to sell them of eBay which is a big hassle. Instead you have put the original stock tires on the new wheels, right?
This looks great. But can you please post some pics showing the width of the tires in this config?
So with this setup, you only have to pay for the wheels, which I am assuming is $1100. Add mount/balancing, and you're done, right?
I would however, go with a ProKit to lower the car by 1". I understand this might cost $250 for the springs and $350 for labor.
So after everything is done, I would then sell the original rims for $150 each. This exercise would then result in a nice upgrade without too much cost or waste.
I don't really like the center caps in your pics, as they don't match well. What are the options with this wheel?
Nice posting! You've made a wise choice, I think.
master345 is offline   Reply With Quote
Old 09-18-2012, 10:27 PM   #16
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
Originally Posted by mickey177 View Post
Can you please take more side photos?thanks
will do. I'll try to remember my camera tomorrow
hankster is offline   Reply With Quote
Old 09-18-2012, 10:51 PM   #17
hankster
hankster's Avatar
yup, going to use them up learning to really drive this car in autocross before buying stickier performance tires
will do. They are exactly same size, width and offset as stock so will look the same
$51.99 total to mount and balance. Make sure the shop has a touchless setup or at least plastic clamps so as not to scratch the wheels. Most shops have machines with metal clamps they will scratch your painted/coated wheels.
no lowering for me - autocross stock (RTR) class
I either leave them or remove them. I'll probably remove them tomorrow and see how I like it. I don't know of any other options.
thanks, they definitely fit my needs and expectations
Old 09-19-2012, 08:41 AM   #18
hankster
hankster's Avatar
I also bought hub rings for the wheels off of ebay for $9 which included shipping. OD75mm/ID56.1mm
Old 09-19-2012, 11:40 AM   #19
TXFRS
Drives: FRS - Argento
Nice.
Aside from having the fastest color, have you noticed a performance difference with the lighter wheels?
TXFRS is offline   Reply With Quote
Old 09-19-2012, 05:04 PM   #20
hankster
hankster's Avatar
Originally Posted by TXFRS View Post
Nice. Aside from having the fastest color, have you noticed a performance difference with the lighter wheels?
absolutely, totally subjective but feels a bit more agile, lighter, like it rolls easier. Turning feels easier and smoother.
HOWEVER, I also had OEM crash bolts installed and a mild 'performance' alignment done so no telling how much the new lighter wheels are contributing to that versus the alignment.
The stock front and rear toe settings were out of spec anyway. From what I've been reading that's not uncommon in these vehicles. Everyone should probably go have their alignment checked. Easy handling improvement and extend the life of your tires.
Old 09-19-2012, 08:17 PM   #21
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
But the Enkei RPF1 Type IIs are heavier than the original RPF1.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 09-19-2012, 09:23 PM   #22
hankster
hankster's Avatar
yes, by about a pound or so. Not sweating it. They are also available in 17x7 now. RPF1 17x7 are not available until December.
Old 09-19-2012, 11:34 PM   #23
hankster
hankster's Avatar
Exclamation PIX PIX PIX
The Following 3 Users Say Thank You to hankster For This Useful Post:
mickey177 (09-20-2012), normancw (09-21-2012), touge-n00b (09-21-2012)
Old 09-20-2012, 07:15 PM   #24
ft86Fan
ft86Fan's Avatar
They were supposed to be available on 10/12. Now they changed it to Dec
Your pics are looking good
Old 09-21-2012, 04:34 AM   #25
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Great wheels, now it needs a drop stat!
-Frank
ModBargains is offline   Reply With Quote
Old 09-21-2012, 11:14 AM   #26
hankster
hankster's Avatar
had my order in for the RPF1's but when I found out they pushed availability back to December I cancelled the order and went for the Type II instead.
Old 09-21-2012, 05:30 PM   #27
ft86Fan
ft86Fan's Avatar
Yeah, good call. I'm just going to get the RPF1 next year since its almost winter already
Old 09-23-2012, 08:54 PM   #28
hankster
hankster's Avatar
...I'm just going to get the RPF1 next year since its almost winter already
that's what I like most about Houston - no real winter to speak of!!!
The Following User Says Thank You to hankster For This Useful Post:
meWant (12-08-2012)
Wheel Directory: Enkei EV5 17x7.0 +38 rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-17-2016 11:47 AM
Wheel Directory: Enkei RS-7 17x7.0 +35 m.box.design Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-06-2016 10:56 AM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 01:28 PM
Wheel Directory: Enkei FLC-01 17x7.0 +40 Mr.Jay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-09-2013 03:44 PM
Wheel Directory: Enkei WTE II 17x7.0 +41 stout90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2013 10:18 PM
