Old 09-08-2012, 02:09 AM   #15
-max-
Drives: Firestorm FRS
I think a spare tire sub box would go over well.
-max- is offline   Reply With Quote
Old 09-08-2012, 02:54 AM   #16
Hanakuso
Originally Posted by DIE1000DEATHS View Post
Radio bezel to fit double DIN HU's...
This with the same exact texture and pattern. It must be 100% same lol
Hanakuso is offline   Reply With Quote
Old 09-08-2012, 03:39 AM   #17
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm replacing the stock dash speakers with just a tweeter, would like a new grille made thats flat after i put the tweeter where the factory mid was.
Old 09-08-2012, 02:02 PM   #18
wheelhaus
wheelhaus's Avatar
Whereas I'd like to see one that allows the tweeter to protrude at an angle, but behind a grille.
Old 09-08-2012, 02:42 PM   #19
daforce007
I'll echo the request for an 8" enclosure with an area where a small (approx 12"x12") D-class amp could attach. Similar to the OEM Audio Plus setup, bit with the amp visible; for ease of wiring and setup.
daforce007 is offline   Reply With Quote
Old 09-08-2012, 04:53 PM   #20
JoeBoxer
JoeBoxer's Avatar
That would be cool too there are just so many different tweeter sizes.
Old 09-09-2012, 12:18 AM   #21
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
An enclosure or something to squeeze some 8" woofers where the rear speakers live... One for each side. THAT would be killer. Even if the interior panel needs to be modified
THIS! If I don't do the subs in the spare tire area, I'd like to try this.
Does anybody know the depth behind the rear side panels?
kmbkk is offline   Reply With Quote
Old 09-09-2012, 02:50 AM   #22
wheelhaus
wheelhaus's Avatar
I'd have popped off the panels myself and measured *if* I had my car... But, I understand there's a lot of room, so a low profile 8" would probably fit since they have typical mounting depth for surface mounting is less than 3". The only thing I'd be worried about is hunting down vibes and rattles...
Here's a list from sonic:
http://www.sonicelectronix.com/cat_f...low-mount.html
Most of the specs show cutouts of about 7 1/4, mounting depth less than 3", and sealed enclosure between 0.15-0.6 cu ft. (the kicker CVT8(X) is deeper and needs a larger volume, possibly too much). I personally like the look of the Pioneer TS-SW84, reviews seem very positive.
I envision a small bladder shaped box (maybe squared edges for ease of fabrication), about 1/4 cu ft total. Possibly adjustable mounting tabs to ensure good fitment to hard points. Maybe a foam backer pad if it touches the outer skin, and a few tiles of CLD for vibe damping. This bladder has a cutout for an 8" sub, (or a specific one or two models are preselected and sold with the kit to guarantee fit). Use a template to mark the interior panel, cut out the marked 8" hole (or sell a pre-cut panel with the kit). A new grille mounts to the surface of the interior panel and secures to the enclosure, sandwiching the interior panel to make a more solid fit. Getting the shape to fit cleanly against the backside of the interior panel would be the toughest part to design.
I's be glad to give some ideas on how I'd approach fabrication. (Assuming it will fit, that is)...
Old 09-17-2012, 12:49 PM   #23
SpeakBeck
Drives: SRT4
We have the FRS here for the week.
Gauge pods and 8" subwoofer enclosure for the trunk seem to be the most popular demands.
SpeakBeck is offline   Reply With Quote
The Following User Says Thank You to SpeakBeck For This Useful Post:
Calum (09-17-2012)
Old 09-17-2012, 01:22 PM   #24
Calum
That Guy
Drives: 2013 asphalt FRS MT
It's great to see vendors being so interactive.
Old 09-19-2012, 01:46 PM   #25
SpeakBeck
Drives: SRT4
8" enclosure is coming along nicely.
Old 09-20-2012, 05:31 AM   #26
Z86
Drives: 86 GTS Auto in Pegasus White
An enclosure or something to squeeze some 8" woofers where the rear speakers live... One for each side. THAT would be killer. Even if the interior panel needs to be modified, I think it would sell.
This
And this
Z86 is offline   Reply With Quote
The Following User Says Thank You to Z86 For This Useful Post:
Dadhawk (09-20-2012)
Old 09-23-2012, 08:56 AM   #27
dualbios
Drives: 86
The 8" sub boxes for replacing the rear speakers would be amazing. also a dash pod for speakers to fit properly. gauges would be a great thing aswell
dualbios is offline   Reply With Quote
Old 09-23-2012, 01:14 PM   #28
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Also, videos and pictures of progress would be nice
enjoi23 is offline   Reply With Quote
